58mark's restoration thread
Old 09-18-2011 | 05:09 PM
  #351
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Axle/Gears: 3.23 posi
Re: 58mark's restoration thread
Mark--Cool. My buddy who's building a V8 S10 will be with me; now he wants a 3rd gen. I'll check again in about 10 days. Meanwhile, stripes...very interesting.
Old 09-18-2011 | 05:13 PM
  #352
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Originally Posted by travis401
Def want it on the raod before the fair, thats not an impossible task right?
Nothing is impossible if you have got the determination!
Old 09-18-2011 | 05:20 PM
  #353
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
i do, just not quite the amount of free time i need. and my problem is ive been holding off on painting the hood till i found a welder...i need more room under there. so now that im picking up the welder on thurs, the hood us going under the knife . other than that its all minor stuff, and i keep adding things to my plate. like the new parallel flow condensor....
Old 09-18-2011 | 07:40 PM
  #354
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
Originally Posted by 58mark
the striping project so far... I was planning on painting in two weeks, but I may bump that up to next sunday.
I really like how the outside corners look rounded and the inside corners look squared off. When I get around to painting my orange or red stripes on mine i wanna do them like that.
Great job on the whole car bro
Old 09-18-2011 | 07:44 PM
  #355
one92rs's Avatar
Car: SOLD!!!!!
thats going to be really nice bro. damn i need to start my ls1 swap so we will both have something to show next year/
Old 09-18-2011 | 08:35 PM
  #356
58mark's Avatar
thanks, i was waching Mecum this weekend and saw a vintage chevelle done that way, and I know 5th gens are that ay, so I figure if they can do it so can I. LOL
Old 09-18-2011 | 08:36 PM
  #357
58mark's Avatar
Man, your car is already impressive!
but that Ls1 will be freaking sweet. t56 with it?
Old 09-18-2011 | 08:58 PM
  #358
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
I really like the layout, but that tape won't hold its shape for more than a couple days.....if that. I hope you plan on painting it sooner than later. You'll find that the inside corners will start peeling up.
Old 09-18-2011 | 09:07 PM
  #359
58mark's Avatar
Oops. I can't get the compressor back to the house for a week. If that happens, ill just have to redo those parts
Old 09-18-2011 | 10:10 PM
  #360
58mark's Avatar
wow, inner corners already lifted... I guess I know not to fix it until right before I paint.
the blue tape stuck, the green lifted. I think I need to go get a thinner roll of blue. like 1/8th instead of 1/4"
Old 09-18-2011 | 10:36 PM
  #361
travis401's Avatar
Car: 91 Camaro RS
yea, the green 3m tape makes some nice sharp lines, but just doesnt hang on very long.
Old 09-18-2011 | 10:46 PM
  #362
58mark's Avatar
wish I had known that earlier. Maybe the stuff I put on without curves will hang on. I don't mind redoing the corners, now that I have my technique down.
Old 09-19-2011 | 07:10 AM
  #363
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Wow, only lasted an hour? I figured you had more time than that. 1/8" is more manageable for the corners.
Old 09-19-2011 | 07:13 AM
  #364
58mark's Avatar
well it was a few hours...
I used 1/16th green on the tight corners, but it was hard to handle. I'll change to 1/8th blue (couldn't find my roll, darn it, gotta buy more)
I'm also thinking of resanding my headlight buckets and do those again as long as I'm spraying satin. I wasn't happy with how they turned out the first time
Old 09-19-2011 | 01:00 PM
  #365
58mark's Avatar
re did it with the 1/8th blue. That stuff takes corners like a ferrari...
hopefully it will stick for a week. I know the picture looks crooked, but that's because the edge of the green tape under/behind the blue can't be seen that well. it's straight
Old 09-19-2011 | 01:04 PM
  #366
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Looks good.
Old 09-19-2011 | 01:10 PM
  #367
58mark's Avatar
as much as I'm still mad at myself for wasting the time and money on those vinyl stripes, some good did come of it. Before I laid down the vinyl I trimmed the heavy plastic backing paper that was stuck to one side of it to less than 1/16th of an inch to the edge of the stripe. when I pulled away the plastic, it left me with a really nice template that I could use for creating my own painted on stripes.
The front edge of the plastic didn't have the right angle to it, but a nice wide piece of tape stuck to the hood took care of that
I still have the plastic, and have told a friend he can use them whenever he wants to paint stripes.
I wonder if there's a market out there for heritage stripe templates?
Old 09-19-2011 | 01:22 PM
  #368
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
If there isn't....there should be. Vinyl is for houses.
Old 09-24-2011 | 09:07 PM
  #369
58mark's Avatar
here we go again... hopefully this is the last time I have to buy drop cloths for a while...
painting monday!
Old 09-24-2011 | 09:54 PM
  #370
jimmy_pop15's Avatar
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
it looks shiny still. You plan on scuffing it?
Old 09-24-2011 | 09:56 PM
  #371
58mark's Avatar
yep. I'll do that either tomorrow night or monday before I paint.
by the way, I've changed my mind from satin to gloss back stripes...
Old 09-24-2011 | 10:00 PM
  #372
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
I know you don't wanna think about re-doing the whole thing, but there's a trick I'll tell you about. If you lay the rough tape work first, then do the detail on the edges of the stripes with the fine line on top, then as soon as you're done spraying you can peel off the fine line and it'll give the fresh paint edges a chance to lay down and you won't feel the tape edges as bad.
