Detroit Speed 1987 Camaro Test Car 2.0
Old 03-09-2017, 09:23 AM
  #151
COTM Editor
BADNBLK's Avatar
Re: Detroit Speed 1988 Camaro Test Car 2.0
Ahhh tow hooks...
Old 03-09-2017, 09:49 AM
  #152
Beater79TA's Avatar
Originally Posted by Detroit Speed
Our tow hook threads into the crash bar that we had fabricated. This is not something that we will offer as a product. With the current location of the plug, using our method on a factory bumper support would require quite a bit of cutting/drilling to attach a hook to a proper chassis point.
Note to self, add this to the list of items to talk to the DSE reps about at Summit Motorama in April....
I suspected that was the case since I've spent the last year trying to sort out how to hook one to a factory frame point on both the front and rear without interfering with other items or completely destroying the bumper. It gets even more fun with a Firebird if you try to find a spot on the front that will let the hook out a factory opening so you don't have to cut the bumper cover.
Old 03-09-2017, 09:59 AM
  #153
Beater79TA's Avatar
Originally Posted by BADNBLK
Ahhh tow hooks...
You've got a couple of months until PPIR to figure out front and rear tow hooks. Clearly marked and minimum of 2 inches in diameter. Rear will be easier than the front from an accessibility standpoint. Front bumper will make the front one interesting to do without cutting a hole for it.
Old 03-09-2017, 10:20 AM
  #154
TGO - 10 Year Member
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Then....
You still have to figure out where/how to mount the AntiLaser diode jammers (4-6 per car).
Old 03-09-2017, 10:42 AM
  #155
COTM Editor
BADNBLK's Avatar
Yeah I do. If I could take back time I would have finished that off while I had the bumper cover off, but barely made the PPIR event last year anyway. It will be done.
Old 03-15-2017, 02:44 PM
  #156
Detroit Speed's Avatar
Car: 1987 DSE-Z Camaro
Engine: 388ci LS7
Axle/Gears: Ford 9" DSE Full Floater
We have the body back after a quick touch-up blast and the underside of the hood has been cleaned up and primed. Everything is now being prepped for epoxy. Stay tuned...
Attached Thumbnails Detroit Speed 1987 Camaro Test Car 2.0-dse-3-12-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-3-12-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-3-15-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-3-15-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-3-15-2017
Old 03-15-2017, 05:51 PM
  #157
COTM Editor
BADNBLK's Avatar
That cow catcher on the front would make any train jealous!
Love it!
Old 03-17-2017, 10:31 AM
  #158
Engine: 388ci LS7
Our Paint/Body Specialist Austin and Test Car Fabricator Matt are moving right along...
Attached Thumbnails Detroit Speed 1987 Camaro Test Car 2.0-dse-3-17-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-3-17-2017
Old 03-17-2017, 12:46 PM
  #159
COTM Editor
BADNBLK's Avatar
Tell me that is just your epoxy sealer? Cause if you paint the damn thing black I'm gonna start dreaming of it, and never get any good sleep!
Old 03-17-2017, 01:14 PM
  #160
Engine: 388ci LS7
Lol, it's epoxy.
Old 03-22-2017, 12:54 PM
  #161
Engine: 388ci LS7
More body shop progress getting the engine bay primed and smoothed out...
Attached Thumbnails Detroit Speed 1987 Camaro Test Car 2.0-dse-3-21-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-3-21-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-3-21-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-3-21-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-3-21-2017
Detroit Speed 1987 Camaro Test Car 2.0-dse-3-22-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-3-22-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-3-22-2017
Old 03-22-2017, 04:36 PM
  #162
COTM Editor
BADNBLK's Avatar
Looking great guys. Glad to see someone welded up the bottle mount holes. I'm really jealous of the master cylinder mount set up. Excited to see the next stage!
Old 03-24-2017, 12:34 PM
  #163
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
What has been smoothed out? Do you mean you wet sanded the primer? I noticed the picture that shows the body filler spread on like a blanket, I really hope you sanded most of that off. The larger the surface area that body filler has the more prone to cracking/failure it becomes. I use Evercoat Rage Ultra and I had called them when I did my engine bay and the representative had said not to go over 6" in circumference unless it was almost a translucent thin coat.
Old 03-24-2017, 04:34 PM
  #164
COTM Editor
BADNBLK's Avatar
Do you know who DSE is and the level of builds that they are putting together in their shop??? I'm gonna guess nobody needed to call a tech line to figure out how much filler was ok to put on before final prime... I'm no pro body man, but I see nothing excessive in the areas pictured.
