Full ls1 swap (drivetrain, interior, brakes, everything!)
I need help and advice on a bunch of different things. I have a 92 RS that was my first car that i bought in highschool. I have redone it but i am doing it again and not on a highschoolers budget. I bought a 98 Z28 and i want to strip it down and put everything on my car. I have the adapters on my 92 with c5 rims but i want to use the spindle and hub of of the ls1. I want to use the rack and pinion and everything. I plan on ordering a tubular k member but i dont know what for sure i would need i.e. 4th gen a-arms with a coil over kit or what. I am also doing the ls1 dash, center console, seats, fuel tank, fuel pump, just any and everything i can. So any know how or anyone who knows whether or not any of the brake and suspension work i want to do is even possible please let me know. Any info would be greatly appreciated. Thanks everyone!
Car: 1987 camaro sc
Engine: lg4 305
Re: Full ls1 swap (drivetrain, interior, brakes, everything!)
everything is possible except for using the ls1 spindles steering and front suspension
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
What id do if i were you is get some aftermarket a arms and reuse your stock spindles and modify those to fit some c5 brakes as its much easier than trying to use ls1 brakes.
Dash, center counsel, seats, rear end, gas tank will all swap over without to much trouble. Door panels have been done but are.. more difficult to put in than the dash and counsel were. Most of the interior trim from the fourth gen will be harder if not impossible to adapt to your car.
If i missed something or you had another question, let us know!
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Adapters are available to put the LS1 brakes on a 3rd gen. Some spindle & hub mods are necessary though to do it.
http://www.bigbrakeupgrade.com/index.html
thanks guys. I just ordered the big brake upgrade kit. Im going to modify my factory spindles. Im still trying to figure out what headers to go with and a few other things. I think im just going to start by getting the interior done first with all the wiring ready so i can just throw the ls1 in pretty quickly and then just be done!
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Engine: cammed LS1
There are nice mid-length headers out there that you could go with that some others have used on this site
Ghettobird52
07-05-2024 11:18 PM
colton_carlson
03-08-2019 12:21 PM
