make your own 4" maf
Old 08-16-2011 | 08:18 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
instead of buying a tsp, lingenfelter, etc. maf and housing I went the cheaper way.... spectre 4' maf housing 9705 (34.95), ebay ls7 maf (49.95), and an ebay pigtail (21.95)....ends you with this
Old 08-16-2011 | 08:36 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
re: make your own 4" maf
I just had mine tuned out.
Nice DIY though
Old 08-16-2011 | 08:43 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
i had mine tuned out also... major pita for myself! cant even change the airfilter without it affecting the tune..
Old 08-16-2011 | 10:02 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Wow this may be something I need to do this winter. My whole cai is 4" except for where it has to step down to the 3 1/2" or 3 1/4", whatever it is, stock truck maf.
My tuner had mine tuned out the first go around also, but the start up issues were annoying, couldn't get it to be reliable on a cold start.
Old 08-16-2011 | 10:45 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
damn more stuff to buy haha
89ROC-Z's Avatar
Car: 89 IROC-Z
wait will the ls7 maf work on the gen3 ecm? 0411
Old 08-17-2011 | 12:04 AM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Yes it will.. Just needs to be tuned for it and have the correct maf table.
Old 08-17-2011 | 01:33 AM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Added a link to this thread in the LS1 swap sticky.
Old 08-17-2011 | 06:40 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
very cool, and noting for my own setup in case of future upgrades
Old 08-17-2011 | 07:44 AM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
I see no reason paying 200+ dollars when you could put together the same thing for 100...
Old 08-17-2011 | 10:55 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
One question? Wouldn't a 4' (foot) MAF go half way into the cabin of the car?
On a serious note, that looks like a great alternative.
Old 08-17-2011 | 12:11 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
It hides well! Ha ha. Ill take pics of the inside also
Old 08-17-2011 | 02:04 PM
BlueZee28's Avatar
Is there a way to use that Spectre housing and a stock truck maf?
Old 08-17-2011 | 02:20 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: make your own 4" maf
doubtful without a lot of chopping. the ls7 is a "card" type maf and does not have the tube integrated with the sensor like the 85mm truck one does
Old 08-17-2011 | 03:20 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
The ls7 sensor does have an internal iat sensor.. But id relocate say a stock ls1 sensor into the start of your cai to avoid the aluminum heat soaking the sensor and giving a false iat reading
Old 08-20-2011 | 11:29 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Does the ls7 maf have the same plug/wire configuration as the 5 wire truck mafs?
Old 08-20-2011 | 11:53 AM
Iroc'nthe87's Avatar
No
Old 08-20-2011 | 01:27 PM
Pocket's Avatar
Car: 91 Trans Am
Engine: LSA
Transmission: T56 AWD
Axle/Gears: 8.8 4.10
Different connector, same number of wires/function and pinout
Old 08-21-2011 | 09:55 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
Nice work. I'll be copying that on my Lq4 s10 build.
Thanks,
Kory
Old 08-25-2011 | 09:46 PM
jamieschott's Avatar
Nice Mod! Note taken.
Old 08-25-2011 | 09:49 PM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
thats a cool mod, i myself am figuring out my air intake dilemma right now, im trying to run a RAII hood with matching box made for it and i cant seem to find something that works right. i saw the blueish vert bird that guy made using a whisper lid, fiberglass etc etc but i havent worked with fiberrglass yet. im starting to look through my yard for other types of OEM airboxes, gm, euro and japanese to find something. frustrating.
Old 08-29-2011 | 01:26 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
I myself didnt like the polished look so I painted mine black.
Old 08-30-2011 | 04:45 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
For anybody that does this, just be advised that without a tune from a shop that's got the talent to build a custom MAF table, chances are your performance will suffer drastically. It's not likely that a shop will just be able to copy an LS7 table due to the different air path in this configuration, but at least that might get you into the ball park. Either way, running this setup with your existing tune is not likely to provide the best results.
Old 08-30-2011 | 05:11 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Powermaf has the change over voltages. And I believe it would provide ALOT less airflow resistance. A good tuner can do the changes easy.
Old 08-30-2011 | 09:12 PM
Jim85IROC's Avatar
Agreed. I just don't want somebody to do the mod then find out he needs a $500 tune to make it function properly.
Old 10-24-2011 | 08:50 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Just thought Id add in some GM part numbers. I ordered mine through GM Parts direct and Ive added the PN's and the ( as of today ) price below. I went for this instead as I dont want so many couplers in my system I am only after the bung and will weld it into the pipe itself so I'll only have the silicone elbow from the TB around to the piping then filter. Nice and neat
Bung: PN 19166574 and it runs $9.27
LS7 MAF PN: 15865791 and its $55.52
Old 10-25-2011 | 08:09 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
not a bad price, considering I paid around $60 for a used truck MAF (85mm) and the stock LS1 fbody ones seem to go for over $100 on ebay
Old 10-25-2011 | 08:47 AM
Damnit Dan i got'em for $40! lol
Old 10-25-2011 | 09:11 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
hey, i was young and dumb, i know better now (ok, so maybe it was like a year ago)
Old 07-14-2017 | 07:36 PM
86IROCZ28NDC's Avatar
hey man I have a question about your maf sensor. Your saying this will work on a 86 camaro and which pigtail did you buy. I just built a 350 too motor for my car and have a custom tune and I feel like my stock maf sensor is holding my motor back and wanna upgrade it
chazman
08-28-2018 04:25 PM
trevor1010
08-26-2015 03:41 PM
trevor1010
08-24-2015 09:34 PM
trevor1010
08-24-2015 12:29 PM
Bert87
08-23-2015 04:50 PM
