anybody get creative with accessory set up for our cars?
1 Post
Car: currently 91 camaro
Engine: soon to be 350 turbo
Transmission: soon to be 4l80e
Axle/Gears: 99 ss rear end with richmond 4:11's
I'm thinking about using an electric power steering pump for my ls swap. then just making my own bracket for the alt. has anyone else done something different for the accessories for these swaps. mine is twin turbo's and I'm trying to make as much space as possible for the turbos.
1 Post
Re: anybody get creative with accessory set up for our cars?
nobody ?? was it a dump question?
1 Post
thanks robert. ya i want to do something nice. my goal is to keep it from looking crowded like a lot of builds i've seen.
1 Post
well my last camaro had no power steering pump and that was kind of a bother. i was thinking on doing an electric pump tucked up somewhere under the battery tray area on the drivers side. but doing the turbos i want to keep the accessories as close to center as possible so i can have more room for the turbos. i just have'nt found any pics of much other then the stock set up for them so far.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I have all custom brackets cncd' by a friend, no power steering. If I knew the truck bracket would work like I do now, I would have not threw the s10 steering box on. I am probably going back to a truck setup in the future. Since I drive it on the street and not to the track these days, may as well.
1 Post
1 Post
*sigh* it just seem like it will be a tight fit if i try to put tha power steering pump on there with turbos. i think i'm really going to try the electric pump and try to locate the alt down low somewhere.
thanks a ton for you pics.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
No problem, I have seen plenty of lots out there, custom and ect, you will get it figured out.
