Texas Two-step: My ls6/hybrid swap
Car: 1992 RS Heritage Edition
Engine: LS6 Mut
Axle/Gears: Stock
What up TGO!? Just wanted to post up about a swap I'm doing for my fiance.
A little background about the car:
It is a 1992 RS Heritage Edition (White/Red stripes) with 114k on the clock. Her father bought the car brand new and gave it to her when she turned 16. She's had the car for 15 years now and the last 5 years it has been sitting in the garage. About 4 years ago it stopped running so I replaced the battery and alternator and got the car to run again. Later I found that it had a constant drain from the alarm system that was installed incorrectly. I pulled the wiring and reconnected the vats properly; problem solved. she drove it up until 3 years ago and after that winter season the car wouldn't start. come to find out the fuel pump was toast. To make a long story not so long, I figured the best solution to fixing the fuel pump would be to throw an ls/4L60e combo in it, lol. Her mom was to the point that she was tired of it sitting and was going to sell it. The GF came to me in tears asking me to get it running again since her father had passed away a few years back and that was really the only thing left of him she had that was tangible. She obviously didn't want to get rid of it so I brought it down from OKC to Dallas on a trailer and told her I would fix it and that's when it hit me. She wants to drive it, she wants to enjoy it, and she doesn't want to have any issues with it. LSX its is.
PICS:
The car is in great shape inside and out. Yes I know, it's super dusty...lol. It has a few nicks on the lower ground effects and a couple on the door guards but other than that it's flawless. The interior carpet is great, the drivers seat has a tear or 2 in it but those will be getting replaced. The dash pad is in great condition and is original although it's loose, I don't think the mounting points are broken but just need to be tightened down. The radio trim panel is cracked from whoever installed the single din unit over tightening the screws and the armrest lid latch is broken. These will all be replaced as well. I plan on pulling the carpet and dynamating the full car as well as the doors since the panels have to come off to replace the window motors and adjust the window guides/felts. The hatch motor works well but the shocks on the hatch and hood are toast so they will get replaced. other than that everything else is great.
Thanks for taking the time to look!
Darryl
PICS:
Darryl
Engine: LS6 Mut
Axle/Gears: Stock
Re: Texas Two-step: My ls6/hybrid swap
Tear down and removal...
Engine and trans out...anyone need a solid 305 and 700r4??? lol
Engine: LS6 Mut
Axle/Gears: Stock
A little 1/8th mile action in my 06 zo6:
LS7 factory bottom end, factory non-milled heads, ported and polished, upgraded bronze valve guides, stock titanium intake valves, SS ferrea exhaust valves, comp 675 lift dual spring, comp hardened push rods, comp/tsp custom grind 246/256 @ .660 lift, Haltech killer bee intake, ported fast 102, ported nick williams 102tb, LG 1 7/8 LT's, no cats 3" o/r x pipe to B&B Bullets, MGW short stick, Mantic twin disc clutch, pfadt motor and trans mounts, stock rear end. 577/552rwhp/tq this was my 1st time at the track in the car something like my 7th pass. Ran my best of the night 7.25 @99.8mph spinning through most of 1st.
The truck is also a friend of mine that we built. It's an 89 with a 5.3 swap, big cam, built trans, 100 shot. We just redid the suspension and haven't had a chance to run it again.
Engine: LS6 Mut
Axle/Gears: Stock
Transmission is done...
The engine is almost complete. The plan was to just do an ls1 with the LS Hot Cam, 317 heads/LS2 intake. I bought the motor minus the intake and oil pan from a 98 C5 vette for 750 bucks on craigslist. We tore it down and there was no issues with it. Sent it off to the machine shop with a customers short block from his 04 zo6. My engine build was supposed to be ls1 block, lq9 rods, forged mahle pistons. Well the machine shop mistakenly swapped blocks and machined the LS6 block for my pistons. Told the customer what happened and he was cool with it. He was going to have it rebuilt to sell anyway because we are building an iron block 408 for his car. I paid for both of our machining, let him have my LS1 block as well as bought the lq9 block for his build in exchange for his LS6 block.
Still waiting on a few parts but it should be put together and ready to go in tomorrow. LS6 block, LS1 crank, LQ9 rods, forged mahle LS2 pistons, arp hardware, IWIS timing chain kit, 317 6.0 truck heads milled (same specs as a 243 head) and polished the ports up a little bit, stock 6.0 truck valves, ls3 springs, comp 217/226 @ .575 lift 114 lsa cam. PICS:
Engine: LS6 Mut
Axle/Gears: Stock
Pulled the exhaust, dropped the tank....12 gallons of bad gas and a rusted out fuel pump and fuel sender later...I figures i needs a new gas tank. I'll be running braided steel fuel line, walbro 255 in tank pump and C5 corvette fuel filter
Engine: LS6 Mut
Axle/Gears: Stock
LSX swap radiator came in from entropy radiator. By far the best quality radiator i have seen to date. I am using a similar one from the same company on my ls3 stroker swapped 66 c10. They are hand built, multi core, aluminum radiators made in the USA. Great quality dual electric fans and harness. You may pay a little more for these radiators but its worth every penny. They are direct replacement units that you don't have to modify anything on the car and for ls swaps they move the inlet/outlets to a location so you can stock f-body radiator hoses. I'll get some pics and post up. good for 900hp.
