BADNBLK's 91 Z28 LS1 swap... Engine + much more :)
#301
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: '85 iroc-'13 powerstroke H&S tuned
Engine: 406 sbc full roller
Transmission: t5 soon to be t56
Axle/Gears: stock
Re: BADNBLK's 91 Z28 LS1 swap... Engine + much more :)
what are the dimensions on the radiator or better yet do you have a link?
#303
1 Post
Axle/Gears: stock
awesome that will help clear the twin huron speed kit im gonna run with a 408, cant wait to dump some funds in to the ol girl
#305
1 Post
Axle/Gears: stock
currently 2000 miles from home working to pay for it, got the t56, spohn k member with a arms, 12 bolt moser, full founders rear, pa racing front coilover kit, sold the 406 and t5 now just need to find the time to do it, i plan on shaving everything from the firewall except master and clutch master. keep up the good work
#307
COTM Editor
#311
COTM Editor
#312
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
That's characteristic of some...
Nothing else was intended.
Thanks. Should be weather-free for a change. I'll be running the '57, my son will be running Ugly Betty.
#313
Good lord.
I hope your OCD makes the wiring as clean as the bodywork in the engine compartment. Truly outstanding work
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
#314
COTM Editor
What wiring?!!! Is what I hope people will say lol. I have ideas on what to do with that all, but making it a reality might be another thing. That will hopefully be a next week project.
#316
I hadn't seen your build thread, I rarely check this LS section. It looks great. I was wondering what compound you used for the engine bay, what grit you decided to wet sand up to and how/what equipment you used to polish it? Old style liquid sandpaper compound or something like the newer perfect it line? Did you wet sand by hand or use the 6" Trizact 3M stuff? Really looks great. I was thinking of using the little 3" pads on mine.
And like one of the other members said, check out the braided nylon!
http://www.cableorganizer.com/nylon/
#318
COTM Editor
I welded the firewall seam to just behind the wiper motor, and stopped... so only like 4" from my plate. The passenger side frame rail I did weld up and smooth, but I didn't take it all the way down as you did. The drivers side I didn't mess with as steering shaft, brake lines, and headers don't allow you much space to show off all the addition work, so I just didn't do it haha!
#319
COTM Editor
Its been 10 years since I repainted the bottom of the car, and there was a few scratches and such from previous work in the last 10 years. So I rattle canned the transmission tunnel area again while the transmission was out. You'll see why I spent that time soon.
![Name: 20160610_182927_zpstj5kphhu.jpg
Size: 3.46 MB](https://www.thirdgen.org/forums/attachments/ltx-lsx/319383d1501267467-badnblks-91-z28-ls1-20160610_182927_zpstj5kphhu.jpg)
![Name: 20160610_182913_zps6oxstosw.jpg
Size: 4.18 MB](https://www.thirdgen.org/forums/attachments/ltx-lsx/319384d1501267467-badnblks-91-z28-ls1-20160610_182913_zps6oxstosw.jpg)
Next I broke out the Heatshield Products heat barrier. I consistently felt like there was a large amount of heat coming from the transmission tunnel, so this may help keep it on the outside, which will be much more important now with no HVAC.
The install is simple as cutting the shape and peeling the self adhesive backing off and rolling it on.
![Name: 20160610_233351_zpskcnh4eus.jpg
Size: 3.67 MB](https://www.thirdgen.org/forums/attachments/ltx-lsx/319385d1501267467-badnblks-91-z28-ls1-20160610_233351_zpskcnh4eus.jpg)
![Name: 20160610_233323_zps3m4bxhyd.jpg
Size: 3.67 MB](https://www.thirdgen.org/forums/attachments/ltx-lsx/319386d1501267467-badnblks-91-z28-ls1-20160610_233323_zps3m4bxhyd.jpg)
Billet AN line clamps... eh I was taking pictures lol
![Name: 20160610_233250_zpsgqjezefm.jpg
Size: 3.43 MB](https://www.thirdgen.org/forums/attachments/ltx-lsx/319387d1501267467-badnblks-91-z28-ls1-20160610_233250_zpsgqjezefm.jpg)
![Name: 20160610_233149_zps8ubzqqbv.jpg
Size: 3.48 MB](https://www.thirdgen.org/forums/attachments/ltx-lsx/319388d1501267467-badnblks-91-z28-ls1-20160610_233149_zps8ubzqqbv.jpg)
#321
COTM Editor
Next project was getting the LS7 clutch and T56 transmission installed... which I didn't take much for pics, but you can see it in the pics with the
Hooker Blackheart True dual stainless exhaust system!!!!! I gotta say I opened the box initially and said "wow there is a lot of pieces" but all of those pieces came together to be the most well thought out, and best fitting exhaust system I have ever seen for our cars. I could not be happier with the money spent on this system and I haven't even heard it yet! I'm still not sold on the exhaust tips, and I have a plan with those, but it will be a while before I mess with those.
