new ride, has some nice options doesn't it?
Latest addition, 88 IROC 5.0 5 speed with Perf. axle, 4 wheel discs, 9 bolt, fe2 susp and more. Only 82K KM (not miles) all original. Originally a Canadian car. All original unmolested.
![](http://www.vettemod.com/forum/imagehosting/24a6b7e96d0807.jpg)
![](http://www.vettemod.com/forum/imagehosting/24a6b7e97f2ad5.jpg)
![](http://www.vettemod.com/forum/imagehosting/24a6b7e9b60306.jpg)
![](http://www.vettemod.com/forum/imagehosting/24a6b7e992f5e3.jpg)
![](http://www.vettemod.com/forum/imagehosting/24a6b7fc8a591a.jpg)
________________________
AR9: SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
A01: WINDOW, TINTED, ALL SHADED, W/S
A31: WINDOW, POWER OPERATED, SIDE
A90: LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
B34: COVERING, FRT FLOOR MATS CARPETED INSERT
B35: COVERING, REAR, FLOOR MATS CARPETED INSERT
B6Q: DECAL PACKAGE, 02
CD4: WIPER SYSTEM WINDSHIELD, PULSE
C41: HVAC SYSTEM, HEATER OUTSIDE AIR, WITH FAN
C49: DEFOGGER, RR WINDOW, ELECTRIC
C95: LAMP, INTR, ROOF, COURTESY AND DUAL READING
D34: MIRROR, VISOR VANITY
D35: MIRROR, OUTSIDE REAR VIEW
D7J: GEAR, SPEEDO DRIVEN
D80: SPOILER, RR END PNL
D88: DECAL, STRIPE, SPORT
E5Z: SPEEDOMETER ADAPTER (DELETE)
E7Z: SENSOR VEH SPD (DELETE)
E9Z: SPEEDOMETER KEY (DELETE)
FE2: SUSPENSION SYSTEM, RIDE HANDLING
GM3: AXLE REAR, 3.45 RATIO
G80: AXLE POSITRACTION, LIMITED SLIP
G92: AXLE REAR RATIO, PERFORMANCE
J65: BRAKE SYSTEM, PWR, FRT & RR DISC
KC4: COOLING SYSTEM, ENG OIL
K68: GENERATOR,105 AMP
LB9: ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
MK6: TRANSMISSION, MAN 5 SPD, B0RG WARNER, 2.95 1ST, O/D
MM5: MERCHANDISED TRANS, MAN 5 SPD PROVISIONS
NA5: EMISSION SYSTEM, FEDERAL, TIER O
NP5: LEATHER WRAPPED, STEERING WHEEL AND SHIFT ****
N33: STEERING COLUMN, TILT TYPE
N65: WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
N96: WHEEL, 16 X 8, CAST ALUMINUM
PB4: LOCK CONTROL, WHEEL
QDZ: TIRE ALL, P245/50VR16/N BL R/PE ST TL HW4
TR9: LAMP, GROUP
TT4: HEADLAMPS, HALOGEN, 4
T93: TAIL & STOP LAMP, SMOKED
T96: LAMP, FOG
UM6: RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS,
UQ1: RADIO PROVISIONS, FOR STEREO
U25: LAMP, INTR, RR COMPT, COURTESY
U26: LAMP, INTR, ENG COMPT, COURTESY
U29: LAMP, INTR I/P, COURTESY
U79: SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
VAN: ASSEMBLY PLANT, VAN NUYS, CA
VK3: LICENSE PLATE, FRT MOUNTING PKG
V73: ANTENNA, FIXED
WW1: APPEARANCE PACKAGE(WHITE), AERO #l
W62: ORNAMENTATION, AERO PACKAGE
X06: CANADIAN GROUP
Z28: MERCHANDISED PKG, SPECIAL PERFORMANCE
Z31: ADVANCE PRICE SHEET
Z49: EXPORT, CANADIAN MODIF MANDATORY BASE EOUIP
15P: WHEEL COLOR SILVER METALLIC (91)
40U: PRIMARY COLOR, EXTERIOR, WHITE (91)
6DB: SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7DB: SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
8NL: SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
82B: TRIM COMBINATION, CLOTH, MED DK GRAY (91)
82I: INTERIOR TRIM, MED DK GRAY (91)
829: SEAT BELT COLOR, MED DK GRAY (91)
9NL: COMPUTER SELECTED REAR RIGHTHAND SPRING
90A: STRIPE COLOR, ACCENT, TWO TONE, GOLD/DK AUBURN (91)
The red one is a 87 IROC 5.7 automatic
___________________________________
AC3: ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER
AG9: ADJUSTER, SEAT, POWER, 6 WAY
AU3: LOCK CONTROL, SIDE DR, ELEC
B18: ORNAMENTATION, INTR, DELUX
B2L: PERFORMANCE PACKAGE & ENGINE PACKAGE V8 5.7LPFI
