Post your firebird pics
#1901
Engine: 4++,350 & 305 CIs
Re: Post your firebird pics
Thanks, The brakes were new in 2000ish, BAER 13" and 2 piece rotors on all 4 corners.
#1902
Car: 1987 IZ, 1990 IZ, 1992 GTA
Car: 84 Pontiac Firebird
Engine: 368 6.0 LS
Transmission: 350 turbo+tci 3000 stall
Axle/Gears: 10 bolt 7.5 with 3.73 auburn posi-t
Before and after bought February 16 and after is current
#1913
should be making about 550hp on a stock 150k 5.3 LS. I don't know the formula to calculate HP off of injector duty % But at 9psi and my 55ish injector duty cycle someone on this forum calculated about 525hp. So add 2.5psi and a 68% injector duty cycle and figure what that's about. This are 72lb injectors btw.
The Supercharger is pulley'd down already so I cant increase boost anymore. But I'm already gathering parts for ported heads, lifters, cam etc. Should net me a minimum of 100hp easily on the cam alone without boost.
But I'm done at 650hp... no need for it on the street. its already almost too much unless I get a nice straight away and lots of room lol. But Ive done that and wanted more streetability so a tame motor and boost works for me.
#1915
haha u better believe it but thank you. Anymore and I'd be tempted to use it and prob total the car. Only reason its getting a cam is that I'm pulling the whole top end off to freshen the valve train and get new reman heads so the top end is like new. Since the motor has 150k of prob harsh miles I might as well throw in a cam to take advantage of the blower. I picked up a used Lq9 cam (stock 6.0 peanut cam) which would net me 40hp at 6000/6500 over the LM7 cam (stock 5.3 peanut cam). But Cammotion wants me to get a $400 custom cam lol which would net me like 100hp over stock and retain stock ish idling/driving at low RPM.
#1916
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
^ sounds cool....point exact lol but I'd beat up the setup you have now until a problem arises to have to refreshen the top end...I try not to be wasteful lol... either way great work!!!
#1917
Car: 92 Firebird Formula
Engine: 5.0 tbi
Transmission: 700r4/shift-kit
Axle/Gears: 4.11/posi
before
after
Finally got mine back from paint and body
#1919
Car: 1990 Trans Am
@russ looking good, paint and body turned out great!
Cb , love that pic of your stance!
#1920
Engine: 5.0 tbi
Thank's Maks I'm pleased the way it turned out. Now I can start cleaning it and making it look the way Dar would like!
#1924
Car: 1990 Trans Am
^punkmaster love the wheels, matches well without ground efx.
#1925
#1929
#1931
Engine: 5.0 tbi
Here's a couple more updated picts. Thinking about putting Cragar SS wheels on it?
#1932
Car: 1990 Trans Am
Russ, looks good I'd try to use the wheels you have now maybe polish them or black
#1933
Engine: 5.0 tbi
Yeah the cragars are probably kinda dated. Sorry had a 70's flash back LOL.
#1934
Engine: 5.0 tbi
Picked up some old school Centerlines for my 92. Can't wait till I polish them and install them . Only $200.00 for all four.
#1935
#1936
Car: 1990 Trans Am
^nice!!!! A very lonely bird lol but all look stunning!
And Russ great pick up! Can't wait to to see them on
#1937
Engine: 5.0 tbi
Got the Center lines on today and had to change the electric fan. Here are some pict's of engine bay before I start on it.
#1938
Car: 1990 Trans Am
Russ looks better with new wheels! Gotta shine up the tires to match those pretty wheels!
#1939
Engine: 5.0 tbi
Started on engine this weekend . Still needs more cleaning. Pict's not very good [phone doesn't take very good pict's in my garage]. Will post better ones later [taking my camera with me]
#1942
1 Post
Car: 1999 Camaro Z28
Engine: 5.7
Thank ya! It's an 88' GTA, 5.7. 18x10 xxr's with 285/40 Goodyear Supercars on all four corners, wing from my 2000 TA, RA2 hood, traded my original GTA wheels for the black paint work and spoiler mounting. Slightly modded drivetrain, bout to dive into it some more. Redone tan leather and swapped a 4th gen A4 console in
#1943
#1944
1 Post
Engine: 5.7
It's +20 on all 4 and 1" spacers plus the front I used the factory spacers to clear the hub dust cap. Once I swap my new brakes on I should be able to ditch that.
#1948
Engine: 5.0 tbi
Here are some better engine pict's.Still a little more work to do .Got a new headliner plastic going to paint it to match rest of interior. Then work on the exhaust
#1949
Drove her to work today and had to get this shot, wish I could get a better shot but that's about the best I could do.
