84 Z28 LT1 Swap
Car: 1987 Iroc-Z28
Engine: L98 (soon to be LT1)
Transmission: 700R4 (soon to be 4L60e)
Axle/Gears: 3.27 LS
84 Z28 LT1 Swap
Well a few months ago I bought my own 3rd gen. It is an 84 Z28 hardtop. Original L69 HO 4bbl 5.0 had been replaced with what seems to be a late 70s 350 from a truck. Along with destroying 99.9% of the wiring under the hood and some on the interior, the PO also decided to hack up the interior ( gauge cluster was made out of a license plate? ) Well anyways, I have now replaced much of the wiring under the hood, and pieced the interior back together.. Still need an oem gauge cluster though. Now it time to start on the engine! I bought a 97 LT1 from a Firebird off a friend of mine for $500. He sold the T56 that was mated to it before I could get it so I'll be using a 700R4 since I have two in my garage, Ha! Well, the LT1 was just plum worn out, so it needed a rebuild. Last week I got it all torn down, looked like its definitely going to need boring.
As far as the engine build goes, I'll just be doing a moderate build. Pistons, Scat rods, and stock crank(fully Balanced). Ported intake and heads, upgraded springs, roller rockers, Comp Pushrods. 52mm TB, etc, etc.
Still haven't decided which cam to use. I was thinking the LT4 hotcam. I'm not looking for huge hp numbers here.. just a good weekend driver.
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Re: 84 Z28 LT1 Swap
Also, since this car was carbed before.. Any recommendations on a good inline fuel pump? ( I have no desire to drop the fuel tank, and I won't mind a noisy pump. ) and, my fuel lines are on the passenger side.. could I just get some from a tpi car to move the lines to the drivers side?
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: 84 Z28 LT1 Swap
Getting the lines from a tpi, tbi, or efi V6 car will work, its a good bit of work to install them, but if you've got the majority of the driveline out for the swap it wont be so bad.
For inline, i'd probably be sticking with a bosch 044
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Re: 84 Z28 LT1 Swap
So basically the lines from any efi car will work?
300lph..wow. with that much flow, it'd probably be wise to get a good AFPR? like the Aeromotive piece?
Car: 93 240SX
Engine: LQ9
Re: 84 Z28 LT1 Swap
Shouldnt need to get an afpr, but its never a bad idea.
Yes TPI/TBI/V6efi they are all the same underneath, there are differences in the end near the shock tower, some point straight up, some go at a slightly forward angle, but it really doesnt matter which you use.
The bosch will support the power, its high quality, and reliable.
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Re: 84 Z28 LT1 Swap
Small update. Engine is in the shop! time for the waiting game.
also got my intake painted..
What do you think?
What do you think?
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: 84 Z28 LT1 Swap
Very nice. Do nott get fuel anywhere on the intake when installing the fuel lines. Ask me how I know. Lol
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Re: 84 Z28 LT1 Swap
I'm going to Polish up the rails and TB and throw them on there to see how it looks tomorrow. Should look sweet!
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Re: 84 Z28 LT1 Swap
Welp, got the fuel rails polished, next is the throttle body. PS pump, steam pipe, and ignition components also came in today.
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: 84 Z28 LT1 Swap
Nice job on the polishing, try to reuse as many factory bolts as possible(except head bolts, rod bolts etc). I got new bolts from Ace and the threads were alittle more coarse. Just trying to give small pointers, seems lik,e youve got most of it under control
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Re: 84 Z28 LT1 Swap
Maybe I'll use them for the intake too, idk yet. I have NO intake bolts, ha, it didn't come with any. Engine wasn't complete so I'm trying to piece it back together.
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Re: 84 Z28 LT1 Swap
Update: Machine work on the block and crank is done. rebuild kit came in too. Now I just need to get the heads done
My car does have a TH350 in it! (very horribly installed though) Check it out.
nice mounting system the PO did there...NOT. I'm surprised that drive-shaft didn't come out!
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Re: 84 Z28 LT1 Swap
Anyone know where i can find the other side of this connector here? I've looked everywhere and cant find it.
