My 1984 HO Z28 LT1/T-56 Swap Log
#51
Car: 99 Tahoe, 98 Buick, 84 Camaro
Engine: 350, 2800, none at the moment
Re: My 1984 HO Z28 LT1/T-56 Swap Log
I almost forgot, you should put a link to your swap thread on the LTX/LT swap page at https://www.thirdgen.org/forums/ltx-...ltx-swaps.html.
If your thread is a TGO thread just drop a reply with a link to your thread and it will get added to the list so that others who have similar projects can access the info.
And, I'll see what I can do about getting back to my project. Dont think I dont apreciate the kick.
Regards,
newZman (Terry)
Regards,
newZman (Terry)
#52
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 92 Vette, 83 Camaro
Engine: 305 going to 95 LT1
Transmission: 5 speed going to T56 6 speed
Axle/Gears: 3.73 posi with disc brakes
Regards,
newZman (Terry)
Regards,
newZman (Terry)
more later
Tom
#53
There I go throwing out random acronyms... It is short for ThirdGen.Org.
I saw your swap was moved to the LSx/LTx forum, that's where it should be. If you dont want to follow the link provided here you can there through a 'sticky' link at the top of that forum.
BR
#54
I hope all is well. I'm still hoping you'll get going on your swap. My son and I got our engine out of the 83 Camaro and stripped the interior. We found some plastic pieces under the carpet, too. I guess they built these cars too fast.
#55
This is a thread that is getting older. My son and I have rebuilt our LT1 to a 383, hotcam, electric water pump and a bunch of other stuff on the engine. It's been a while since we took everything apart and I hope we can remember how to put it all back together. My thread is still ongoing. Come on over and have a look. I don't know how to make a link to it. Maybe some day.
#56
Car: 1986 Trans Am
Newzman do you remember what you did for your fuel pump and fuel lines. I am putting an lt1 into my 86 trans am that had the carbed 305 and my fuel lines come up on the right side of the car as yours did. thanks for any help
#57
A lot of water has gone over the dam since I did anything on this thread. But here is my status on the fuel set up on our swap. We bought a plastic 2001 Trans Am gas tank which has an electric fuel pump in it. We don't have it installed yet and I'm hoping that what other guys say is true that it fits just like the old tank. The only thing needed is a modification to the filler pipe. I've done some research on the fuel lines and found that the 4th gen cars all use nylon or plastic lines. I will use these lines temporarily as I learned how to cut and crimp them to fittings. Besides this makes it easier to make connections to the fuel rails and the fuel pump on the tank as I can use OEM connections. To protect the lines under the car I'm going to enclose the lines in some electrical conduit. Also I'm cutting a trap door above the tank so it will be easier to service the fuel pump without removing the gas tank. If you plan on using the metal lines in your car, I'd suggest contacting Pure Choice as they might be able to help you with connections and flexible braided lines. Hope this helps.
#58
Car: 1986 Trans Am
Thanks for the info Strick 1 its always good to know multiple options when doing something. I am planning on keeping my stock tank and just cutting the access hole as you were mentioning. From what i have read I can just get a fuel injection sending unit and fuel pump and swap. I will definitely need to contact pure choice it seems like everybody goes through them and are satisfied with them.
#59
#60
Car: 1986 Trans Am
Strick 1 thanks again for the help. I will make sure I cant put a fuel pump inside my tank as you say. If I cant I don't have a problem putting an inline fuel pump on. My gas tank is still in pretty good condition so I don't want to replace it yet if I don't have to but maybe something for the future.
#61
colton_carlson
03-08-2019 12:21 PM
GVMV
08-16-2015 08:01 PM
