Lets rebuild this Ls2
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
well long story short no.7 cylinder went lean and the piston grenaded inside the chamber and messed up the head (not beyond repair) but its still a sore to see. already bought a new piston, rod, rings, and bearings for the one cylinder and i plan on putting it back together, cylinder looks perfect. Ill be sending the one head back to t.e.a to have it fixed... also sold my 230/238 .600/.604 112+2 eps cam and bought a slightly bigger one 239/246 .624/.615 112+3.. we will see how this goes
Car: '85 Camaro
Re: Lets rebuild this Ls2
Damn....after that long wait on getting the heads, this happens. Sorry to hear that man. But now, time for bigger and better things
Oh just curious, how did it run lean? Wasn't your car tuned?
you lucky devil, how did that thing not destroy the cylinder?!
going back to an auto and a bigger cam....that little sc is going to be a rocket ship off the line.
Engine: Cammed 6.0L LSX
Looks like you might have a valve kissing the piston on the cylinder to the left?
Car: 1986 camaro
Engine: ls2
Yeah I know im a lucky ****... But the reason it went lean is my tank is not sumped and I had roughly alittle more than 1/4 of a tank and was doing a 1-2-3 to see if I had finally gotten my tick master adjusted right when at the top of 3rd it poped 3 times and I shut it off... Guessing it didnt have enough fuel and leaned out, or an injector stopped working because none of the other cylinders or plugs look to have ran lean. Also the kissed pistons yall see are from my old 317's I had, the heads were shaved .040 and the valves touched the pistons on each cylinder.. I had the cam ground from a known cam expert on ls1tech but nothing was hurt so all was well, no sharp spots to cause excess heat.
Car: 1986 camaro
Engine: ls2
well i have decoded to just bore it 4.005 and use the stock rods and autotec pistons. head is currently at t.e.a getting fixed and the new camshaft should arrive monday
Car: 1986 camaro
Engine: ls2
6.125 scat rods and my trickflow head came back from T.E.A. today...
