82z28 350 to lt1
82z28 350 to lt1
sup guys new to this forum. ive got an 82 camaro and been wanting to do a lt1 swap...i want to know what i will need...lets say i got motor/pc/harness.....will i need any other mods to make the motor sit and run...like motor mounts etc etc....thanx in advance
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: 82z28 350 to lt1
browse throught the ltx/lsx swap subforum. the motor mounts are the same, and your v8 trans (im guessing you already have a v8) will bolt right to it. however, it wont be a straight "drop in, tighten down the bolts and go" swap.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Welcome aboard thirdgen.org.
Start by reading the LT1 swap sticky in the top section of this forum.
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Or if your low on cash do it yourself, it's so easy even a cave man can do it. Thanks to pockets write up along with a other hundred threads.
Hotrodboba400
12-10-2019 07:07 PM
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
New2Chevy
09-28-2015 12:35 AM
