58mark's restoration thread
#201
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: 58mark's restoration thread
just got done spraying the clear... kind of
there's bunch of trash in the horizontal parts. Not sure where it's coming from, but I guess it's typical of a garage paint job. on the last coat, these things started appearing. Not sure if they are bubbles or drips, I think drips from the gun. I hope so. I'm going to wait a day or two, sand them down, and then apply another coat or two of clear over the top of them and hope new ones don't appear. If they do, I'll have to just sand them and polish it out the best I can. there should be plenty of clear on the roof and hood to do that
this has been frustrating, lots of little things have gone wrong, including finding some spots that I didn't get dents out completly, that only showed up when I sprayed clear. that's frustrating because I thought I did everything right, including using high build primer and long snading block to block down the car
#202
basically, in the spots that didn't get the drips and trash, I think it looks great. hardly any orange peel. I jsut hope this is something I can fix
#203
1 Post
Car: 91 Z28
Axle/Gears: Stock
Anything can be fixed. There will always be "dirt". For a garage job, it looks like you're doing fine.
#204
thanks, I needed that
couple pics from today
#205
Car: '82 Camaro
Transmission: wc T5
Axle/Gears: 3.23 posi
With no experience, I can only watch, read and learn--taking the defects out of the clear is a whole different task, from what I've read. The learning goes on.
I've customized a couple of nice motorbikes, concentrating on details so hard for so long that when it's all together it's difficult to see the whole bike--you keep looking at tiny details while others are praising your work. One, a Triumph 650, I sat on the floor so long working on that when I finally started it and timed it, I grabbed the exhaust to pull myself up out of habit--that handprint burned into the new chrome permanently--ouch. I think your paint looks excellent--you'll work it out.
#206
1 Post
Car: 91 Z28
Axle/Gears: Stock
Without seeing it in person, it appears that you've done a fine job of distributing the metallic. I don't see striping or blotching. It'll need some finish work for sure, but it appears the hardest part is over. You're on track.
#207
I had some similar runs/dirt when i sprayed my car. I had a buddy who paints cars come over to look at it, and he waited till the clear was pretty much cured (95%) and then put blue painters tape on the clear around the drips, and then scraped the runs off with a brand new razor blade. It got the runs down to almost level with the good clear so it would much easier to sand the runs/dirt out. Your clear has WAY less peel than mine I'm gonna sand my clear down then lay more clear one of these days....
#208
here's some better pics, ones that don't show the negatives. if it wasn't for the trash and drips, I'd be tempted to not touch it as far as sanding and buffing goes. not a lot of orange peel there
#209
check out these pics. I clear coated my taillights after I sanded them with 800 grit paper. I think they turned out fantastic!
#211
Wow Mark! Those lenses look way better than new!
#212
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
Yeah they look like just drips. Did it only happen on the horizontal panels, where the gun would be over the work? Like sail said, use a razor blade to cut it down level. put a piece of tape on the two corners of the blade, then hold the blade vertically (perpendicular to the panel) then with very light pressure let it drag across the drip spots. it should turn white. if it doesn't the clear isn't dry enough. then just keep dragging it lightly until you can't see and feel the spots. then block wetsand with 1000, 1500, 2000, then buff.
BTW those taillight do look better than brand new already, wait till you buff em. Yea buddy!
#214
thanks to everyone who suggested the razor blade trick, it worked like a charm. I used one of these to avoid the temptation to flex the blade, and it gave me better grip and control. got it at wal mart with a pack of replacement blades
#215
Car: '83 Sport Coupe
Engine: 360
Transmission: TKO-500
Axle/Gears: 12 bolt 3.73 TrueTrac
I would probably never attempt an at home paint job, but I must say you are doing fantastic work. I always admire someone who pays such close attention to detail and preparation. I myself can become very impatient at times, and it is always nice to step back and take example from others who go about doing things the proper way, not necessarily the PAINLESS way.
The whole car is looking great, but I must say those taillights look amazing! I am watching...
