Pro-Touring , wide Tires
Car: 87 iroc z28
Engine: 89 C4 TPI ,
Transmission: ZF6 speed , 89 C4
Axle/Gears: 89 corvette rear end
How many 3rd gens have stuffed 335 or 315 tires out back, not slicks , (inside quarter panels ). Great for Pro-Touring !!!
Re: Pro-Touring , wide Tires
Ive heard of people doing it but they usually have air shocks and they will always stick out past the wheel well. I had 275/60/15's on my rear end and it looked awful.Theyre street/strip tires and they stuck out a good 4-5 inches past the panel. and it rubbed with new suspension
I don't know if this guy is on this forum, but his user name on LS1tech is 'LS1-IROC'. His IROC has 18 x 9 wheels with 265-35-18 tires on the front, and 18 x 12 wheels with 335-30-18 tires on the rear. His wheels were custom made to look similar to the original IROC wheels. Also, his car's rear was mini tubbed to make the rear wheels fit properly.
Boys and girls... THIS is how a proper larger wheel and tire setup SHOULD be done!!!
I tucked a 27.4" tall 305 series tire on my car with no issues other than beating the snot out of the inner front wheel well for clearance. 19x10 wheel. I believe 315's can fit same way. I have a set of 315/35/17 on my ls1 car that i wanted to mock up. They look good on the ls1 car, nice and wide
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
These are 10.5" rims with a BFG Drag Radial. 4th gen rear axle and these rims were made for a 4th gen, probably 7.5" backspace give or take. My car has seen a BFH many times and I have sanded my bumbstops flush. They didnt rub but i used a 9/16" spacer just to be safe, I may be able to take them off. They sit almost flush with the fender lip, maybe stick out 1/4" with the spacers in.
A 10" wide rim with a Nitto Drag 315 is a great street setup, it's probably an inch or more narrower than my BFG 315 tires.
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
If anyone cares, the owner of the white Iroc is on this board: 406TPI. He's up for COTM nomination if you guys care to check it out/learn more about his awesome setup.
https://www.thirdgen.org/forums/auto...minations.html
COTM Editor
There is some amazing example of cars in this months line up! Get ready to vote on them today!
Oh man, so many perfect examples this month that it was almost impossible to vote!
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
Bohemian
Aftermarket Product Review
11-25-2015 09:38 PM
