steel braided fuel line LT1/ls1
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
I have the stock fuel line on my Lt1 and i don't like it, it looks like a fire hazard the way i have mine now, and makes my engine bay look bad. I seen a thread on here someone had it and the part# but now i can't find it.
It's Pure Choice Motorsports Kit but i need help finding the one to the thirdgen fuel fittings?
COTM Editor
Received 1,895 Likes
Car: '89 Firebird
Engine: 7.0L
Re: steel braided fuel line LT1/ls1
Is this what you're looking for? (part number DFI 310-74730)
Transition from -6AN fitting to the stock 3rd gen fuel line.
http://www.jegs.com/webapp/wcs/store...Term=310-74730
Car: 1989 SS
This thread is what i'm talking about, there is a kit that bolts and snaps right up.
https://www.thirdgen.org/forums/ltx-...-lt1-fuel.html
https://www.thirdgen.org/forums/atta...s-pics-552.jpg
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
For the Braided Line, itself, make sure you get some kind of Teflon lined line. Otherwise, fuel will sweat through your lines, and your garage will ALWAYS smell of gasoline.
I got mine from Pegasus Racing, for it's flexibility...
https://www.pegasusautoracing.com/pr...p?Product=3480
There is some less expensive line out there that could work for short straight runs- look for the "radius" specs to check if you can use.
Car: 1989 SS
I found an extreme way of doing it, http://www.gmhightechperformance.com...third_gen_use/
Car: 92 RS/97 K3500/07 ISS
Engine: LT1/454/LS4
Transmission: 4L60E/4L80E/4T65E-HD
Axle/Gears: 2.73/4.10/3.29
You might also try pm'ing z28ricer on here, he's only on once every couple of weeks right now, but he makes them as well. I bought one of his power steering swap hoses & it's well made, so if it's any indication of the quality of his fuel lines are I wouldn't hesitate to buy them if I were needing a set again.
Car: 1989 SS
When I bought mine several years ago I just called them & they knew exactly what I needed.
theshackle
03-05-2017 06:37 PM
ambainb
04-25-2016 09:21 PM
AkDrifted
08-17-2015 07:45 PM
