front of bodykit scrape
I've noticed that a lot of people's 92 camaros have a scrape on the front of the body kit... most likely from steep driveways, it happens to me all the time...
i have two questions... is there any way to prevent this from happening other than not going up steep driveways? like a technique or something?
and also, has anyone put like a metal bolt or something to protect the plastic?
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
Re: front of bodykit scrape
its not just 92's most do expecially iroc-z's and later z28's i would belive since there (i think) stock the most lowest. i know if you are going in a steep driveway you will wanna go at an angle and of course slow but i dont know if that applies with speed bumps and whatnot. maybe you can get the clear bra on the lip so it protects it a little more? also a full front mask lebra protects it majorly and you dont cry everytime you go over a bump.
hmm maybe we should make this a gallery??? heres mine lol
there really isnt many scrapes exept for a few small ones, but having only 27k miles doesnt hurt either
Car: 1991 Camaro RS
Engine: 3.1L V6 Soon to be 3.4 :D
Transmission: Auto 4-Speed
My car is the king of this problem,
the previous owner put tiny tiny wheels so the front spoiler is just wrecked.
I got the idea of a rhino-lining like product and then painting over that for the underside.
Idk how that'd work it was just what i thought.
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
Appears to fit only because I got out of the car to take the picture. When I sit in the car it slightly scrapes when parking it in the garage.
Best solution I found is to only park in reverse. That way the nose scrapes, but only the underside takes visible scratches. To be honest, I always parked my cars backwards due to tighter turning circles.
1 Post
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
if you've ever had it on a flatbed, you'll probably have damage from the cable
if you've ever driven less than 100 feet behind another car you'll probably have rock chips
if you've ever driven if front first into a parking spot with a concrete curb in front of you you'll have a bent air dam and scratched up valence
if you've ever driven it onto a steep incline you'll have scrapes on the front center of the valence
if you've ever thrown an engine lift under the front of the car, dropped a socket while standing in front of the motor, or kicked it while bending over the engine, you'll have beauty marks for that
if it's lowered you will have most of that damage
Car: 1990 Camaro RS
Engine: 305 TBI
Transmission: 700 R4
my 90 camaro rs does this too..
u have to angle your car and go slow..
i fixed the problem by putting
20 inch american racing irocs..
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Mine scrapes alot as well and sad thing is, I kinda want to lower the front some more.
Car: 86 Iroc-Z
Engine: 305 (TPI)
Axle/Gears: i dunno lolz
My car has this
Previous owner had a very steep driveway...I even hit it when I was reversing it to take it out for a teste drive
1 Post
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
Solution; drive a Firebird. Lol. It seems this problem is much more uncommon with Trans Ams and Firebirds because of the overall stance of the car. Unless they're extremely lowered. Yet my air dam does still scrape on everything. And I'm only sitting about an inch lower than stock.
Car: 86 z28,89 iroc
Engine: 350 crate and ls1
Transmission: 700r4/4l60e
Axle/Gears: open diff stock/4th gen posi
if your driveing a camaro at least you can replace the ground effect if needed...but if you drive a gta or somthing like that you have to replace the whole nose....that would be unfortunate
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I don't scrape my lip even after lowering my car 3.5". It's all in how you drive it.
Engine: LO3
Engine: LB9, LB9
To a certain extent. But it's mostly technique. Take driveways at a 45* or greater. NEVER approach anything straight on. Idle up driveways and over speed bumps. I try to drive only on firmiliar territory. Drive slow when necessary, avoid crappy roads and pot holes. Plan your route before you leave. In fact, when I see a speed bump I will just park and walk. I mean our front lips are at least 5 inches off the ground, my GTI is less than 2 and I hardly ever scrape that.
1 Post
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
I used to have problems with this, but he's right. You really have to know how to drive it and you won't have any problems. I take most bumps/entrances/whatever at an angle to cut off scraping. You'll also need to take it slow so you can creep over what you're driving (entering OR leaving). I don't scrape anymore (or VERY rarily, and it's not the bottom of the lip moreso than the shield underneath the car and very slight at that). Just pay attention and you'll be fine.
I think the problem is that the nose is longer in front of the front wheels than most cars so even the slightest angled sidewalk/speedbump will scrape it, especially if you are low. The only way to solve this is like bglancer71 said, go on an angle so that the tire contacts the speedbump/sidewalk as early as possible, which will raise the front end of that car just enough to get the other front tire on it before the front comes into contact with it.. It's just a matter of doing this right everytime, but again it depends how low the car is. Mine scrapes slightly in the morning when the tires are cold and I'm actually higher than stock because of MOOG springs and 4th gen isolators. When I pull in after a long drive, the tires are warm and thus more inflated and it doesn't scrape, just barely making it!
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I commute quite often on a ferry to cross the Puget Sound and the ramp is more often than not set too steep for my GFX. Since it's more than one lane of traffic boarding or offloading, there's no way to turn and take the ramp at an angle. Instead, it's slow way down and still scape the nose.
Car: 90 Iroc
Transmission: 700r4 Built by- Speed Secrets
go over speedbumps as slow as possible ans at a slight angle if possible, same thing for driveways. yep gotta drive it like a slammed honda haha
1Aauto
Sponsored Vendors
08-26-2015 02:18 PM
