Custom LT1/LS1 Swap Wiring harness's built to your specifications..any interest's??
Car: 87 IROC
Engine: LQ9 6.0
I don't know if this is in the right forum or not,but I was just wondering if I was to offer custom built LT1/LS1 Swap harness's built to your specifications/setup using factory 3rd gen and factory LT1/LS1 Etc harness's..basically just saving you time and the hassle...how many would be interested in something like this? and if so,what sounds like a fair asking price for that kind of service? TIA
Car: 87 IROC
Engine: LQ9 6.0
Re: Custom LT1/LS1 Swap Wiring harness's built to your specifications..any interest's
Nobody would be interested in something like this??..
i would be interested for my swap
Car: 89 IROC-Z
Engine: 355ci SBC
Transmission: TH700R4 - 2500 stall
Axle/Gears: 3.70 9 bolt
I would be interested as well. I'm sure you could get some takers as the harness from Hawks runs about a grand. $600.00 seems like a good price... depends on how much your looking for though.
Car: 87 IROC
Engine: LQ9 6.0
I was thinking around $225(includes return shipping)if both the 3rd gen and LT1/LS1 harness's are supplied to me...once received, I would strip both harness's down,join the two harness's into one, COMPLETELY remove any unneeded wiring and reloom the new harness,all done to fit your application/setup..let me know what you guy's think.
I don't see how you plan to make any money on these. There is nearly 100 dollars in materials to build one if using high quality loom, tape, solder, ect.. Shipping one way is 15-20(plus insurance). You would likely make less than minimum wage if you are doing quality work with quality materials.
Car: 87 IROC
Engine: LQ9 6.0
Car: 87 IROC
Engine: LQ9 6.0
I'm not looking to make a living at this..I'm just "feeling it out" for now..more less just trying to help some fellow swappers out and get my name out there/make a little money while I'm doin it.
Car: 91 Trans Am
Engine: LSA
Transmission: T56 AWD
Axle/Gears: 8.8 4.10
I'd suggest basing the fee on time vs an arbitrary number. Bear in mind you will have nearly as much time with Q&A prior to and after the work as you will in the actual build. You'll also want to keep a large stock of parts on hand for a quick turn around
I've got a good bit of extra connectors I'll never use if you're interested in stocking up
Car: 87 IROC
Engine: LQ9 6.0
I would say yes there is demand. In fact I thought there was already a market for this.
Pocket did mine, it was the best money I spent on my entire swap, and if I do another I'd want him to do it again.
And, yes, he answered many email questions for me, was an invaluable resource, and other than me turning the wrench, he is probably the single most critical participant in making my swap a reality.
Yes, I'd pay for someone to assist with the wiring harness.
Car: '89 IROC-Z
Engine: LSx
When the point in time comes for me I'd deffinatly be interested. I have my LS1 harness but every harness on my 89 was junk so once I get another chassis harness and the time comes I'll be in.
Car: 83 Z28/L69
Engine: L69 305H.O.
Transmission: 6spd T56
Axle/Gears: 4.10 LS 4th Gen
I'm about to do a 97 LT1/6spd into a 85 SC. Where do I send my harness? Do you take PayPal? THanks
Car: 1988 Camaro
Engine: 5.3L LM7
Axle/Gears: 3.73 1LE '90 Disc
I would definitely be interested, I am swapping an LM7/4L60e truck motor into my car 1988 camaro with 305tbi/700R4. Nothing wild needed on mine, just convert everything. Will be running LS6 intake and injectors.
Let me know how much and I'll do paypal as well or send a check either way.
Car: 1988 Camaro
Engine: 5.3L LM7
Can you post pics of work you've done?
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
I'm interested. Do you have any references?
