LS1 swap high fuel pressure 100psi
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
I'm getting ready to start my engine for the first time and primed the fuel system today. No leaks, but 100 psi of fuel pressure. Should be aprox 60 psi but I cannot figure out what's going on.
Racetronix fuel pump new
plastic tank
fuel pump relay good
Power at fuel pump good
Wix 33737 filter good (replaced my new one with another new one)
Russell classic hose
2 different gauges read the same pressure
Here's the car's build thread:
https://www.thirdgen.org/forums/memb...n-91z-ls1.html
What am I missing?
plastic tank
What am I missing?
COTM Editor
Received 1,921 Likes
Car: '89 Firebird
Engine: 7.0L
Re: LS1 swap high fuel pressure 100psi
Fuel filter has the pressure regulator in it and you no doubt plumbed it wrong
Car: '91 LS6/T56/9"
Engine: LS6
That was the very first thing I checked, just forgot to mention it in the post.
I physically traced the send and return lines from the tank to the correct ports on the filter. 3/8" input, 5/16" return.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Then there is a restriction in the return line. Did you remove the pressure regulator from plastic tank?
Car: '91 LS6/T56/9"
Engine: LS6
That was it. Pulled the regulator, Threw my original wix filter on and pressure is perfect. However, no start.......Troubleshooting now.
FASTERTHANUMARK
02-25-2008 08:49 AM
