Detroit Speed 1987 Camaro Test Car 2.0
#451
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
#452
Re: Detroit Speed 1987 Camaro Test Car 2.0
I'm wondering how the Tilton pedals fit around the stock steering column? Did you use the stock column?
#453
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I just went back and read through the thread again and caught a few things I missed the first time around. I see the extra work that was done to give more crossmember clearance for the dry sump scavenge lines.
Are you running an internal oil pump but just the external scavenge?
Is the rear axle a full float housing?
#454
I love this thirdgen! It really has me wanting to buy another one to build.My very first car in 1999 was a 90 Camaro. I had so many good memories with that car.
I did not see it mentioned and wanted to ask. Any reason you did not use a tubular k-member in the front? Are the tubular k-members not strong enough?
I also noticed you have seats in the rear. Any photos of how you modified them to fit with the 4link?
Is the wiring all custom or did you buy a kit? Would love to know more about how its wired up.
#455
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Also, DSE doesn't make a tubular k-member for our cars so I don't think they'd want to use a competitors in their car which is showcasing their parts.
dennisbernal91z (01-26-2023)
#457
#458
From the build photos on the DSE website, the 4link doesn't intrude very far into the interior and the seats will go back in without any real modifications. The main reason many track cars don't have the back seat any more is the cage makes the rear seat unsafe to use and, depending on who did the cage, may interfere with the seats latching in place.