Also, Anyone have a pinout for an 1984 Connector 100? I have a couple wires I can't figure out where they go.
Car: 93 240SX
Engine: LQ9
Re: 84 Z28 LT1 Swap
That connector is part of the a/c harness, it plugs into the corresponding plug on the engine harness. Though I'm quite sure thats out of a newer chassis, so you probably didnt have the same one on yours.
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Re: 84 Z28 LT1 Swap
Edit: The engine harness was destroyed too so, even if it was there, I would never know.
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Re: 84 Z28 LT1 Swap
Here is some pictures just to keep the thread alive while I wait for the engine work to be done.
This is My LT1 before dis-assembly.
Under the hood, as it currently sits.
While I had the dash out for wiring repair.
And, A random pic of my last project lol.
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Re: 84 Z28 LT1 Swap
Car: 92 Camaro
Engine: 3.1 v6 (building lt1)
Transmission: auto
Re: 84 Z28 LT1 Swap
Did you get the LT1 from a Marine Named Matt or Jay.
Asking because IM friends with them and helped load up an LT1 for them not too long ago.
Car: 1997 K1500 SS/SB
Engine: LT1 with TPI on top
Transmission: 4L60E/np241,
Re: 84 Z28 LT1 Swap
interisting build, not exactly my method but It will be a different way. watching!
here is mine http://www.gmtruckcentral.com/articles/lt1swap.html
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Re: 84 Z28 LT1 Swap
I was thinking the same thing.
Re: 84 Z28 LT1 Swap
xxxx
Car: 93 240SX
Engine: LQ9
Re: 84 Z28 LT1 Swap
Lol, oh no a 2.8 problem
getting mad at someone because you were posting blatant advertising some reason in his thread, and it was completely unrelated, and wanting to withhold help as a result.
Guess what, i've been at this a LONG time and i'm sure i'll be more than helpful with his issue that you want to act like you're the only one that can help.
His above post read "you might want to look at your pm's, i'm the one that was helping you with your 2.8 problem"
Re: 84 Z28 LT1 Swap
LT1 swap not related??? mad na not mad just insulted, that my feable attempt to help was ****** on.
good deal, I glad that you are so well versed in this stuff, I was actually hoping to bounce ideas off of you all, but???
huh??? I havent owned a 2.8 in 10 years??? your mixed up dude!!! or I am "that is possable" especially as ignorant as I am.
Car: 93 240SX
Engine: LQ9
Re: 84 Z28 LT1 Swap
YOU posted that you WERE helping the OP with his 2.8 problem, then went back, edited it and put "good luck"
You didnt have a "feeble attempt" at help, you just posted a link to your swap, into a truck with "not how I did it"
Bounce ideas off who for what ?
Posting a link to your stuff is not bouncing ideas.
Car: 92 Camaro
Transmission: auto
Re: 84 Z28 LT1 Swap
Me and Logan go way back. (went to Iraq a few times with him)
I had that LT1 at my house for a bit.
I'm doing the same swap this winter in my 92.
Before Jay pulled the motor out of his 97 I had already gotten a long block but not much else. Jay let me have some of the parts before Logan sold it too you I guss. (Small world)
I got alot of part's that I've been saving up and have extra stuff. (fuel rail wiring and small stuff.
Let me know if you need anything I travel to Fort Knox every week and drive to Nashville everyweek also.
There also are a few Z28 at the local pull a parts if you need me too look for any thing 4 u.
Re: 84 Z28 LT1 Swap
Car: 93 240SX
Engine: LQ9
Re: 84 Z28 LT1 Swap
If you wanted the pinouts for it:
The light blue wire connects to the a/c pressure switch, it originates at the a/c control panel, goes to the a/c cycling switch, then its output goes to that connector and on to the a/c compressor.
The large red wire provides power for the high speed blower relay.
The ground grounds the blower.
Theend.
Edit: the one in the above picture is from a V6 car, they use all 4 slots, where the V8 cars only have the above 3 wires.
Theend.
