BADNBLK's 91 Z28 LS1 swap... Engine + much more :)
#402
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: BADNBLK's 91 Z28 LS1 swap... Engine + much more :)
Aren't you getting tired of winning the Super Chevy award at Bandimere?
Congratulations! Yours is the most engineered 3rd gen I've seen in person!
#403
Car: 1985 Camaro Sport Coupe
Engine: 2.8 - Bored/Stroked, Pacesetters
Transmission: 5 spd Manual
Axle/Gears: Stock
Congrats brother!! A very amazing car before the swap and now even better!! I did not think that was even possible. So, what's next for this beast???? I cannot imagine what more could be done.....NITROUS.....TWIN TURBOS.....?????
#404
COTM Editor
Not sure about power adders at this point, but not ruling anything out. I need to do some more suspension work, and have some plans for some changes coming, but not out of the engineering dept yet
#405
Any sound clips of this thing? Would love to hear it in motion.
#406
so what are the tire sizes and rim specs... I see they are 18x10's and 11's but what backspacing are you running? if you don't mind sharing
#407
COTM Editor
I have some video that I need to upload to youtube, that should give a better idea than the first start idle clips I posted before.
I have narrowed rear end, and custom brakes... I'm not sure you'd want my specs unless you have baer hubs, rotors, and narrowed to my specs. But if you still do let me know I'll tell you.
#408
Eventually my car will get to the stage yours is, hopefully in two more years I'll be "done".
#409
BADNBLK has really set the bar pretty high on this one. Beautiful work.
#410
I had posted over at your COTM thread however I may find you here more readily.
To repost:
Curious. What are your fenders heights? I haven't gone back to read up (again for the 4th time...!). Do you have weight jacks...or anything to adjust ride height? The wheel/tire combination and stance suit the 3rd gen perfectly. (Is it tubbed?)
To repost:
#412
COTM Editor
Thanks. I just read your post in the car of the month thread (congrats btw), and realized that my engine plans are identical to what you've done internally... So I might just copycat lol.
To repost:
To repost:
Ain't no thang as too clean haha!
#414
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
If I'd brought mine up next to you guys, yours would have looked even better.
But it was busy going rounds...
#415
COTM Editor
#416
Car: 88 rs
Engine: ls1
Transmission: t56
Axle/Gears: moser 4:10
Who put those Optima stickers on your car, are they straight?
#418
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
God I love this thing! Who makes the carbon front grill again?
Jay
Jay
#419
COTM Editor
#424
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Heh, I was going to have it be wall art, I don't even own a Camaro, lol
#426
COTM Editor
So I got a phone call and pulled all my stickers off over the weekend....
Then I drove it out a little outside of town to a lil spot in a fancy development, and took some pictures
This guy kept getting in the way of my shots...
Yeah!!! That is the quick and not dirty on that situation
#429
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Beautiful car and as others have said it looks greats without the stickers. I really enjoy your builds your attention to detail is incredible.
Serious question though. Every time I look at your car I can’t wrap my head around how low it is. I have the Eibach pro kit springs and had to cut bumps to stop hitting them on really rough roads. In addition my car even with the lowered stance rolls over in the front due to the lowered roll center. You must not have much suspension travel before hitting the bumps, and it can’t ride very well does it? How did you solve the roll center problem associated with lower cars? Really large sway bars? Care to elaborate on how you got a stance like that and can still drive on the street?
#430
Axle/Gears: Stock
Congrats brother!! What magazine is this beast going in??? (Sorry if you stated earlier, I did not see it??) Looks AMAZING without the stickers everywhere!
Your secret photo spot appears to be North of home???? East of I-25 off Mulberry?? Looking GREAT as usual!! LOVE THIS F-ING CAR!!!!
#431
COTM Editor
#432
#434
.... In addition my car even with the lowered stance rolls over in the front due to the lowered roll center. You must not have much suspension travel before hitting the bumps, and it can’t ride very well does it? How did you solve the roll center problem associated with lower cars? Really large sway bars? Care to elaborate on how you got a stance like that and can still drive on the street?
