Painting ls1 intake
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 88 trans am 72 olds cutlass
Engine: soon to be 5.3 455 olds
Transmission: soon to be t-56 2004r
Axle/Gears: 3.23 3.73
Painting ls1 intake
Is there a certain paint everyone is using to paint their intakes? Any certain prep that needs to be done? Should i use plastic paint prep? I want to paint my valve covers the same color so id like to use 1 paint for both. Its gonna be graphite in color to match the stock mesh wheels on my trans am thanks
Re: Painting ls1 intake
Sounds like you and I have very similar ideas. I'm planning on painting my valve covers and intake the same graphite color. ![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
In the past, I've cleaned my plastic parts with a little bit of brake cleaner, followed by some primer and my paint of choice, and I've never had any problems with adhesion.
I painted the 4th gen battery hold/ coolant overflow by cleaning it with some brake cleaner, then sanding it with a scotch pad. Then I gave it 2 light coats of adhesion promoter. Let dry for a few, then couple coats of primer. Dry, then color. Looks good
I plan to use similar process on intake and valve covers. I seen a thread over at tech that I used. They also used clear on the intake.
A super good bath first..then scotch pad..bath again..let dry very well.Some would just base clear it like that with high heat paint and looks good.Taking your time is what gives a great rattle can job.First coat should be misted on..flash time of 15-20 mins at room temp atleast..then second coat a lil heavier to bring the color up...flash again 15-20 mins.then a third final cot to even things out..by this point you wont even see the grain of the intake itself..it should look like it was sanded and prepped by hand lol.I always suggest clear coating it aswell with high heat paint..doesnt have to be gloss clear..this is where ppl go crazy and mess up is by spraying heavy cleat right on and it builds up to a thick mess with runs.
thanks for the help i will try it out this weekend and take some pics when its done.
1 Post
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Everything 86white_t/a305 said is the way to go man as I did mine a few months back and they turned out pretty good. Heres a pic of them
![Name: IMG-20111109-00096.jpg
Size: 59.4 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/376192d1501392178-painting-ls1-intake-img-20111109-00096.jpg)
![Name: IMG-20111110-00097.jpg
Size: 72.9 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/376193d1501392178-painting-ls1-intake-img-20111110-00097.jpg)
1 Post
Car: 89 IROC
Thats sounds like it will look good
yep what 86white and triple 6 said. i used ceramic engine paint, and with any paint job, it's only as good as the prep you put into it!
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
I sanded mine to get rid of the mold marks and give the primer something better to stick to. I dont see any reason a quick scotch, prime and paint wouldnt do the job
Now look what you guys made me do lol.I couldnt resist..plain black ls6 intakes just dont cut it for me.Now I need black corvette rail covers,paint the motor in a red and black color scheme.
I used high heat flat red engine enamel by vht.Got it at my local parts store "Canadian Tire" but any Nappa or Autozone etc would carry it.And 2 coats of clear.Im thinking I might paint the whole motor in this color to match my car.Under the hood is all gloss black already..would stand out.
1 Post
Car: 89 IROC
2 LS6 intakes. Dam. If you ever sell one let me know as the back vaccume port on mine was appoxied to hell to seal it. Dont know how much i trust it as the previous owner was gonna run it the way it was
My spare ls6 intake had the rear port plastic welded and epoxy sealed then pressure tested.Its quite common for guys to break them trying to take them off and paint the intake or replace the seal.I bought the ls6 intake before I found my lq4 with an ls6 on it already..double score lol.
ambainb
04-25-2016 09:21 PM