Old 09-24-2011 | 10:06 PM
  #373
58mark's Avatar
that's more or less what I did. I can remove the closest edge of the tape without disturbing the large areas of paper and plastic
Old 09-24-2011 | 10:32 PM
  #374
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
still lookin good mark, your car always has
Old 09-26-2011 | 03:23 PM
  #375
58mark's Avatar
Old 09-26-2011 | 04:09 PM
  #376
texascat2's Avatar
Car: 1989 Forumla 350 WS6
Engine: 5.7 TPI:Bosch III's 22#'s
Transmission: 700-R4
Axle/Gears: BW 9 Bolt Posi- 3:27
LOOKS GREAT!
Old 09-26-2011 | 04:13 PM
  #377
58mark's Avatar
thanks! It's not good enough to leave it as is...(of course, my garage is terrible for spraying) so i'm going to have to wait a few days, sand it smooth, and the buff it glossy again. The nice thing is when I'm done I should have mirror finish black stripes.
I'm pretty pleased.. there's one part where the tape must have come up funny on the stripes, it looks a little sloppy. not sure what I can do about that. maybe tape off the good part, sand the sloppy part with 1200 grit sandpaper, then buff everything. I'll have to experiment
Old 09-26-2011 | 04:17 PM
  #378
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Mark it looks awesome! You did a great job.
Old 09-26-2011 | 04:24 PM
  #379
texascat2's Avatar
You'll figure it out, you always do!
Old 09-26-2011 | 04:28 PM
  #380
58mark's Avatar
thank you both!
Old 09-26-2011 | 04:36 PM
  #381
texascat2's Avatar
Old 09-26-2011 | 05:32 PM
  #382
one92rs's Avatar
Car: SOLD!!!!!
no going to go with a built 4l60. my buddy can build them in his sleep. just need the parts. he is also going to help set everything in.
payment--my current engine and trans with all parts to put in a 50 something truck.
by the way those stripes look good.
Old 09-26-2011 | 05:41 PM
  #383
58mark's Avatar
thanks, I'm glad I went to the trouble to do the heritage stripes, instead of just straight stripes like I used to have.
one thing that I think is interesting is how fast this prospray single stage dries. I've used single stage before, and it still felt sticky hours later. this stuff was dry to the touch after an hour.
If it wasn't for a little trash in the paint, I would be tempted not to sand and buff it at all, it came out really smooth
Old 09-26-2011 | 06:06 PM
  #384
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Axle/Gears: Built 4th gen 3.42 posi/disc
WOW, it came out great. Well done Mark.
Old 09-26-2011 | 06:55 PM
  #385
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
you're gonna sand and buff single stage paint? hmm, never tried that before. Lemme know how it turns out.
Old 09-26-2011 | 06:56 PM
  #386
58mark's Avatar
oh yeah, you can buff it just like clear. only with non metallic paint though...
Old 09-26-2011 | 07:54 PM
  #387
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Looks good Mark.
Old 09-26-2011 | 09:53 PM
  #388
kmcn47's Avatar
Transmission: 5spd
Originally Posted by texascat2
LOOKS GREAT!
agreed
Old 09-26-2011 | 10:10 PM
  #389
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
Looks awesome Mark. Great job.
Old 09-27-2011 | 07:06 AM
  #390
58mark's Avatar
well after all the excitement about getting the factory stereo with the mp3 input, last night when I turned it on it had horrible static coming out of the right rear channel, and it wasn't like satic caused by a weak signal. It was only out of the one speaker, and it wasn't controlled by the volume ****. the only way to shut it off was to put the old stereo back in. Guess it's a problem that didn't present itself until the stereo was on for a while.
and of course, I'm past the 7 day return period, so I'm out of luck. bummer
Old 09-27-2011 | 03:49 PM
  #391
one92rs's Avatar
Car: SOLD!!!!!
damn that sucks dude.
Old 09-28-2011 | 10:26 PM
  #392
kmcn47's Avatar
Transmission: 5spd
hmmm post this in the stereo board they'll sort you out this site usually does hope you can get it sorted
Old 09-29-2011 | 08:58 PM
  #393
58mark's Avatar
here's the stripes... fully sanded, compounded and polished.
just have left some general cleaning of nooks and crannies left, get some dust out of the interior, and one more upgrade that is secret for now.. that will happen monday... LOL
Old 09-29-2011 | 09:14 PM
  #394
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
That looks great dude. Very well done.
Old 09-29-2011 | 09:20 PM
  #395
kmcn47's Avatar
Transmission: 5spd
damn............wanna come to ohio and paint my car? lol cant hurt to ask
Old 09-29-2011 | 09:28 PM
  #396
58mark's Avatar
I think it will be a long time before I tackle another job close to this one. I'm just glad to be almost done.
Old 09-30-2011 | 04:59 AM
  #397
texascat2's Avatar
Turned out great!
Old 09-30-2011 | 10:27 AM
  #398
lonestar7's Avatar
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
It looks great Mark! When you get the final detailing done, take some daytime photos outside and post them. I'd love to see it in the sunlight.
Old 09-30-2011 | 10:34 AM
  #399
58mark's Avatar
State fair is in two weeks, i'm going get tons of pics
Old 09-30-2011 | 03:54 PM
  #400
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Looks great man! Mines next(:
Whered you get that rear window decal?
Quick Reply: 58mark's restoration thread
