My new $300 86 Iroc-z28
#453
Re: My new $300 86 Iroc-z28
So you're the one who has been picking the goodies off of them LOL!
I feel for you right now man this weather has been nuts. I've upgraded to a heated garage and still haven't accomplished the amount of wok you have lol! Keep up the good work and maybe by next summer my damn car will be done!
#454
1 Post
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
uh yes sir yes I have lol yeah its been cold and still have no heater and the garage is detached with no insulation very cold and if you need help would love to anytime. Around tax time ill be on the hunt for a t56 may insulate the garage to, not for sure.
#455
I'm working on the interior right now, but when I comes to motor time I'm going to need all the help I can get lol! A lot of my funds seem to get diverted to home projects now since I bought a house with a bigger garage. Soon she will be in running condition.... soon.
#456
1 Post
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Pics pics and more pics
Cleaned both the garages
Box of goodies- tr55 plugs, new o2s, new iac/tps, new alt, new dayco belts.
Very happy with how the interior came out and shiny everything is minus the primer lol
#459
1 Post
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Alright update first the harness I bought was wrong was from a 98 corvette so sold it and bought another harness from a 99 camaro also bought a amp seems and looks new got it extremely cheap
edit ditching the idea of halos all together
#460
1 Post
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
Are those the halos that go directly onto the headlight housing? I recently saw some just like that in person and I did not like the look at all.
I would just go with the BMW headlights...
#462
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
halos IMHO are completely pointless. and incredibly blinding to other motorists. my logic (if you can't see enough of the road to drive safely with the factory headlights or equivalent [silverstar bulbs ect ect] then you don't need to be driving)
#463
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
HID's are what blind other drivers, only because people decided its a good idea to use them in fake projector housings(no control of the light output) or without projectors at all
when done properly with real projectors, HID's make a world of difference driving at night, and will not blind oncoming motorists, they also aren't cheap
#464
1 Post
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Yea already took em off. Deloomed the engine harness and laid it out in the engine bay today also hooked up the amp to make sure it works which it does very happy with it. As far as headlights go I dont know what i will do maybe stock, e36(halo/non halo), projectors, aftermarket housing(black/chrome)... so many options. Already have the clear smoked housing side markers and will be getting the clear black turn signal housings so food for thought....
#466
1 Post
Engine: LB9|TPI
I don't think you understand the difference between standard and "Halo" housings, halo's are only on when the **** is pulled out one click, the "halo" is around the outer edge of the glass, once you turn the headlights on, the halo's are not visible any longer(on your typical setup)
#468
1 Post
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
The idea for this was a more modern 86 in terms of interior comfort, drivetrain, and ease of swap huge reason why I went with 4th gen wiring made everything simpler for me. Then there's the led lighting, temp/comp mirror etc. I've owned two other stock 86 camaros one sc and a Iroc so with this one I wanted something different.
Thank you have put a lot of work into this build to make it everything I want
Bit of progress got the stereo system wiring finished up really need new speakers the ones I had laying around are blown.... Got the rear hatch wired up got the ecu mounted where I want it and will be tucked out of the way best as possible. Also got my seats put back in I think that's all for now
#469
1 Post
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Update and some news........
First buddy I work with had a flip out he gave me which is awesome its pretty basic but has dvd, usb mp3 port, bluetooth, sub output so works for me need to fix the rubber stripping on the screen heres pics
Secondly... found out wife is pregnant so project will be set back hopefully not the back burner but progress will probably slow
#473
Car: 82 Camaro Lots of mods
Engine: Blown 355
Axle/Gears: 3:73
Your doing a great job can't wait to see it finished!
#474
1 Post
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Really been almost a whole month with no update weathers been crap and works been crazy working at both autozones without a day off but little bit of an update got some founders spherical double adj lca's for $20 less than 500 miles, got all new locks for the doors and hatch. Other than that been gathering parts for the motor, suspension, brakes will run the stock 3rd gen rear and brakes till after I get it running then will do the brake and rear upgrade to a 4th gen setup
#477
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
So just ordered this
http://m.ebay.com/itm/220885157632?nav=WATCHING_ACTIVE
#478
1 Post
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Oh I know I have a plan for them just need them for the housings if you've been following withe the modern theme you'll know
#479
1 Post
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
So plan is as follows motor is out of the car and finally have a day off with nice weather so want to clean polish the heads put the car in the air clean and undercoat the trans tunnel after that head to Upullit to see if I can find a hvac box if not will be rebuilding the front steering/suspension and cutting the front coils car has set for quite some time with the motor in place and it's horribly high oh and headlights should be here today as well don't know that I'll do anything with them till I get all the other stuff I need for them will update tomorrow with pics
#480
1 Post
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
So............ changing plans going auto so now for sale the pedal assem and a brand new clutch master simply doing this for cost and reliability also have almost everything I need to rebuild the front steering/brakes/suspension also got the motor adapters(wrong ones) so monday i have to go get the right ones. Believe thats all for now
#481
1 Post
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Update bye bye stock rear end went and picked up a 4th gen rear from a 99 ss also got the aluminum driveshaft and torque arm paid 275 for all of it next fri will have a steering column coming. That is all.
#482
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
your making good progress. looks good!
#483
1 Post
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
motor mounts on, torque arm cleaned up, gauge assembly with led's, started to clean the grime off the trans tunnel and wow that stuff sucks to get off killed my drill twice fully charged both times also got my afterburner third brake light wired up video below
#484
1 Post
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Just bought a 4l60 for $350 specs are Built by monster transmission. stage 2 setup with b&m shift kit and Hughes performance 3k stall tq converter. 2k on rebuild getting closer
#485
Where do you find this stuff? Lol...
#487
Car: 1991 Camaro RS
Engine: LO3
you have the best luck anyone in the world has finding parts for good prices, lol.
#489
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
The build looks awesome. It's nice to see a car so far gone being restored. I'm not a big fan of the fourth gen interior, though.
#490
1 Post
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Thanks and I know its not everybodys taste but its something I plan on keeping forever and I liked the challenge of doing this and being different with everything ive done to the car and im happy with how it looks
#493
im putting a 91-92 z28 high rise on my camaro and iv been looking for 91-92 glass rear in PERFECT condition with the third break light built in and its been hard finding one around here, but if i can just use my 87's glass (which is perfect) and add my own custom third light seems likes a good option for me
#494
1 Post
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
can you tell me a little bit about the 3rd break light setup and maybe a few pictures..
http://www.autozone.com/autozone/acc...er=327402_0_0_
#495
1 Post
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Update ive bought alt and powersteering brackets have a new ls1/a4 harness on the way steering column should be here tomorrow also buying a fuel pump assembly tomorrow for lol $25 also getting pre-bent fuel lines that is all
#496
nice! looks good!
#497
1 Post
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Starting to look more like a motor lol
Anyways column and alt bracket came harness should be here soon also just bought a set of 241 heads for $150 little over 20k on them!!
