Breaking up
1 Post
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Breaking up
Is it possible that a TPS can cause an LT1 to break up at lower RPM's? The car doesn't do it unless it is 1) warmed up all the way and going into closed loop or 2) is really hot outside no matter how long it has sat. So I changed the ICM thinking it was breaking down when it got hot, and it's fixed a little but still breaking up bad. Now I haven't had a chance to run the codes yet but if I hold the throttle in a certain place, I can trigger the SES, let off the gas or increase it a little bit and the light goes out. When the SES is on, the car runs pretty good. I'm hoping it's not the opti, but a local hot rod shop has opti's in stock at a decent price (they normally don't carry junk) but before buying an opti, I wanted to get some opinions on the TPS.
1 Post
Car: 1987 GTA
Re: Breaking up
From what the codes show I've got one o2 that's running lean, and it's showing a MAF fault (don't know if that is from where I unplugged it last week or not for a bit to test). I'm going to throw a stock tune on it set to SD mode to eliminate the MAF and check with my scanner to see the TPS values, I looked at it yesterday with it running...duh you can check from 0-100% with the car running, but the spark advance was showing great...up to 45* advanced...sitting at 25* at idle.
1 Post
Car: 1987 GTA
Re: Breaking up
Yeah, I ment that you can't really check with it running (was sitting in the driveway). I'll go from there and see what happens, thanks again Pocket.
1 Post
Car: 1987 GTA
Re: Breaking up
Well, looks like the MAF took a dump. Set my tune to a SD setup and it's running just fine now. Guess I'll be searching around for a new MAF and hopefully running it in SD won't affect my gas milage too much.
UltRoadWarrior9
04-28-2020 10:39 PM
sjorgens
10-01-2015 07:54 PM
