Magnacharged LS1 IROC results
Just finished up my Maggie install. Motor is a bone stock 99 LS1 crate motor, 6 speed trans and a ford 9" with 4:10 gears through a full GMMG exhaust. I was pretty happy with the results. 440hp/441tq Check out the torque curve...err line...lol. The tuner suggested I switch to some LS6 valve springs due to the valve float you see at the end of the graph. Motor never ran out of fuel. With all the down low torque that the blower gives I'm definatley going to have to change gear ratios though.
Dyno Video
http://www.youtube.com/watch?v=GSiGzpxuKgM
Dyno Video
Re: Magnacharged LS1 IROC results
Awesome results! Those 4:10s and the magnacharger gotta be pretty rough on the rear tires. You could probably take off from a dead stop in 4th gear lol.
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Nice! I want a whipple for mine. What iat's are you seeing fully warmed up?
Wipples are nice units for sure, just a bit more pricey than I wanted to spend. IAT temp varies. Going down the road they sit around 100-110 so far. Letting it sit at idle in the garage with the fan on they will creep up to 125ish. Under full boost they will hit 150-160ish. At 160 it will start to pull timing. These numbers are completely normal according to the guy that tuned it, and he has quite a bit of experience with these blowers. Keep in mind..the IAT sensor on these systems are mounted before the intercooler.
Looks good! I love maggies....and whipples
Any chance you can move the IAT after the cooler to limit timing being pulled? I guess not on a blower like that. Makes no sense to have it before the cooler since its the air after the cooler that matters.
howmuch boost is she putting down? thats a nice street setup im willing to invest in lol
I thought the same thing to...why not mount it after the cooler?? But in the end...it doesn't really matter where it's at, before or after. You just end up with a shift in reference points as it related to IAT. The only reason to mount it after the cooler is if you wanted to compare these IAT's to another motor that is N/A or a conventional intercooled boosted application. See what I'm saying?
COTM Editor
those are nice results... that low end torque will be real nice
what size maggie do you have on yours?
also curious on what you did for the intercooler... i had a custom one made for mine by griffin that i mounted in front of the rad where the ac condenser use to go... my car is in paint so i haven't yet been able to get it tuned and dyno'd yet to see how much it hopped up my LS3 type motor
Car: Camaro
Engine: 6.2L
Nice! Sounds great indeed. Dont bother with the LS6 valve springs though IMO you can never have too much spring only not enough Id go with the PAC1518 beehives and might as well throw the LS6 cam in there while your at it theres another 30-50 ponies waiting for you for cheap lol
Upgrade the pushrods while your at it
Not that you need anymore power than that anyway Thats pretty stout.
Car: 83Z28 HO
Transmission: G Force 5 speed
Nice!! I wish I had taken at least a quick IPHONE film when I had mine on the dyno. Gotta love that screaming sound the blower makes at WOT.
The torque they lay down is awesome and a curse at the same time. Getting any decent traction is a major challenge (at least for me). And I'm running 3.70:1 gear ratio in the rear. I don't bother laying into it hard until I'm in third gear. I think I would have gotten better HP numbers with an LS1 due to that engines ability to breathe on top, but I got outrageous torque on the Mustang dyno. Change your gearing and it should be a rocket 0-60.
Well its just that you want to use the air thats going to the intake valves for your reference. That way you dont pull timing unecessarily. Precooler temps can be 200 deg but if after cooler temps are only 140 then you dont have to pull timing just yet. That could be 10-20hp per degree pulled on a boosted application.
Since its water to air the drop is consistant, as long as the water temp is controlled and remains consistant and the blower remains at a set operating temp. Its just that the air temps will vary greatly with a roots/screw type setup depending on blower heatsoak and water temps. If you did your first dyno pull cold, and then 5 pulls later on hot blower, you should see less power due to heat soak. Cobra stangs see it all the time.
Just saying it makes sense to me to have IAT's taken after cooler if possible and control timing modifications from there. Doing it the other way is much more conservative which is ok on stock bottom end type setups.
I would love a maggie setup tho. I want a GTO as my daily driver and then get the maggie setup with a mild blower cam. I love the sound they make but they are just too expensive. i can make a twin turbo kit for that price
I'll tell you what, that sound is very addicting....It almost make it feel like some sort of crazy windup toy.
Engine bay shot. The only thing I have changed since that pic was taken was to switch from running a PCV system to running dual breathers. As far as hood clearence is concerned I just had to trim out one small area from the bracing...other than that it fits great. Plenty of room around the back of the blower too.
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Engine bay looks perfect !!able to mount the cf frc that you had ? Or will you have to mod them
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Time for a cam swap and ditch that MAF. But we should stop trying to spend your money for you especially after what the maggie cost...She looks sick job well done sir.
I see what your saying. I do have a little data with regards to the heat soak issue. The car made 434hp with it heat soaked. The car sat for over an hour with fans blowing on it and another pull was made and it picked up 6hp. Unfortunatley I don't know what the difference was in IAT or coolant temp but I was kinda suprised it didn't pick up more.
Yeah, I figure this will do me good power wise for a couple years....then I'll put in a blower cam and definately ditch the MAF. The tuner said I am right at the upper limit of the MAF right now. Could see 500rwhp with the cam and a touch more boost
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
i know this is an old post, but do you still have this car? im doing almost the exact same thing to my 88 gta. it currently has an LPE gt2-3 cam (forced induction cam), long tubes, 25% UD pulley. i think im making about 375 rwhp right now. I bought a radix mp112 maggie, it came stock with a 3.4" pulley, i upgraded to a 2.9" pulley, upgraded the 78mm tb to a 90mm tb, upgraded injectors to 60#'s, bought a racetronix fuel pump, and a crank pinning kit. Im thinking about running meth, but not sure yet. im shooting for 525ish, boost should be around 8psi.
what size tb are you using? any video? any track times? did it add much weight to the car?any more pictures? hope you can help, i need some motivation to get this done. im following speartechs 91 z28 build.
Good luck with your project. Run the biggest TB you can afford, PD blowers love big openings..lol.
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Can you explane to me your ac system? From the looks of it, you are running the third gen system hooked to the 4th gen compressor.
Do you have a tubular k member or did you clearance the stock one?
Thanks!
Thanks!
Engine: 2002 Ls1
Transmission: t-56
is the 3.0 pulley he stock one? or did you upgrade?
Engine: 2002 Ls1
Transmission: t-56
the radix that i have uses a 3.4", but it only has the one pulley on the front, and the jtube that connects to the tb comes from the back. i bought a 2.9" pulley.
have you checked out speartechs 91 z28 with the radix magnacharger? speartech.com
they were running a 2.76" pulley though, which i may switch to eventually.
Ive got longtube headers and the gt2-3 cam also. Im really hoping for over 500 to the tires.
are you running cats? headers?
have you run yours at the track?
have you weighed your car?
Last time I weighed it it was 3340 before the supercharger, 9 inch rear and new a/c system...lol It's probably a pig now. I know the s/c alone was over 80lbs.
Engine: 2002 Ls1
Transmission: t-56
No cats, just long tube headers. No runs at the track yet. Not big into 1/4 mile runs. I might make it to the track once this summer...maybe.
I ran it at the track last year and got a 12.4@115 I think i could of gotten a high 11 with a better launch (2.0 60' ) I cant wait to see what happens with the maggie on there.
total engine mods can be found on my fquick page.
i just ordered some more parts today, i still need a boost gauge, wideband gauge, bigger maf for the 90mm tb, and some other odds and ends.
ambainb
04-25-2016 09:21 PM
mustangman65_79
08-11-2015 03:17 PM