New interior; 2001 Trans Am Seats custom upholstery. These seats are built buy a guy I know in Florida. This package was $1100 shipped. I know that sounds expensive BUT this is what you get. You get front and rear seats with new foam, seat tracks are cleaned and greased, new switches, motors, and wiring for electric seats and last but not least great quality leather upholstery. Obviously the more custom you want it, the more you are going to pay. Unfortunately for me, my order came in wrong after I deployed so He has agreed to wait until I get back home to rectify it. It was supposed to be black leather with red inserts and red baseball stitching for all of the seams w/out the firebirds in the headrests. Needless to say I got firebirds in the headrests and o baseball stitching. Most likely I will settle for a refund on the cost of the stitching and I will remove the headrest covers and swap them with the blank ones he sends me. still for the price it's awesome. PM me if you want his info. PICS:
Engine: LS6 Mut
Axle/Gears: Stock
on the agenda for this week is to notch the k member to accommodate the f-body a/c compressor (hawks notch kit), put the suspension and brakes on, instal new gas tank, pump, sending unit and run fuel lines.
I bought the '13 camaro SS brake kit from bigbrakeupgrade.com minus calipers and found my own set of red calipers on ebay since they didn't have any in stock when I bought the kit. worked out a little cheaper for me plus I get my core back when I send in the factory spindles! I'm going with Eibach Sportlines and KYB AGX shocks and struts.
I picked up a set of intellitronix gauges and I am anxious to install them. My fiance was a big fan of knight rider growing up and I figured she would flip **** when she cranks the car up and sees the digital gauges.
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Looks great so far!
You're in Dallas? You need to come hang out with NTTGA. we've got several guys who have either done LS swaps, or are in the process
https://www.facebook.com/groups/133019903522213/
Engine: LS6 Mut
Axle/Gears: Stock
Looks great so far!
Sounds like a plan, I'm in Rockwall actually. Check us out, we're opening the shop in a few weeks. Hit us up if any of you need help with a swap. that's the majority of the work we do is custom swaps, old school or new school and C6 corvettes.
https://www.facebook.com/RakichPerformace
Engine: LS6 Mut
Axle/Gears: Stock
its not done yet and honestly if we wouldn't have had customer cars, machining time and had all the parts on hand it would take about 5-7 days. thats about average for us once we get everything in. we usually don't have a car more than 2 weeks and if we do its because something is on back order or its an extensive build with a lot of fabrication.
Our monthly meeting is going to be this sunday at the spring creek in Irving at 4PM
hope to see you there
Engine: LS6 Mut
Axle/Gears: Stock
I'm deployed and won't be home until January. Until then my partner/best friend/shop owner is finishing my build and sending me updates as it progresses. Maybe next go around!
Engine: LS6 Mut
Axle/Gears: Stock
Motor and trans going in today!
Engine: LS6 Mut
Axle/Gears: Stock
Well, I thought it was going in today. Ran into a few setbacks, nothing major.
Got the frame notched, the old harness out, motor mounts didn't come in so drive line is going in tomorrow. Got the gas tank built and ready to go in. Going to power wash the engine bay then paint the k member before we install everything.
Engine: LS6 Mut
Axle/Gears: Stock
power washed the engine bay, painted the k member, and got my computer in! Hopefully engine and trans will go in tomorrow!
1 Post
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Very nice, definitely keeping up with this build. Does your upholstery guy have a website?
Engine: LS6 Mut
Axle/Gears: Stock
Space Coast Motor Works out of Florida.
Engine: LS6 Mut
Axle/Gears: Stock
Soon after this project is done, I'm going to jump back into my 66 C10 LS3 swap. Here's a brief rundown of whats going into it...