In a nutshell, extended ball joints and a lowered panhard bar mount will reduce the need for larger sway bars by moving the roll centres. Add to that reduced unsprung weight via light weight wheels, hubs and brakes and you can reduce the need for big bars even more. This not only improves the ride quality, but with an appropriately spec'd shock to take advantage of the changes, keeps the tires in better contact with the pavement.
TEDSgrad and SlickTrackGod do a good job of explaining what happens.
https://www.thirdgen.org/forums/susp...ll-joints.html
#437
COTM Editor (Retired)
Re: BADNBLK's 91 Z28 LS1 swap... Long time coming
Well I made a couple changes to my plans. If you have been following any of the other threads on this page, then you know what these are.
For those that don't. These are the Hooker Blackheart series of stainless LS swap headers for 82-92. They are 409SS, 1 7/8" primaries, and don't compromise ground clearance. I will be using almost their entire set up for this, except for their conversion pan, which will/may require me to notch the kmember for pan clearance.
I replaced a very nice set of Hawks Stainless Works headers for these and I got to say I'm impressed with the quality. The inside of each primary has been smoothed and sanded to provide no interuptions in flow. The SW headers had very nice welds, but nothing like this. Can't wait to get the rest of the system.
Can they be got with a Y-pipe?
#440
You're welcome (right place, right time)
I like a set of these myself. Easy to install over the axle true dual exhaust. Just a little fabrication needed to adapt the mid-pipe and back to my own Gen 1 SBC headers and 700R4 crossmember.
#441
1 Post
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
You would have to make your own Y pipe if that is the route you want to go. They are set up for their true dual system. Unless you already have a cat back you really want to use I would recommend just getting their dual system with those headers. It is a really good exhaust and it is actually cheaper buying that than buying a y and a catback.
#442
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
yup. I saw yours on the MAVtv episode as well; looked great and I have been watching all the episodes of the whole series. I always perk up when I see a 3rd gen competing.
Mine was on the NJ episode but just the same; maybe for a total of 9 seconds
Great event optima does. I heard that they moved the NJ event from May to August , so that may change things around for me a bit, but I still plan on attending
#443
COTM Editor
#444
COTM Editor
yup; same here. I saw yours on the MAVtv episode as well.
Can't wait to see how you do next season
#445
Car: 1987 IROC-Z
The show is set up to only really highlight the "cast" of the guys running every event and being contenders. I hope that someday I can find a money tree and afford to play with the big boys and travel as well. I don't have MAVtv so I wasn't able to catch any other episodes other than the PPIR event. I can't wait for next season, even though I got thousands to spend to try and come out and show up ya know.
yup, you are certainly right about that. the TV show definitely spends most of the time on the "heavy hitters" and showcasing their story as well as the car. I totally understand that. Those are typically some seriously seriously awesome cars indeed. Would be nice to show more "raw" footage of more of the overall competitors, but I understand they gotta squeeze all the weekends action into one hour.
I am right there with ya when it comes to wanting to be up there to play with the big boys. You car is light ears ahead of mine in fabrication and mods so I am hoping just to be up to your ride's level one day...! I am interested to see how those blackheart headers go in too. Keeping an eye out for updates as I usually do.
#446
COTM Editor
The BLACKHEARTS are on the car. They were the header I initially installed, but I had them Ceramic heat coated, so may not have seemed like it in the pics. That was a crazy deadline time for me haha
#447
How was the fitment of the headers around the sub frame area. I installed the Racing Innovation headers and the fitment is extremely tight to the sub frame area Like 3/8" on the left and 1/8" on the right side. I am running the factory K-member and 4L60E so fitment is gonna be tight but mine is way tight. I guess you get what you pay for.
#448
COTM Editor
#449
COTM Editor