Anyway.... Here is the pics!
![Name: 20160611_143917_zps9p9u7nt3.jpg
Size: 3.72 MB](https://www.thirdgen.org/forums/attachments/ltx-lsx/319376d1501267467-badnblks-91-z28-ls1-20160611_143917_zps9p9u7nt3.jpg)
![Name: 20160611_143935_zpswakug7dt.jpg
Size: 4.13 MB](https://www.thirdgen.org/forums/attachments/ltx-lsx/319377d1501267467-badnblks-91-z28-ls1-20160611_143935_zpswakug7dt.jpg)
![Name: 20160611_144006_zpsb6iauewj.jpg
Size: 4.17 MB](https://www.thirdgen.org/forums/attachments/ltx-lsx/319378d1501267467-badnblks-91-z28-ls1-20160611_144006_zpsb6iauewj.jpg)
![Name: 20160611_144015_zpsgzew5dzy.jpg
Size: 3.92 MB](https://www.thirdgen.org/forums/attachments/ltx-lsx/319379d1501267467-badnblks-91-z28-ls1-20160611_144015_zpsgzew5dzy.jpg)
![Name: 20160611_144352_zpsq8zmzsri.jpg
Size: 3.94 MB](https://www.thirdgen.org/forums/attachments/ltx-lsx/319380d1501267467-badnblks-91-z28-ls1-20160611_144352_zpsq8zmzsri.jpg)
![Name: 20160611_144410_zpsjhlethnx.jpg
Size: 4.09 MB](https://www.thirdgen.org/forums/attachments/ltx-lsx/319381d1501267467-badnblks-91-z28-ls1-20160611_144410_zpsjhlethnx.jpg)
![Name: 20160611_143955_zpsxthkf3r9.jpg
Size: 3.73 MB](https://www.thirdgen.org/forums/attachments/ltx-lsx/319382d1501267467-badnblks-91-z28-ls1-20160611_143955_zpsxthkf3r9.jpg)
I'll take better pics of the tips when its on the ground.
Got some other little stuff done as well, but didn't take much for pics of that stuff.
#322
Are your frame connectors a home brew?
Does the Black heart exhaust work only with a transmember made with the dual exhaust notches?
#323
COTM Editor
Darn right about that heat from the transmission tunnel! I was leaning towards only covering the cabin side of the transmission tunnel, are you doing both sides or only that side?
People are adapting the exhaust to other headers and mounts, so I'm sure it can be done, but not bolt in like this was. Worth it though....
#325
COTM Editor
Yes, not LOTS!!!! but more than I'd like. Dyno-mat is just rubberized asphalt with tinfoil on one side, not a heat barrier, just an additional layer to get hot.
#327
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Looking great! When I got my custom exhaust built, I put the mufflers at the back like that too! Sounds awesome!
#328
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
looks like it is coming along great man. I enjoy following this build
awesome work
awesome work
#329
Car: 1991 Camaro Z28
Engine: LS Conversion
Axle/Gears: Stock for now...
Really enjoying this thread. I'm drooling over the underside of your car too. I wish I had a lift like that!!
#330
Car: '02 Z06
The most important thing with projects like this (other than having funds to do it) ... is to push yourself to make progress little by little. The more you start to see it come together, the more motivating it is to finish it.
Great work so far!
Great work so far!
#331
COTM Editor
Been on vacation all last week. Not much to update since then, so I'll try and hustle and get something to so all you guys!
#333
COTM Editor
I need to...
- Finish assembling spark plug wires
- Make a bracket for my coils to sit on. Mount coils.
- Mount ECM
- Run harness out to car, or in to computer... how ever you wanna look at it.
- Run powers and ground to engine, body, lights, and fans.
- Mount fuse block and tie all harness/dash together.
- Install base tune.
- Start engine!!!
- Make brake lines to Wilwood master cylinder and bleed.
- Bleed clutch, and adjust tick master as needed.
- Put the front clip back on.
- Wire SkinnyBoy quad projectors in.
- Reassemble interior.
- Swap seat brackets, install Sparcos
- Dyno tune
- Drive AS MUCH AS POSSIBLE for engine break in
- Load on trailer
- Drive to PPIR
- Sleep for 30 minutes
- Race to M******t Glory...
![help](https://www.thirdgen.org/forums/images/smilies/help.gif)
![crazy](https://www.thirdgen.org/forums/images/smilies/crazy.gif)
![Embarrassment](https://www.thirdgen.org/forums/images/smilies/redface.gif)
#334
COTM Editor
I have had the loom for over a year.
I need to...
- Start engine!!!
- Dyno tune
- Load on trailer
- Drive to PPIR
- Race to M******t Glory...![help](https://www.thirdgen.org/forums/images/smilies/help.gif)
I need to...
- Start engine!!!
