My 84 Trans am (the homecoming)
#101
Car: workcar Legacy Cruising 84 trans am
Engine: Ls1 99 corvette
Transmission: update working to get a T56
Axle/Gears: 2004 GTO IRS
Re: My 84 Trans am (the homecoming)
tanks Guys
small update
the first cruises over no photo from it do to I was not there
car is now in temp housing
Pass.door out and more red necks job coming into the daylight , like rang bolts and broken parts
sets is out
console next
small update
sets is out
console next
#103
It is good to know it help me get out into the cold to work on it hope that it wont will be long winter
#104
Car: 1991 camaro Z28
Engine: 5.7 350 TPI with a performance chip
Yeah this really caught my eye, can't wait to see it done to,
#105
Car: 1989 Turbo Trans AM #82
Engine: 3.8 Turbo V6
Transmission: 2004R
Axle/Gears: 3.27 9 Bolt Borg Warner Rear
wow great work so far, love it!!!!!
#108
Car: 1989 GTA
Engine: 5.7 350
Huge props on the restoration, don't see that man nice 84s running around especially in your neck of the woods i would think.
P.S. Nice Subaru wagon i rock one in the winter when the GTA is in the garage
#109
#110
Here we start a joint venture for our projects
But do to Sony failure almost all picture of the transfer were lost. But here is one
and one picture from befor Ls1 removed from it
more info later
more info later
#111
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
hmm is that a totaled GTO?
did the sony camera fail like their PS3 do because they think it's the 29th february?
good luck with the ls1 swap!
#112
picture delete in transfer from camera and windows with out going to Recycle Bin
the Gto looks bad but the interior is good but it is going into chevelle
for me it is upgrade
from 96 abs 3 channel to 2004 4 channel abs
10 bolt 4.11.1 to 3:73.1 rear end assembly
and more
and more
#114
small update
GTO kmember out
and IRS too .
GTO kmember out
and IRS too .
#116
#118
small update
My brother been busy cutting GTO down
I will save rest for My build
Most likely will I be using 2002 cluster that I finally had time to it pickup
#119
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
Awsomeness all around...GREAT work man....crazy to see some posts in march and still snowing up there (unless these are older pics) cant wait to see the final results
#120
Car: 1983 Pontiac Trans Am "Daytona"
Engine: LG4 305 V8
Transmission: T5 5-speed
Wow, looks great so far! Hope you don't live near that damn volcano...scary ****!
#124
dead in the water at the moment do to corneal graft surgery but hoping that I will be able to work on this sumer but not much room to work with were his is
#125
Car: 1985 Trans Am
Engine: 305 Carb
Axle/Gears: Borg Warner 3.27
man ill be following ya, this is a amazing rebuilt. always loved them 15th's
#126
Great thread to read ; Fabulous story and I'm hooked!!! Best of luck with your health and being able to get on with the build!
#128
Interesting about the rear. Most IRS swaps are C4, and there aren't that many completed C4 IRS projects in f-bodies. There is one guy doing a C5, but this is the first attempt I've seen at a GTO rear.
1992 Trans Am
05-10-2023 07:19 PM
1984, 3rd, 84, black, generation, gold, ground, kvartmilais, pics, rebuild, t56, tbi, tpi, tranmission, trans, transmission
