freshly painted engine bay, frame rails and wheel wells
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: freshly painted engine bay, frame rails and wheel wells
Just curious.. How did you get the tops of the strut towers to look so perfect and hide the spot welds?
Car: 1999 Z28
countless hours of body work, when i get home i can post some pics of the work underneath the paint. i tried to make the engine bay "smooth" without getting to out of control, most of what i did is subtle, if you didnt know these cars you would think it came factory this way. the corners of the rad support have been smoothed and rounded, welded up every hole that i didnt need, smoothed the frame rails, removed all the factory seam sealer and redid it to look a lot neater.
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Looks great, very well done!!!!
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Very nice!
AkDrifted
08-17-2015 07:45 PM