66 C10 SCSB Step Side frame off resto mod
Forged LS3 418 Stroker
Built 6L80E trans with twistmachine Paddle Shifters (1200hp rated)
Full PorterBuilt Touring Coil Over Drop Member
rack and pinion conversion
C6 ZO6 Brakes at all 4 corners
Moser 12 bolt 3.73's custom length star flanged 33 spline axles with torino big bearing ends
3" wider step side fenders to fit some big meats underneath without tubing the bed
Gas tank relocated between the rear frame rails
Custom Boyd aluminum gas tank for fuel injection w/aeromotive stealth 340 pump
Vintage Air
Dakota Digital Gauges
Modded factory dash for double nav/dvd unit
Hopefully this truck will be a ground pounder when its done. I'm hoping for 600rwhp N/A and 23mpg. I still have a lot of body work to do on the cab as well as fab the frame for the new suspension. I have a friend of mine that owns a local audio shop working on a custom enclosure for 2 JL Audio slim line subs where the old gas tank was. Can't wait to make some progress.
If anyone is interested in that build check out the below link.
http://67-72chevytrucks.com/vboard/s...d.php?t=550041
Vintage Air
Engine: LS6 Mut
Axle/Gears: Stock
Hawk's swap LT's installed, intake, trans, gas tank in and lines ran.
Next will be to lengthen the harness to locate the ECU under the dash, wire the gauges, tail/reverse lights, instal the radiator and crank her up...Once she's running then we'll finish out the suspension, brakes and interior.
Car: 89 IROC-Z
Engine: 355ci SBC
Transmission: TH700R4 - 2500 stall
Axle/Gears: 3.70 9 bolt
Looks great! I can't wait to get to that point. Hope it screams once you get it on the road...
Engine: LS6 Mut
Axle/Gears: Stock
Got the rest of the exhaust loosely installed to make adjustments as needed. Fit pretty well.
Engine: LS6 Mut
Axle/Gears: Stock
Engine: LS6 Mut
Axle/Gears: Stock
Engine: LS6 Mut
Axle/Gears: Stock
What did you do for suspension, I like the rim/tire combo and stance.I got sportline springs and bilstein hd shocks upfront and ak shocks in the back.I find the rear is just way too soft and the front is nice and firm.
Engine: LS6 Mut
Axle/Gears: Stock
I'm running sportlines with the KYB agx shocks and struts, hawks third gen wheel adapters and 2013 corvette C6 front wheels all around
1 Post
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Looks great. I want to do an LS swap into my 89 T/A so bad.
Engine: LS6 Mut
Axle/Gears: Stock
Engine: LS6 Mut
Axle/Gears: Stock
Car is now back on the street. Finishing up wiring the 4th gen cruise, 4th gen t/a seats, and other interior items. Wash, clay bar, wax, buff, and carpet shampoo. First time the car had this treatment since 2008 and the carpet for 23 years old looks new now. See pics. Will take more in better light.
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Looks great boss.
MMan. Now I wanna go and build up my 68 c10. Lolz
I was just planning on keeping it w a stock ls1 and bolt ons.
I looked far and wide for a 92 Ann ed camaro. The one u built here looks awesome.
Car: 1992 z28
Looks awesome man! The wax and clamber treatment really brought the life back to that paint. If you get a chance can you get some pictures of the completed engine bay? Maybe a shot or two of the interior as well? Also, I really like those wheels... the color on them is nice.
What did you do for the exhaust? Is that something that you fabricated yourself?
Engine: LS6 Mut
Axle/Gears: Stock
Looks awesome man! The wax and clamber treatment really brought the life back to that paint. If you get a chance can you get some pictures of the completed engine bay? Maybe a shot or two of the interior as well? Also, I really like those wheels... the color on them is nice. What did you do for the exhaust? Is that something that you fabricated yourself?
#42
Engine: LS6 Mut
Axle/Gears: Stock
#43
The exhaust is hawks lsx swap kit. Long tubes and off road y pipe into 3rd gen borla cat back. Pics of engine bay below.
Attachment 272789
Attachment 272790
Attachment 272789
Attachment 272790
#44
Engine: LS6 Mut
Axle/Gears: Stock
#47
Engine: LS6 Mut
Axle/Gears: Stock
#48
Without the heater control valve the heater core will always have hot water flowing through it. Since the core isn't isolated from the air flow when the AC is on, the cool air from the AC will flow over the heater core on the way out the vents. You can still cool the interior this way but not as easily as you can with either a manual bypass valve or the heater control valve plumbed into the lines.
4th gens get around this by having the heater core isolated from the airflow differently than a 3rd gen when the heater isn't on.
#49
Engine: LS6 Mut
Axle/Gears: Stock
Without the heater control valve the heater core will always have hot water flowing through it. Since the core isn't isolated from the air flow when the AC is on, the cool air from the AC will flow over the heater core on the way out the vents. You can still cool the interior this way but not as easily as you can with either a manual bypass valve or the heater control valve plumbed into the lines. 4th gens get around this by having the heater core isolated from the airflow differently than a 3rd gen when the heater isn't on.
#50
Engine: LS6 Mut
Axle/Gears: Stock
I guess what I'm trying to say is the a/c and heat are hooked up like they were on the 305 only the power plant is LS.