Old 03-24-2017, 05:52 PM
  #165
Tibo's Avatar
Car: 1991 Z28 Vert
BADNBLK--I'm no professional bodyman either which is why I had called Evercoat. There are limits in regards to the usage of body filler, it even states so on the side of the can by issuing a maximal thickness boundary but there is no mention of maximal surface area covered. The larger the area covered the thinner the application of filler needs to be. One of the other interesting tidbits that the representative told me (that I hope DSE didn't fall victim too also) is that Body fillers do not chemically bond with Epoxies, they will only stick with adhesion so you have to use uber coarse sandpaper to where the epoxy primer is almost gone. You also have to wait until the epoxy has fully gassed off. Putting filler right on top of Epoxies may lead to adhesion problems down the line.
Old 03-25-2017, 07:03 AM
  #166
kaos420's Avatar
Car: 88 gta
Engine: 5.8
Axle/Gears: 3.73 POSI
BADNBLK REMEMBER THERES ALWAY ONE KEYBOARD WARRIOR IN THE BUNCH..Next he wil be telling chip fosse how to paint lol
Old 03-25-2017, 07:06 AM
  #167
M G Brewer's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77
DSE knows what they are doing. I have been keeping up with them for a very long time.
Old 03-30-2017, 08:41 AM
  #168
Engine: 388ci LS7
This week's update features more body shop progress. The car is just about ready to be primed, but we had to take a short pause and shoot the upcoming product catalog with our friends at Norton Abrasives!
Third Gens are becoming accustom to the lime light these days!
Attached Thumbnails Detroit Speed 1987 Camaro Test Car 2.0-img_2485-copy.jpg   Detroit Speed 1987 Camaro Test Car 2.0-img_2473-copy.jpg   Detroit Speed 1987 Camaro Test Car 2.0-img_2489-copy.jpg
Old 03-30-2017, 10:40 AM
  #169
BOTTLEDZ28's Avatar
Transmission: A4
This thread pleases me.
Old 03-30-2017, 10:44 AM
  #170
Engine: 388ci LS7
Old 03-30-2017, 11:46 AM
  #171
Engine: 388ci LS7
As I made that last update, the guys laid down the primer!
Attached Thumbnails Detroit Speed 1987 Camaro Test Car 2.0-dse-3-30-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-3-30-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-3-30-2017
Old 03-30-2017, 04:14 PM
  #172
COTM Editor
BADNBLK's Avatar
Sooooo close
Old 04-01-2017, 12:21 AM
  #173
skinny z's Avatar
Old 04-01-2017, 10:56 AM
  #174
skinny z's Avatar
Old 04-05-2017, 10:29 PM
  #175
COTM Editor
QwkTrip's Avatar
Received 1,939 Likes on 1,324 Posts
Car: '89 Firebird
Engine: 7.0L
You think the popularity of these cars is on the rebound? I've been waiting 20 years to be cool again!
Old 04-06-2017, 08:09 AM
  #176
Beater79TA's Avatar
Some of us have had a theory on this for a couple of years. The people who were in their late teens and early 20s when the cars were new, had to give them up for families and careers. Now those same people are to the point where the kids are out of college and married and they suddenly have disposable income and nostalgia has them looking to get a toy again. And they've gone looking to get their first car back. Only this time, they can afford to make it so much better than the original one was. We take ours to a lot of events around the country and hear this theme a lot. "It was my first car and we've had it stored out back for the last ten years. Seeing yours I want to get it out and update it" or "I had one of these back in XXXX. Maybe I'll go get another one and build it for a weekend car". And this is largely being said by couples in their 50's. What I like best about this resurgance in interest is the number of companies, like DSE, that are entering the market with new products.
Old 04-06-2017, 05:33 PM
  #177
Black18Ice's Avatar
Could you give some more info on the pass side engine mount? I'm going to be running the same dry sump system and my engine mount hits the pump. I was planning on running a custom mount unless you guys had one the worked. Also, did you clearance the kmember to fit the scavenge lines in there?
Old 04-12-2017, 01:34 PM
  #178
Engine: 388ci LS7
Getting closer and closer to paint...
Attached Thumbnails Detroit Speed 1987 Camaro Test Car 2.0-dse-04-12-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-12-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-12-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-12-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-12-2017
Old 04-18-2017, 01:04 PM
  #179
COTM Editor
BADNBLK's Avatar
I can't wait to find out the color...
Old 04-24-2017, 07:20 AM
  #180
Engine: 388ci LS7
I apologize for the delay everyone, we've been busy at Road Atlanta over the weekend.
But now that we're back, how about some paint?!
