92 Z28 Forged 346 TC78 Build While retaining A/C!
#51
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Re: 92 Z28 Forged 346 TC78 Build While retaining A/C!
I'm running a 3" down pipe to a electronic cutout and a mufflex 4" exhaust. The 3" should be fine at my power level. When I upgrade I'll go bigger.
#52
1 Post
Car: 86 IROC, 89 GTA
Engine: 350 blocks, both of em
Transmission: 700r4s
Axle/Gears: 10 bolt and 9 bolt, 3.73, 3.23
I already checked clearance on my car, a 4" pipe fits in there just fine as well. I'll be running mine nearly identical to yours.
#53
Transmission: 4L80E
I was going to try to run something bigger but all of its already tight. And I figured the turbo is only a 3" exhaust. I did a little bit today. Mostly cleanup and paint getting ready to put rearend back in and my exhaust back on. Also got my HVAC back together. post some more pics later
#54
Transmission: 4L80E
Little update... Sorry guys I work to much! I started on my fan bracket for my twin Derale Pushers. Made out of aluminum plate and bolted to the front side of the core support.
#55
Transmission: 4L80E
Also started mock up and my intercooler pipes. Got my BOV tig welded on. Also I started mounting and wiring my 2002 Z28 Cruise control unit under the driverside front.
#57
Transmission: 4L80E
Thanks man! Theres been a few updates. Hard to work on the car being out of town all the time.
I've done a lot more wiring for my electric fans and fuel pumps. I'm running 10 gauge to them. Also got a bung welded in for my Typhoon IAT sensor in my intake piping, The rest of my piping has been completed. Figured out I cant run a wonder bar due to the fact my turbo shoots downward.. damn it. Trying to figure out my slip yoke with my 4l80e that had a bolt on one. I'm gonna bite the bullet and yank my trans and put in the right output shaft just so I can have more spline contact. Kinda weirded out on running a yoke with counterbore and only having 2" Of spline contact. I also got my steering shaft built from a chevy astro van. Give me a bit and Ill post some pics. Also got all my feedlines to my turbo made and installed my stainless flexable radiator hoses.
#58
Transmission: 4L80E
Sorry guys, Hard to find the motivation to work on this due to work and family. But heres a update. Got all my intercooler pipes hooked up. Installed a power steering cooler. Got all my PS lines ran. Wiring wiring and more wiring!! Also decided to run methanol injection. I bought a small fuel cell to mount in my spare tire well. Had to build the bracket for that.
#59
Transmission: 4L80E
Ok here's the bracket I built for my methanol tank. Wanted the pump to me mounted to tank.
#60
Transmission: 4L80E
Here's where I mounted my progressive methanol controller. Also how the cars been sitting. Working on mounting all my panels up.
diana227vegas
07-08-2016 12:27 AM
ambainb
04-25-2016 09:21 PM
LT1Formula
08-20-2015 09:36 PM
db057
08-11-2015 10:11 PM