#216
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
looking like your cars gonna be amazing mark, nice job, wish i had the time/money to do mine up nice
#217
1 Post
Car: 1989 Camaro RS--
Engine: MPFI
Mark the tail lights look amazing! I wonder if the clear coat in the aerosol would work as well? You are really doing a nice job on your car
#218
I would doubt an aerosol system would be thick enough to give it that depth. I really laid it on and let it flatten
ok, update time
sanding down the car now. going to go 600, 1200, 2000, and then polish
Questions for Haps or anybody else, can you tell me what compounding system you prefer? I've use 3M, but I also hear good things about the meguiar's M105/205 system
I have a makita buffer, so I'm in good shape there
ok, update time
#220
1 Post
Car: 91 Z28
Axle/Gears: Stock
Only ever used the 3M Finesse It system. I really like it.
Edit: Make sure to take up those edges. Don't want to burn through if you haven't had a great deal of time with the buffer.
#221
I used it with the 58, but I'm still fairly new.
how much overlap of the edge do you give it? right on the crease?
#225
just as an experiment, I just tried this with a new wool pad I already had
http://www.amazon.com/3M-Automotive-...2583644&sr=8-1
wow! it looked great! do great it showed some flaws I didn't even see earlier.
how does the perfect-it system differ from the finesse it system?
#227
1 Post
Car: 91 Z28
Axle/Gears: Stock
If you go here, you'll see the Perfect It series is "the best" but I'm not sure why. In addition, I'm not sure of the steps.
#228
by the way, I wasn't ignoring you with what you suggested, I just tried something I already had on the shelf. Still interested in the finesse system if it suits my needs more
#229
thanks for that! I was impressed at the results with the wool pad. a few seconds, and I had a HIGH shine
#230
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
I've never wasted time taping edges. just make sure the pad spins away from the edge
#231
I got in that habit when I did the 58. when you get near an edge, go over the cliff, not into it
#232
I couldn't help myself... I took a few shortcuts and broke out the buffer. this is after 400 grit, then 1200 grit on an electric sander, and then buffed with compound. No wet sanding, no polish
it's not perfect, but it's encouraging
#233
Looks great! You can see the cord from the light!
#234
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
Yeah it always buffs so much easier when it's that fresh looking good can't wait to see the whole car done.
#235
1 Post
Car: 91 Z28
Axle/Gears: Stock
#236
cool, The 05973 was recommended to me when I was shooting lacquer on the 58, nice to know it's good for clear too, because I like it
#239
i hope so! I'm a teacher, and go back to work soon. once that happens, it will be hard to find much time to work on the car.
no big updates, just black sanding the dust and drips out of the clear. I might be ready to start buffing by the end of the week
#240
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
It looks great! Just a slight thought...you used a 1.5 tip for the clear right? Im no expert at all, but do you think that because the tip was 1.5 it caused some drips? I think I see most people say they use 1.3 to 1.5 ish for base and a 1.3 or so for clear?
#241
the clear I was using called for a 1.4 tip, but it sprayed beautifully with the 1.5 LVLP
I found the problem, and it was with the cleaning of the gun, I need to break the gun gun down totally and clean it part by part before I spray anything else. With the cap off, and pushing thinner or reducer through the gun, it was spitting instead of spraying. It didn't look that much different when the cap was on, but I'm sure that has something to do with the problem. I still stand by the quality of the gun, but apparently not the quality of my ablilty to keep it clean
#242
#243
live and learn... I don't see how people break down the guns between coats if you are recoating with flash time of 10 minutes. I was waiting 30, and I still felt rushed
#246
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
if it's spitting it may just be from not having the tip tight enough. with the gun all together and the top off with some thinner or something in it, pull the trigger so just air comes out of the tip. if you see bubbles in the thinner in the cup then the tip's not tight enough and that would be why it's spitting
#247
it was spitting when the cap was off it totally. when the gun was new it had more of a controlled spray when the tip was off it. I'm assuming since the pattern changed something is blocked on the inside.
#248
Car: '82 Camaro
Transmission: wc T5
Aha! Significant Other just got her Principal's Cert., schedules 1 hour per week to talk and laugh with me.
How do I link to that October meet? See you there with my shameful old paint.
#249
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
Cap and tip are two different parts. I'm talking about the tip, which is behind the cap. The cap comes off by hand, then you need a wrench to take off the tip. make sure the tip is nice and tight with a wrench