Attached Thumbnails Detroit Speed 1987 Camaro Test Car 2.0-dse-04-14-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-14-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-14-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-14-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-14-2017
Detroit Speed 1987 Camaro Test Car 2.0-dse-04-14-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-18-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-18-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-18-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-18-2017
Detroit Speed 1987 Camaro Test Car 2.0-dse-04-18-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-18-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-20-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-20-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-20-2017
Old 04-24-2017, 04:05 PM
  #181
tglennon11's Avatar
Car: 87 IROC
Axle/Gears: LS1 10bolt w/ 3.73
You had to go Blue, now im really hooked
keep it up guys!
Old 04-24-2017, 06:11 PM
  #182
COTM Editor
BADNBLK's Avatar
Love the blue!!! Cannot wait to see it... in person... in grid haha!
Old 04-24-2017, 06:17 PM
  #183
dbrochard's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T5
Axle/Gears: Torsen 3.73
What color/ brand is that blue paint?
Old 04-25-2017, 09:02 AM
  #184
Engine: 388ci LS7
The paint is PPG Deltron Bright Blue Poly.
Old 04-26-2017, 01:14 PM
  #185
Engine: 388ci LS7
After a little bedliner for the wheel houses yesterday, she's officially a rolling chassis!
Coming together pretty quickly now...
Attached Thumbnails Detroit Speed 1987 Camaro Test Car 2.0-dse-04-25-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-25-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-25-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-25-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-25-2017
Detroit Speed 1987 Camaro Test Car 2.0-dse-04-26-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-26-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-26-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-26-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-04-26-2017
Old 04-26-2017, 02:48 PM
  #186
COTM Editor
BADNBLK's Avatar
Damn that is looking great!!!! Those rear coil overs are sexy sexy. Can't wait to see how the rest comes together!
Old 04-26-2017, 04:10 PM
  #187
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Can you please post what company bead liner you are using and how you applied it?
I love the build and want mine (someday) to use as many of the same products as possible.
Paints? Primers? Topcoats? Clears? Bedliner? Chassis paint? Etc...
That would be a great help to know what top shops like to use and what sort of results they get. (clearly amazing)
Old 04-26-2017, 07:24 PM
  #188
COTM Editor
QwkTrip's Avatar
Car: '89 Firebird
Engine: 7.0L
What wheels are on the car? (Brand and model name)
Old 04-30-2017, 12:35 PM
  #189
skinny z's Avatar
No flares. Thank you.
Old 05-02-2017, 02:11 AM
  #190
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
wow, what an awesome build. great job guys!
Old 05-02-2017, 02:44 AM
  #191
Twin_Turbo's Avatar
Bedliner is really catchin on for undercoating
Awesome build
Old 05-04-2017, 09:23 AM
  #192
Engine: 388ci LS7
Making more and more progress with each week. The guys took the time to focus on the doors and hatch/spoiler recently.
Attached Thumbnails Detroit Speed 1987 Camaro Test Car 2.0-dse-05-04-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-05-04-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-05-04-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-05-04-2017   Detroit Speed 1987 Camaro Test Car 2.0-dse-05-04-2017
Old 05-04-2017, 09:26 AM
  #193
Engine: 388ci LS7
The bedliner is UPOL Raptor and is a spray-on application. Before applying the liner, everything is prepped then sprayed with epoxy primer. As far as all of our paints/primers/clears we use PPG Refinish.
Old 05-04-2017, 09:46 AM
  #194
Engine: 388ci LS7
The wheels are Formula 43 RAD5's. Formula 43 is no longer in business, so these wheels are unfortunately out of production.
Old 05-04-2017, 12:20 PM
  #195
Engine: LS3
Hey DT, thanks for filling us in on coatings used!
Great to see the build moving forward. I think I will try the bedliner in the wheel tubs too. Great idea. Even better execution!
You guys are using a stock K-member correct? No faith in the aftermarket units? Or do you see them as not needed? Just curious to learn a bit more about the reasoning.
Thanks.
Old 05-04-2017, 12:59 PM
  #196
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Old 05-04-2017, 04:18 PM
  #197
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Detroit Speed 1987 Camaro Test Car 2.0
I love that rear spoiler.
Old 05-04-2017, 04:44 PM
  #198
COTM Editor
QwkTrip's Avatar
Car: '89 Firebird
Engine: 7.0L
I've been looking for wheels for 5 years and the one my eye finally catches isn't available any more. If you could say they were super expensive then it would at least make me feel better.
Old 05-04-2017, 05:06 PM
  #199
Ty92Z's Avatar
Car: 1992 Z28 1991 RS
Engine: LB9 LO3
Transmission: 5 speeds
Is that a Hawk's 5" spoiler. Fits really well. How much massaging was needed?
Old 05-05-2017, 07:28 PM
  #200
M G Brewer's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77
That car already has like $15,000-$20,000 in it just the way it sits.
Quick Reply: Detroit Speed 1987 Camaro Test Car 2.0
