My 84 Trans am (the homecoming)
#51
Car: workcar Legacy Cruising 84 trans am
Engine: Ls1 99 corvette
Transmission: update working to get a T56
Axle/Gears: 2004 GTO IRS
Re: My 84 Trans am (the homecoming)
I need to buy Motor Mount 50$ + tax
#52
Car: 88 GTA
Engine: 305 V8 LB9
Transmission: 4 sp. Auto-4L60
I WOULD NOT, NOT, NOT keep it outside under a tarp!! Under ANY circumstances!
If it was a water-proof, breathable car cover, I might be okay with that, but a plastic tarp will only hold in and trap moisture and start rusting all that beautiful chassis work! If you keep it outside, get a weatherproof, breathable cover or put it back inside, but for heaven's sake, do NOT keep it under a tarp!
The work is beautiful, though. Can your brother come to the States and do mine??
#53
under the plastic tarp is soft car cover (4-LAYER CAR COVER)
my brother is busy he is working on his chevelle thats why my Trans am is out side
any way the engine bay will be most likely resurface again to get it little better
#54
ufff that is bad
here is my dirty old one
#55
Car: 88 GTA
Engine: 305 V8 LB9
Yours is in GREAT shape compared to mine...for an 85, that's beautiful condition!
I'm going to be busily working on my dash while the car is in the body shop. Might recover the seats while I'm at it.
#56
it is in great shape but I´m not using it go to do 4gen dash swap
#57
Car: 88 GTA
Engine: 305 V8 LB9
#60
another small update
I´m continuing to clean and paint the small things
#61
#62
nice after almost 25 year under dirt looks good
#64
yes it is a camaro setup but it clear 82-84 hood , I don't no if it came from v6 or v8
#65
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Ah ha, I didn't know it was possible to fit it on the early birds, thats really cool. It is a v6 setup, at least the snorkel is, which is easy to tell by looking at the bung on it for an external IAT sensor. A while back a few TPI guys tried em out with an external mounted IAT sensor that supposedly would offer a more accurate reading of the intake air temp, unlike the factory sensor which was located in the bottom of the tpi plenium.
#66
hehe I had planing to use that hole for extra air temp sensor but it is will be some time be for I put the engine in the car , do to price of dollar and low offer time at me work,the project is slow going at this time
#67
p.s I have at it 2 upgrade to my wise list , but most likely will they be at after the car is finish
1. Racecraft Inc. K-Members
2.FAYS2 Suspension
2.FAYS2 Suspension
#68
got my self a Rack and Pinion form 1996 camaro it need paint
and another set of wheels for 126 $
#69
this is really a restorer's restoration lol...everything that has been goin on this has had an extra touch from ya! i like checking in on this build, one of my favorites on here...lots of work and time goin on on this. keep up the great work!
#70
icebird84,
1st of all nice work. U need to get some nice white 84 recaro seats to go with that car.
How were you able to confirm that a camaro Dual snorkle TPI intake will clear a 82 hood. do you by chance seen or have any pictures of it done?
I have a 82 and have the 89 Dual snorkle TPI intake (black plastic) and would like them to work.
Also whats ur thinking behind using a V6 rack and penion ? would that work in a 3rd gen compared to one from v8 without major mods?
#71
either rack and pinion will require the same amount of mods, most likely that's the one that was available. They are most likely the same part for v6 and v8 cars, the only real difference may be ratio.. Looks like it's going to be a really cool resto, can't wait to see more pics! Are you going to modify your factory k-member to work with the rack unit or get an aftermarket one already set up for it?
#72
small update and news
update
15th Anniversary horn emblem has a new hornbottom from Fiero GT
and news
4L60-e steps a side for T56 , I´m working on getting brake from ws6 and from same car interior and wiring
update
and news
#73
1 Post
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
In my experience, the camaro TPI "dual snorkel" doesn't clear a firebird hood. I did a mock-up on my 84 T/A and it didn't fit. The firebird hood has VERY little space at all above the radiator shrowd. That looks like an intense and thorough project you have going on there!
#75
Car: 84 Berlinetta
Transmission: 700R4 TransGo Kit
Axle/Gears: Lock-Right
All the way down to bare metal...
Dude, that is true love and dedication...
#78
well on the road again
this time to get some cargo
not many boxes I know
more to come
more to come
#79
Car: 88 GTA
Engine: 305 V8 LB9
A dual snorkel CAN be done on a Firebird if it's done right. This one was a T/A Nats.
#80
#81
ok first box open and in it is ?
center console with storage bin
#82
car wiring harness complete minus engine harness
AC duct work, controls, and evaporator box
#83
and more
#84
#86
thanks 300hpse
and in this one the driver and passenger door panels with switches and dash to windshield panel
here the dash frame work
and in this one
the ABS controller
and in this one
the ABS controller
#87
glad to see you're still at it! I see you got yourself a vette t-56 that you're gonna use instead of the auto? Did you get the parts to convert it to an f-body t-56 yet?
#88
not yet and I lost the t56 and my brother lost the ls1/LS6 do to guy did have the right to part the corvette he bought it on loan
but t 56 will be
but t 56 will be
#89
#90
Car: 88 GTA
Engine: 305 V8 LB9
#91
1 Post
Car: 1984 Trans Am
It looks to me like a good portion of the bracing under the hood was cut away to create clearance for that intake ducting.
#92
Agreed, it looks like all the bracing in the area of the intake ducting is cut out.. I think it would be really cool if you cut away the area under the vents on the front of the hood and made the vents functional and also cut a corrisponding hole in the top of the ducting, stuck two small square air filters in there and make it a functioning ram air setup (not sure if the vents line up with the top of the intake ducting to make this idea feasable and im sure it wouldn't be that great of an idea as far as rain is concerned but it sure would be cool if it worked).
#93
found one more to make first cut on
#94
last empty
#96
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
looking awsomeee!!!
any updates??
any updates??