- Dyno tune
- Load on trailer
- Drive to PPIR
#339
COTM Editor
I need to...
- Dyno tune
- Load on trailer
- Drive to PPIR
I need to...
- Dyno tune
- Load on trailer
- Drive to PPIR
Guess what?! It runs!!! I'll post a couple videos in a few. Uploaded a custom tune, and we can't get it to idle. Turns out my IAC isn't sealing... Not sure why, but it was late, and I need a couple hours of sleep before work.
#340
COTM Editor
<iframe width="560" height="315" src="https://www.youtube.com/embed/V1WID9vSyTQ" frameborder="0" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/9r1O4e68rQw" frameborder="0" allowfullscreen></iframe>
#341
1 Post
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
![](http://g03.a.alicdn.com/kf/HTB1uYUnKXXXXXaEXFXXq6xXFXXXA/92mm-throttle-body-TPS-IAC-Throttle-Position-Sensor-for-LSX-LS-LS1-LS2-LS6.jpg)
^^ Check O ring ?
Also is the MAF tuned for the dual snorkel? I remember reading that it is tough to tune when your running multiple air filters, but really that's the only detail I remember.
Grats breh, your gonna make it.
#342
COTM Editor
I'm gonna try!
#345
COTM Editor
So IAC seal o-ring was garbage, but the IAC still didn't operate correctly, so it now has a new one, and will idle on its own after a little coaxing. We got some tuning work to do.
I spent most of Sunday finishing up some basic wiring, vacuum hose connections, Brake lines for the Wilwood master, bleeding the hydraulic fluids, rear axle seals, and putting the body back together, and some interior re-assembly.
I UNWRAPPED IT!!!!!! I think it looks freaking mean, and I'm really happy with how it turned out.
![Name: 20160703_180134_zpsmf4fpha9.jpg
Size: 4.03 MB](https://www.thirdgen.org/forums/attachments/ltx-lsx/319067d1501266449-badnblks-91-z28-ls1-20160703_180134_zpsmf4fpha9.jpg)
![Name: 20160703_180204_zpsnohipzjq.jpg
Size: 4.21 MB](https://www.thirdgen.org/forums/attachments/ltx-lsx/319068d1501266449-badnblks-91-z28-ls1-20160703_180204_zpsnohipzjq.jpg)
![Name: 20160703_180247_zpse691biba.jpg
Size: 4.08 MB](https://www.thirdgen.org/forums/attachments/ltx-lsx/319069d1501266449-badnblks-91-z28-ls1-20160703_180247_zpse691biba.jpg)
I put the nose together on the ground
![Name: IMG_20160703_202745_zpskmphl3nm.jpg
Size: 1.92 MB](https://www.thirdgen.org/forums/attachments/ltx-lsx/319070d1501266449-badnblks-91-z28-ls1-img_20160703_202745_zpskmphl3nm.jpg)
With the fenders and nose on... (still have final alignment of panels to do)
![Name: 20160704_001933_zps2aeaifyt.jpg
Size: 3.95 MB](https://www.thirdgen.org/forums/attachments/ltx-lsx/319071d1501266449-badnblks-91-z28-ls1-20160704_001933_zps2aeaifyt.jpg)
![Name: 20160704_001956_zpse552tqjh.jpg
Size: 3.72 MB](https://www.thirdgen.org/forums/attachments/ltx-lsx/319072d1501266449-badnblks-91-z28-ls1-20160704_001956_zpse552tqjh.jpg)
![Name: 20160704_002008_zpszxyq8peq.jpg
Size: 3.97 MB](https://www.thirdgen.org/forums/attachments/ltx-lsx/319073d1501266449-badnblks-91-z28-ls1-20160704_002008_zpszxyq8peq.jpg)
Good look at my Skinnyboy Lighting QUAD projector mini D2S Square headlight set up... Still need wire them up
![Name: 20160704_002056_zpsegniyovc.jpg
Size: 4.09 MB](https://www.thirdgen.org/forums/attachments/ltx-lsx/319074d1501266449-badnblks-91-z28-ls1-20160704_002056_zpsegniyovc.jpg)
![Name: 20160704_002124_zpsubwyx8yn.jpg
Size: 4.22 MB](https://www.thirdgen.org/forums/attachments/ltx-lsx/319075d1501266449-badnblks-91-z28-ls1-20160704_002124_zpsubwyx8yn.jpg)
#346
1 Post
Car: 2014 Z28 #80
Dear god I am envious... That's probably the prettiest setup I have ever seen... and I was really partial to mine (for a home job/first time etc.).
#349
COTM Editor
Thank you! The coils are mounted under the dash.
Awesome!!! Thank you!
#350
1 Post
Car: 92 Z28
Lookin killer man. Is that a catch can by the tensioner pulley? And is the shaved nose emblem a new thing or was that already done? Can't recall.