B3W: ADVANCE PRICE SHEET
B4Z: IROC PACKAGE
B84: ORNAMENTATION, EXTR MLDG, BODY SIDE
B94: FENDER EMBLEM, Z28
B97: ORNAMENTATION, EXTR MLDG, LOWER ACCENT
C60: HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DD8: MIRROR I/S, R/V, LT SENSITIVE
DG7: MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
DK6: CONSOLE ROOF, INTERIOR
D08: PAINT, HIGH GLOSS FINISH
D42: SHADE, RR COMPT SECURITY
D6M: GEAR, SPEEDO DRIVEN
E72: BODY LENGTH, INCR I8 INCH
GW6: AXLE REAR, 3.27 RATIO
K34: CRUISE CONTROL, AUT0MATIC, ELECTRONIC
L98: 5.7 LITER V8 TPI ENGINE
MD8: TRANSMISSION, AUTO 4 SPD, THM 700 R4
MXO: MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NOD: ASSEMBLY PLANT, NORWOOD, OHIO
P20: HUBCAPS, WHEEL, STYLED
QDZ : TIRE ALL, P245/50VR16/N BL R/PE ST TL HW4
TR9: LAMP, GROUP
T96: LAMP, FOG
UX1: RADIO, AM/FM STEREO CASSETTE EQUALIZER
U21: CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
V73: ANTENNA, FIXED
YR1: SEAT,FRT CUSTOM
YS1: SEAT,RR CUST
YT1: BUILD UP DR & QTR
YT9: OPTION PACKAGE, FISHER FURNISHED PARTS
1A2: SEO VEHICLE, PUBLIC SERVICE
1HV: COMPONENTS OF IROC-Z PERFORMANCE PKG(CHEV)
1SC: PACKAGE, OPTION 03
6ZX: SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7ZX: SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
81Q: MOLDING COLOR, BRIGHT RED (91)
81U: PRIMARY COLOR, EXTERIOR, BRIGHT RED (91)
82C: TRIM COMBINATION, CLOTH, MED DK GRAY (C) (91)
86A: STRIPE COLOR, ACCENT, TWO TONE RED/GUNMETAL (91)
TR9: LAMP, GROUP
T96: LAMP, FOG
V73: ANTENNA, FIXED
X06: CANADIAN GROUP
B4Z: IROC PACKAGE
TR9: LAMP, GROUP
T96: LAMP, FOG
V73: ANTENNA, FIXED
YS1: SEAT,RR CUST
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
Re: new ride, has some nice options doesn't it?
congrats on a good find.. did you find it locally, or have it shipped to you?
Both came from the UK. In fact, the 2 C4 vettes in my album came from the UK too. The others from the US. It's faster to get them here, no tax hassles and the British pound dropped in value. Compared to a stable US dollar and high container fees and taxes over outside EU imports, the UK is my main fishing pond since last year ![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
I didn't even know it had a 9 bolt, perf. axle and 4 wheel discs. I knew it had AC delete, a 5 speed and some other tids and bits. A nice surprise for sure!!
I started wondering, if it wasn't for the electric windows & rear defog...wouldn't that have been enough deletes/performance options for a 1Le? Weren't there only 4 in 88? Ahh...just my luck LOL
Car: 88 Camaro Coupe - 99 Corvette
Engine: 305TPI - LS1
Transmission: A4 - A4
Axle/Gears: 3:73 - 3:15
verrrrrry nice!
1 Post
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
Thats an awesome car. Hard to believe you could find such a well optioned, clean, original Iroc overseas.
On a side note, just how rare are Irocs (and I suppose other Thirdgens) over in Europe? I just spent 4 months in London (with brief trips to Lisbon Portugal & Amsterdam) and I never saw ANY american sports cars with the exception of 2 newer Mustangs. I never saw a Corvette, or any gen F-body for that matter.
They are not that common and most of what drives around is junk.
Locally there are 4 that I know of, my 2, a buddies 88 5.7 hardtop and another buddies 92 5.7 GTA hardtop.
Vettes are a lot more common, I have a couple, my buddy too.
diana227vegas
07-08-2016 12:27 AM
