Brought an 88 home today..
#251
Re: Brought an 88 home today..
I agree I don’t like gloss as much. I scored almost a full gallon of this for (I think) $5, maybe $15 I can’t remember.
https://tcpglobal.com/products/kus-hrf201-qt
im a little afraid it would be a bit too flat for me though. I’m going to spray the grill with it first to see how I like it.
#255
So, last week I picked up a shell and I have to paint the whole thing, which is not a problem. I just need to know how much primer and paint I will need to paint the entire car inside and out. I am going with the original dark blue color.
I also need to know the best way to strip the paint off of the bumper covers front and back as well as the ground effects. If anybody can help me out that would be great I just want to do this all myself. But, I want to do it right.
#256
Primer amount is really hard to say. Hell even paint amount is hard to say, different brands will cover better or worse and have different mix ratios. I can tell you it’s a full gallon of the base I used and more than a gallon of clear.
if I was doing it again I wouldn’t completely strip the car unless it’s absolutely necessary. If you only need to strip the car down to metal in a few spots you’ll save on whatever primer you use for DTM.
I can tell you it probably cost triple whatever I thought it would cost. All the materials add up and prices have double in the last year or so.
#257
sorry I’m just seeing this.
#258
Thanks for your reply, I want to also try and keep the costs down. What's good for stripping the Ground Effects and both bumper covers? I want it to look as professional as I can get and just painting over, what I think is, 3 layers of paint won't do. I know it needs stripped.
if you want to completely strip the bumpers I’d do one of those. Heat gun method is not fast though, and chemical stripper is very weak now days. If you use stripper, apply the product then cover with plastic sheeting so it doesn’t dry up. Even with chemical stripper you’ll probably need to finish stripping with sandpaper.
as far as materials, if you’re stripping to metal I’d start with a galling of epoxy and a gallon surfacer. I used summit racing for the most part for primer, it’s cheap and worked well.
#259
this first receipt is pre-covid cost for 1 quart of surfacer+hardener.
this 2nd receipt is the exact same purchase from a few months ago. Pre covid price for my base coat was $250, 3 months ago they wanted over $400 for a gallon of base only.
#260
I’ve used chemical stripper (aircraft) on plastic parts with no problems. I also used a heat gun and a razor blade to remove paint on my plastic bumper. I mainly did this so I didn’t dust up my shop.
That's nuts
#263
I’m going through a divorce so I’m not living where the car is. Haven’t been able to do much but it’s looking more like car…anyone ever mount a hatch solo? Sketchy situation
I’m having trouble getting the hatch to actually latch. Will have to do some adjusting.
#265
I actually installed the hood the same way.
With everything that’s been going on I haven’t taken pics but I painted the door handles, hatch trim, and hood latch parts with the same hot rod black I used on the grille. I still need to paint the gas cover, 1/4 panel ground effect, and mirrors.
Billgluckman (01-07-2023)
#267
I drug the car out to try to get it put more together. It’s running rich as hell for some reason, I’ll have to check into that.
so right now the interior isn’t finished and I still have a lot of work to do but I’m curious how people are valuing these cars with ls swaps? I may end up selling it once it’s road ready, I really don’t know.
#268
Engine: LB9 305
Transmission: AT
The paint looks very nice, in the Photos, "Billgluckman"!
Some questions, Who did the paint? Type of paint? Were the mirrors, door handles and rocker ground effects(GX) removed? If so, How was the rear most nut, in the rocker panel GX removed? I spent 40 minutes trying to remove the rearmost nut, with negative results!
#269
and yes I removed all the ground effects…I’m not sure what the issue is on that but, it should be pretty straight forward. The only tip I can give you is maybe you need to pry the nut while you turn it so maybe it will grab and come off. I assume you are talking about the little “speed nuts”?
#270
I think that nut is mostly an issue on the verts. Not so much with coupes. At least on my 84 it was way easier to remove. Probably due to the reinforcement on the verts anyway.
I think an ls conversion on a base Camaro can't hurt the value too much, if at all. Less that base car was flawless. It's on the irocs/z28s, especially if they are well optioned and/or with TPI that you can somewhat hurt the value/appeal quite a bit more often than not.
#271
I don’t want to sell the car, and refuse to until I fix some things, but it may happen. I definitely have to cut and buff the paint, install a windshield, and get tires for the matching wheels(c6 wheels). I would think those things would make a big difference vs sell it it “as is”
Billgluckman (08-11-2023)
#273
Engine: LB9 305
Transmission: AT
***EDIT*** Not to Hijack, what about Subframe Connectors?
I started my own thread ,in the TGO "History/Originality" section, containing the above question. I don't want to encumber the OP's Thread. Mike Celi
#277
#278
Billgluckman (12-03-2023)
#280
I have a real nice pair that I thought about selling on Ebay. Then I realized that between Ebay's fees and the IRS I'd pretty much be giving them away so I made some wall art with them. Turned out pretty neat at that:
#281
tom3 (12-05-2023)
Billgluckman (12-17-2023)
therckid
08-29-2012 04:50 AM