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Re: 84 Z28 LT1 Swap
Before Jay pulled the motor out of his 97 I had already gotten a long block but not much else. Jay let me have some of the parts before Logan sold it too you I guess. (Small world)
got alot of spiders at your place? lol, the intake on that thing was full of em.
That'd be great! if you ever find an undamaged lt1 harness let me know. the last time i was at pap there was only one lt1 car and its harness had been cut up. :[
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Re: 84 Z28 LT1 Swap
The end.
The end.
I'm probably not going to be running A/C unless I can find Vette brackets, or save up enough to get a tubular K-member. so power for high, and ground is all i need for now, just need the stupid connector! ha.
I suppose if all else fails i could just stick some spade terminals in there, but that would look tacky.. and tacky isn't my thing.
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: 84 Z28 LT1 Swap
Honestly if your even considering AC id notch the kmember while the motor is out. I neglected to do mine now im kinda thinkin AC sounds nice. lol. With a welder and a grinder it can be only about a 2 hour job and be very cost friendly. No need for a tubular Kmemeber just to have AC.
BTW comin along good, props for tackling wiring by yourself, that ***** a nightmare.
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Re: 84 Z28 LT1 Swap
I might do that instead... I'll have to find a welder though lol.
Wiring isn't too bad ;] I rewired that entire engine compartment on the truck in post #18 And Chrysler wiring is alot more complicated than GM stuff
Update from the Machine Shop, Their hanging the new rods on the pistons, and are going to balance the rotating assembly today. Whoo!
(stock crankshaft, Scat Forged I-Beam rods, and Sealed power coated pistons 4.030")
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Re: 84 Z28 LT1 Swap
Got some stuff done in the interior.. New shifter in and a new E-Brake handle..
Anyone know what this style brake handle is from? I've never seen one before but just had to have it when I saw it on Ebay.
Also, If anyone has a shifter plate like this.. And would sell it cheaply..that'd be great!
#42
Car: 92 Camaro
Transmission: auto
Re: 84 Z28 LT1 Swap
I got a complete center and plate out of my 92. no cracks just a little dirty. free to a good home
#44
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
#45
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Re: 84 Z28 LT1 Swap
Update: Got a bunch of goodies today!!
Got my engine from the machine shop!
A relatively new opti, some custom made 8.8mm wires.
And a 4L60e with a 2400 stall converter.
http://i87.photobucket.com/albums/k1...1-15185125.jpg
http://i87.photobucket.com/albums/k1...1-15184010.jpg
http://i87.photobucket.com/albums/k1...1-15183656.jpg
http://i87.photobucket.com/albums/k1...1-15183553.jpg
http://i87.photobucket.com/albums/k1...1-15170545.jpg
http://i87.photobucket.com/albums/k1...1-15185216.jpg
#46
Car: 93 240SX
Engine: LQ9
Re: 84 Z28 LT1 Swap
Going to make for an awesome setup, even when it doesnt have 500HP, a fresh engine to start with and know exactly whats what, is an awesome feeling.
#47
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Re: 84 Z28 LT1 Swap
Couldn't agree more. I'm a strong believer of the saying "Built, not Bought"
IMO It's a lot more fun when you build it yourself, instead of someone else doing it for you.
#48
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Re: 84 Z28 LT1 Swap
Found out a couple things today about my new trans...
the Converter is a Bradco 2400 stall. And the trans itself is a 94 :/
What all would I need to change on it to run properly with my 97 lt1/ecm??
Just the solenoids/Wiring? or does the valve body need to be changed too?
#49
Car: 93 240SX
Engine: LQ9
Re: 84 Z28 LT1 Swap
Where are you coming up with it being different ?
IIRC 94-97 are all the same, 93's are "4L60" no E, which was really just a renamed 700R4.
#50
Car: 1987 Iroc-Z28
Axle/Gears: 3.27 LS
Re: 84 Z28 LT1 Swap
the PWM change in 95 is what i'm referring to.
Edit: It seems that all I need to do is disable the PWM functions in the PCM's trans tables and all is well.
Forgive me, GM transmissions are not my strong suite lol
