1992 Z28 LQ4 swap
Car: 1992 Camaro
Engine: 6.0 LQ4
Axle/Gears: 343
1992 Z28 LQ4 swap
So I had this car in high school. A 1992 Z28 Camaro 25th Anniversary black w/ red stripes. Needless to say driving was a blast in high school. 6 months after graduating high school I blew the worn out 350 TPI . Well here I am 5 years later just having graduated college and I have finally started amassing parts to bring the old Z28 back to life.
I have just purchased a complete lift out 6.0 LQ4 (engine, computer, harness, pedal, TAC module) through LKQ w/88,xxx miles out of an 01 Silverado, Fbody LS1 oilpan+ windage tray+pickup+new gaskets, new GM clamshell LS mounts, Spohn polyurethane bushings, Spohn LSX adapter plates, 4th Gen F-body fuel tank, 4th gen F-body coolant tank, torquer V2 cam, tsp 7.400 pushrods, beehive valve springs, stainless hawks LT headers 1-3/4 primaries, 4L60E out of an 00 Z28, Circle D 3200 stall torque converter, all the air conditioning components , all accessories and brackets out of a 4th gen Fbody, new water pump, alternator, power steering pump w/ reservoir, harmonic balancer and bolt, ARP header bolts, LS7 lifters, every gasket on the damned engine, comp cams rocker trunion kit, LS1 intake, LS1 Injectors, LS1 fuel rails, I'll keep updating this list.
I am planning on using and abusing the stock 700r4 until she gives out and will eventually build up a 4l60 or 80e for it. (That was the plan when I started this thread but have since bought the 4L60e.)
I work at my family business which is an automotive repair facility specializing in exhaust. I will be getting the Hawksthirdgen long tube headers(got them) and using out mandrel bender to build custom exhaust. Hopefully true duals but I am probably just dreaming
I will start to post some pictures tomorrow of the car and what not but for now I am excited as ever to get a start on my ride!!!!!!
Car: 92 Z28 Z03/89 IROC
Engine: MIA/mild 350
Transmission: MIA/T56
Axle/Gears: 3.28/3.73
Re: 1992 Z28 LQ4 swap
nice car and welcome, take a lot of pics, hope to join you lsx guys soon
Car: 1992 Camaro
Engine: 6.0 LQ4
Axle/Gears: 343
Got the car uprooted from our shop and to our house.
LQ4 complete pull out w/ engine, computer, wiring harness, and gas pedal/TAC modulej; $1600
Dummy LS block for mock up.
Old Clamshell mounts that were mounted to the frame
New GM 98-02 LS1 Clamshell mounts w/ stock bushings taken out and replaced w/ new polyurethane bushings from spohn and will mount to the bottom of the block.
Dummy block fits perfect
Car: 1992 Camaro
Engine: 6.0 LQ4
Axle/Gears: 343
Hugging the transmission
Motor almost stripped down to where I can clean all the grime off
317 head casting
317 head casting
Welcome to the lsx world lol.Lq4 with longtubes should serve you well for a nice daily cruiser.I wish I took the time to really clean my block before dropping it in,take your time and it will turn out perfect.Keep us posted and good luck on your build.Nice car to start with.
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Take your time with the swap and it should turn out real nice. Seems like most people start out wanting to use their 700r4 at the start of their swap, but end up using a 4L60e before it's all said & done. Do your homework on it.
What kind of lens do you have on your camera? It looks like it's convex or something. Some of your pics seem distorted.
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
If you have access to an exhaust shop I'd recommend making your own headers! It's always nice to do something yourself and save some cash IMO. Clean that block up too. At least tear it down and re-ring it. Just following torque specs it'll go back together in no time. Plus a pressure washer and some paint will make it look 10X better when you open your hood.
What front accessories are you using? What harness PCM combo? Intake? AC? Cruise? I've a '91 so more power to ya!
