Water pump / steam line mod
1 Post
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Has anyone done the mod and has pictures or info on it. Im looking for any links on here but cant find anything that really explains it. If you can help me out that would be appricated. Thanks
Re: Water pump / steam line mod
You drill and tap a barbed fitting to the flat spot over the upper port. Nothing special about it
Be careful because the alum is very thin there and easy to strip. A 90* fits best
Alternatively if you have the stock 3rd gen radiator, check the heater core return port to see if its threaded. If it is, screw a barbed fitting directly in there and run the steam line to it. Saves you the trouble of permanently altering your pump
Engine: Carb'd LT1 w/ a Cam :)
Axle/Gears: Moser 9" w/ 3.75 gears
And Pocket...his waterpump doesn't have a flat spot over the upper port.
1 Post
Car: 89 IROC
LOL i know you did just trying to get ahead of the game before the snow falls.
1 Post
Car: 89 IROC
well I did the mod and since I havnt seen a water pump like mine on here I thought id share some pics of how i did it. Notice the top of my pump is rounded and not flat like a average LS fbody water pump. Heres some pics if anyone needs to know how to do it in the future
1 Post
Car: 89 IROC
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
The part I posted is the actual part I ordered and used on my Holley fuel pump. It's a 3/8" NPT to 3/8" barb but you can find them in any combo. Remember to use the correct NPT tap and a little Teflon tape.
The key is to tap the hole progressively larger and test fitting your fitting so that it seals at the angle you want it to. Meaning so that the barb is pointing in the direction you want it to while still sealing properly.
1 Post
Car: 89 IROC
Do you have a port just under the overflow port? If you do mine came plugged when I bought it last year. Its a rubber cap with a hose clamp on it. If you need to plug it just use a piece of hose and a bolt in one end with a couple hose clamps.
heres a pic of mine with the 3rd gen rad. Only pic I got at the moment
Heres a pic of the waterpump on the car just got to get a longer hose to connect them
Thats what I have there a port im trying to connect it to the steam tube but its unthreaded and I want it to be decent no jb weld lol... I Might try and look for a tee or some kind of reducer
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
what i did for mine was put a short piece of rubber hose on the port on the rad and put a brass fitting in it with a nipple on it and some clamps and ran my steam line to it. i can get pics if you want.
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Here's my idea for it.
I found a tee at the auto parts store that should work nicely. I used a short rubber nipple between it and the radiator, run the steam line to the smaller side and will cap off the other side of the tee. It probably won't look all that great, but should do the job nicely.
1 Post
Car: 89 IROC
It will do the job yes and as long as you dont mind the ways it looks who cares. I did mine with the water pump MOD as I cant stand having lines, tubes, wiring ETC going all over the place. It drives me nuts and in my mind makes my motor look cheap. Thats just me and maybe im too **** for my own good
Car: Camaro
Engine: 6.2L
Attachment 230302
Attachment 230302
Engine: cammed LS1
Even with clamps? I'll have to check, but I thought it was a heater hose tee for... "the F word". Um, a Ford product
I'll go get some pics of what I did on mine
here ya go
used something like this
1 Post
Car: 89 IROC
that looks like its a pretty solid solution if you dont want to drill the pump for sure.
Car: Camaro
Engine: 6.2L
The vacuum cap where I put the arrow will blow right off its not going to work. You can either put a bolt into another piece of hose with clamps or get an elbow etc but that little cap will not work
Engine: cammed LS1
Oh. Yeah, I just put that cap on there to keep the debris out. I'll put a hose type cap on it when I get it in the car. Thanks for keeping an eye on me though
Engine: cammed LS1
Going to thread a hose barb into the side?
1 Post
Car: 89 IROC
Car: 91 Firebird
Engine: 6.0
Ok, here is what I came in the mail from Summit
Autometer radiator hose adapter part #2282 ($50 shipped)
I had to go buy a 3/8 to 1/4 npt adapter, then a 90 to get what you see here. ($15 at Ace Hardware)
then found a suitable place that didn't interfere with my CAI and cut the hose there. I am using the stock 4th gen upper hose. Cut out about 1/2" to get it perfect.
now surprisingly this made filling up motor with coolant very easy. I disconnected the adapter, and just pivoted the upper hose thats still attached to the waterpump straight up, and filled the block. The air came up the steam tube, and once coolant started running out of the adapter, I stopped and connected everything. Added a little more to the radiator and I was done....
Car: 91 Firebird
Engine: 6.0
I still had to add some coolant after I fired up the motor..... had to burp the heater core too..... still, a lot easier than the last time I replaced the water pump two years ago or so....
the adapter is above the TB, and it is upstream from the motor too. I am really happy with this so far and it seems to fit a lot better than the ls1 radiator I was using. Just a cleaner look for me.......
Last pic
Last pic
1 Post
Car: 89 IROC
I like there are a few options now in this thread for everyone to try. I will try to get a pic of mine tonight when I finish it as I just got some line today for it
1 Post
Car: 89 IROC
Heres mine done. To me its super clean and you wont even see it as thats what I wanted
Car: 1988 Camaro IROC
Axle/Gears: 3.70 Borg Warner
Hey guys, I am looking at my steam tube options, does drilling and putting a fitting on the water pump actually work? I would think that is creates a mixing flow in the coolant...no?
I wouldnt recommend it. Its a steam line to relieve hot spots from the 4 corners of the cyl heads and greatly aids in bleeding the coolant system. It does show some promise in the design
Id grab two of them for a 4 corner setup, then cut and tee the crossover lines. Port it to the WP like shown or radiator
#42
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
This is the best solution, IMO.
Wish I would have know about it before doing my swaps. It's what I'm going to be using in the LS swap in the '57.
#43
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
Last pic
Last pic
I know this is old, but did you still drill and tap your water pump? I like the set up you went with, I just dont want to have to drill into my waterpump if I can avoid it.
#44
Car: 91 Firebird
Engine: 6.0
Nope, I did not drill my waterpump
I specifically wanted to avoid that route just in case I am out of town with the car and the waterpump craps out on me........ I usually carry enough tools to change a waterpump, but not to drill and tap one.... lol
#46
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
#49
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
Yeah I had it narrowed down to 1 or the other, ill probally just use the radiator port and be done. Thanks everyone.
#50
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I tapped the bottom of the water outlet by the thermostat, that way the steam is pulled into the radiator and if I need to change the pump, I can do it without having to modify it. Don't need to change the outlet too often. I bent a nice piece of 1/4" stainless tube to go under the TB then down along the WP then down and around the outlet, but behind the nipples for the heater. If you weren't looking for it, you would never know it is there. I wanted to keep from putting another hose/tube to the radiator
