LSx rotational drag
Old 06-30-2016, 05:21 PM
TGO Supporter/Moderator
TGO - 10 Year Member
anesthes's Avatar
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, LT1
Transmission: TKX, 4L60E
Axle/Gears: 3.42, 3.23
LSx rotational drag
So I bought this 5.3 the other day. I didn't pay much for it because I didn't hear it run. Has 130k.
Anyway, so I got it on the stand. I ripped the exhaust manifolds off, starter, accessories, etc. The kid left the torque converter on, so I went to remove that. I noticed I could rotate the motor by hand easily.
I took the torque converter off. I can grab either the flex plate, or the crank pulley with two hands and completely rotate the motor over.
Now considering everything I'm used to is a PITA to rotate even with a rotating tool that hooks on the flywheel, I'm kinda thinking this thing has very low compression?
Or it's got the lowest drag piston rings on the planet.
But since I don't know jack about LSx stuff, I figured I'd ask.
I paid $150 for this motor complete. I figure even if it needs a rebuild, that's a good price for a core.
-- Joe
Old 07-01-2016, 06:47 AM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Re: LSx rotational drag
My LS1 I know was running when pulled. It seemed pretty easy to turn with the heads on but I don't know that I could have done it by hand. With the heads off sure. After rebuild it was much tougher, but I also bumped compression and some other stuff.
Compression is a little lower on the truck motors, depending on the heads I think around 9.5-1. You sure the heads weren't off and not properly put back on or something like that?
Old 07-01-2016, 07:40 AM
COTM Editor
QwkTrip's Avatar
Received 1,939 Likes on 1,324 Posts
Car: '89 Firebird
Engine: 7.0L
It is easy to tun with all the plugs out. Just friction at that point, no compression.
Old 07-01-2016, 11:25 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Mine rolls over very easy with the plugs out. No problem grabbing the crank pulley and spin it over and it's a very low mile factory crate motor.
Old 07-01-2016, 12:21 PM
anesthes's Avatar
Engine: LC9, LT1
Plugs are all in.. I'll take a video later for you guys to see.
If I have time I'm going to put the starter on it and do a compression test. I'm guessing something north of 140psi is stock for a early 5.3?
I'm thinking of just getting a 5.7 rotating assembly and boring the block. An iron block LS1 would be a nice boost motor.
-- Joe
Old 07-01-2016, 12:26 PM
Car: 92 Z28
Just FYI if your going to start rebuilding/machining ect Summit does have the GM 5.3 bare block for $300
https://www.summitracing.com/parts/s...Fc5ZhgodZEAIQQ
Good deal if you need one.
Old 07-01-2016, 12:32 PM
anesthes's Avatar
Engine: LC9, LT1
I saw that, but it's $150 to ship it to my door, then I gotta do freeze plugs, cam bearings, galley plugs, and all that and final hone.
It's cheaper to machine the one I have.
I gotta do more reading though. I've not done any LSx stuff. I might be making some assumptions of what it's capability is..
-- Joe
Old 07-01-2016, 01:32 PM
anesthes's Avatar
Engine: LC9, LT1
here
Old 07-01-2016, 01:47 PM
Car: 92 Z28
Do you feel air coming out of anywhere besides the exhaust ports? That seems way too easy.
Old 07-01-2016, 01:50 PM
anesthes's Avatar
Engine: LC9, LT1
No, but I need to get someone to turn it while I check.
If I have time tomorrow night I'll do a compression test but, yeah. I was bummed. But for $150 I can't gripe.
I figure I could either make a low boost 5.3, or maybe a 400hp naturally aspirated 5.7 out of it.
-- Joe
Old 07-01-2016, 05:58 PM
COTM Editor
QwkTrip's Avatar
Car: '89 Firebird
Engine: 7.0L
That engine is toast.
Old 07-01-2016, 09:00 PM
anesthes's Avatar
Engine: LC9, LT1
Yeah that's kinda what I was thinking.
-- Joe
Old 07-10-2016, 09:04 AM
Pocket's Avatar
Car: 91 Trans Am
Engine: LSA
Transmission: T56 AWD
Axle/Gears: 8.8 4.10
Yeah that was too easy to spin
I can spin most used truck motors over by grabbing the balancer by hand, but its slow and I have to let compression bleed off as it turns
Old 07-11-2016, 05:52 AM
anesthes's Avatar
Engine: LC9, LT1
Well, I guess It will be a core for a future project.
-- Joe
Old 07-11-2016, 10:49 AM
Pocket's Avatar
Car: 91 Trans Am
Engine: LSA
For $150 youve got in it, you could turn it in to most rebuilders and make money. They're cake to overhaul, so dont sweat it
Old 07-11-2016, 11:58 AM
anesthes's Avatar
Engine: LC9, LT1
I have not done one before, but I figure it's time to start. Really thinking of doing a 5.7 build. I here you can bore them out and stick ls1 rotating assembly.
-- Joe
inkscape
09-21-2016 02:29 AM
wiskerchen019
04-16-2016 05:38 PM
theurge
04-08-2016 08:30 PM
kg1922001
04-05-2016 08:22 PM
BlackMamba94
04-05-2016 03:17 PM
Quick Reply: LSx rotational drag
