CTSV OIL PAN FITMENT PICS!
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
1' set back plates
jegs sbc solid mounts
6.0 lq4
stock k member (No cutting or notching)
pics are not the greatest, there is plenty of clearance, but it gets the point across.
fits like it is made for it!
6.0 lq4
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Re: CTSV OIL PAN FITMENT PICS!
Holy **** nice find! Didn't think there was any other that fit. And no need to cut it is even better. A/c compressor still doesn't fit without notching though?
Im guessing it also doesn't fit with lsx swap mounts? And also how far back would the motor sit compared to the 'normal' lsx swap mounts?
Hanging that far below the k-member wouldnt work for me. Even if I wasnt lowered. I dont think my k-member clears a beer can like that either..? Whats going on with your suspension?
Did you just set it on the ground or just get weight put back on it? Kinda looks like your a-arms are angled down more than they should be. If that is the case, move the car in/out if possible and see what the clearance to ground is then.
Not diggin on ya by the way...I just know that my k-member has taken some smacks from road debris like rocks and such and has probably saved my oil pan numerous times. Im lowered a bit though...and honestly cant remember what its like under a stock suspension f-body haha.
Otherwise looks great!! Lots of room around the k-member!
J.
J.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
yeah, i have scrapped the stock k on the crown of some local roads, that would be a disaster with that pan. Fits nice, but i do not like that it sits that low
COTM Editor
Received 1,922 Likes
Car: '89 Firebird
Engine: 7.0L
Not going to seem like such a good idea after the first thing you drive over wipes out your oil pan.
Trick springs up front .no coils cut off. Car is settled
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Too low for my tastes too... I believe buying the f-body pan would be a wise investment for a street driven car.
there is a trans in it lol look closer
Hahah Im looking closer. I mean...if you say there is Im sure there is haha. I see what might be the oil pan? But at first I thought that was the other side of the subframe. Didnt realize it would leave that much of the flexplate or block exposed.
Its a th400. Don't know what im gonna due about a child under the flywheel. These ls flywheels are alot bigger diameter.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
I didn't say there wasn't one, I said I didn't see one...
I suppose if you know what you're looking for, you can see the tranny pan in the 3rd pic.
You might want to look into using the LS-type 4L80E lower cover, modified to fit the TH400. It would allow you to pick up those two bolt holes in the pan to support the bellhousing (which is missing one bolt due to the LS configuration).
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
its got great clearance around the k-member for sure, just hangs too low for me too be relaxed...i would drag before i hit paved road for sure.
thanks for the pics!
gixxer92
09-01-2015 04:32 PM
downsouthboy
08-29-2015 11:29 AM
Navy8125
08-21-2015 09:32 AM