Car: 1992 Camaro
Engine: 6.0 LQ4
Axle/Gears: 343
Car: 1992 Camaro
Engine: 6.0 LQ4
Axle/Gears: 343
Engine: cammed LS1
Nice Any progress in the last two weeks?
Car: 1992 Camaro
Engine: 6.0 LQ4
Axle/Gears: 343
Will have updated pics tonight.
COTM Editor
Nice build! Your car is the t-top version of my vert... Looking good
Car: 1992 Camaro
Engine: 6.0 LQ4
Axle/Gears: 343
Have done some serious work here in the last two years lol! Car is coming together. A long list of pictures and comments to come hopefully later tonight!
Car: 1992 Camaro
Engine: 6.0 LQ4
Axle/Gears: 343
I used your thread a ton while amassing parts and planning by build!
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
Hogan Muffler and Brake. www.hoganmuffler.com
Car: 1992 Camaro
Engine: 6.0 LQ4
Axle/Gears: 343
Absolutely do so! My name is Joshua. I'd love to see your car as well. Question too: You drilled a 2" hole under the HVAC box and mounted your pcm under the dash is that correct? If so do you have any pictures of when you did that?
Car: 1992 Camaro
Engine: 6.0 LQ4
Axle/Gears: 343
Evolution of the motor from greasy pullout to nice clean LS ready to drop!
Pull out 6.0 in all of its greasy glory!
Starting to tear her down
Hole drilled to facilitate alternator bracket
Front Accessory drive on for mock up purposes.
Nice tight fit on the alternator after drilling the hole and installing the bracket
Degreased......ish
Decided to paint the block black
Degreased......ish
Car: 91 Z28
Engine: 6.0L LQ9
Car: 1992 Camaro
Engine: 6.0 LQ4
Axle/Gears: 343
Primer on the intake, p/s bracket, and alternator bracket and then black paint.
Under the valve cover
Under the heads
88k worth of Kansas gas lol
Black Block
Underside with truck windage still on
Broken down
Under the heads
Black Block
Broken down
Car: 1992 Camaro
Engine: 6.0 LQ4
Axle/Gears: 343
Camshaft TSP Torquer V2
Who wants a black block??????????????????? I don't know what I was thinking so Chevy Engine it is!
Timing cover painted and back on after and LS2 timing chain and new oil pump(I believe LS2 as well, Melling pump)
One head back on
Help from a friend
Two heads back on!
Heads were cleaned up, new valve seats, springs, etc. installed.
Going to need an injection cleaning once she is running lol
Back together w/o the ac on
One head back on
Help from a friend
Two heads back on!
Engine: cammed LS1
Nice progress *****! Is that a Chevelle in the garage beside the engine on the stand? Are those new head bolts? Did you install better rods bolts? I've heard the stock rod bolts are the weak link in the bottom end on these engines. Keep up the nice work.
Car: 1992 Camaro
Engine: 6.0 LQ4
Axle/Gears: 343
68 Chevelle Convertible 427 5 speed dual carbs But that is my pops' project. They head bolts were new yes but I left the stock rod bolts. Hopefully all will be fine :/
Car: 1992 Camaro
Engine: 6.0 LQ4
Axle/Gears: 343
Notch in the crossmember for some oil pan clearance. Would have been reallllllly tight without it but probably would have fit.
Progression of the notch in the crossmember for the A/C compressor
[IMG]http://i1054.photobucket.com/albums/...520_212748.jpg[/IMG]
Boxed up
Painted up
Engine bay is almost ready to accept the motor
Boxed up
Painted up
looking forward to watching this build. i just came in possession of an 88 iroc-z and am planning on doing an LQ4 build. psyched to see the progress of this.. especially as ill soon be following your steps!
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
I've research alot on this and what I gathered it's 50/50 rod bolts my blow or may not spinning around 7000 above and beyond some dont have issues others do
rod bolts are the weak point I upgraded my rod bolts to arp if your block is apart it's cheap insurance , but if block was taken apart I probably wouldn't bother and use a blown rod as excuse to get better block lol
