Some Conversion Questions
Hey guys, I'm starting to save my pennies to afford a 5.3 swap by mid summer. But I have some questions on the best course of action. I know the 5.3 swap is fairly cheap, and I would be swapping this in a 89 RS Camaro with a V6. But my problem is, I would like to make the most power, for under $2500 with a 5.3, or alternatively a LT1. I plan to pair a T-56 with them if I can.
Which would be the cheapest route that will make the most power? Also, would it be possible to make 400HP at the crank of the 5.3 without any kind of forced induction? Or would the LT1 be a better choice for that goal? And with the 5.3 what options do I have as far as heads, and cams? How hard would it be to put a 408 LQ4 in it's place later on? Or is that a completely unrealistic idea?
The idea I have in my head is a 5.3, with a MS4 cam, LS6 intake, and whatever heads would be best to go with that set-up, followed by a T-56 behind it.
I want to get this done somewhat soon, or start getting parts soon because I'm really tired of just how slow my 2.8 V6 is. Thanks for reading and answering my questions, I really appreciate it. Thanks!
- Dalton
- Dalton
Engine: Cammed 6.0L LSX
Re: Some Conversion Questions
The ms4 is probably too big of a cam for a 5.3.
I'd call texas speed and pick their brains, but I would think you should be fine with their 224R or 228r. The ms4 is a 239/242.
Car: 91camaro
Engine: 5.3
Car craft did some dyno testing with the 5.3 and gain 100 hp with just a cam swap. It put down 433 at thie flywheel. That was with a carb and headers. Here the link to the article. It says cam and heads at the top but they tried just the cam swap first.
http://www.carcraft.com/techarticles...ine/index.html
Car: 91camaro
Engine: 5.3
I would just use the stock heads, they already flow pretty good. Just have the serviced. You could always have them ported, but i was told by a machine shop that, "there was no point spending the money doing it because they already flow good far better than the traditional SBC."
Car: 91camaro
Engine: 5.3
LS1 heads have larger combustion chambers so your compression ratio will be really low. Maybe good for forced Induction, but your running N/A right? I know people put 5.3 heads on LS1's to increase their ratio. Are you planning on running carb or fuel injectors? Either way 5.3 + GOOD CAM & valve springs+ intake +headers= 400 flywheel hp . Now if you can find a 6.0L from a truck thats were the power really is.
The original idea was to build a 408 LQ4, but that's not until later, and I'm just fed up with the terrible performance in my V6.
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
I say have a good cam spec'd out and some good heads.. After all thats were the power lies. Check into 799 Heads. They flow like 243 heads but are cheaper, put a good set of springs in them and a cam. Follow up with a good tune. A T56 behind it will just make it that much more fun.
I might just go with a LS1 intake just to get it going.
Thanks, I'll look into them.
You have $2500 for the complete swap? That wont be enough.
You should look into a 350 sbc or possibly and LT1 like you mentioned. With 2k you can make it a pretty stout engine and it would require much less fabrication.
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Now, I do know things like a radiator, harness, motor mounts, exhaust will add to the cost. I don't plan on keeping A/C just yet, as well as other things that will nickel and dime me. But the $2500 isn't really a firm budget, just somewhere I'd like to stay. Even so, I'm still saving money.
What PCM would I want to use? The stock truck one? Or a LS1 PCM?
I'd like to see that link if you have it. There are many variables to account for here, are you gonna fabricate a bracket for the truck accessories? What about fuel system? Wiring, are you doing that yourself? What transmission are you running? Will the trans and rear-end hold the new power? Do you have adequate braking for the new powerplant? Will you have enough money to rebuild these parts if they break?
Dont even look into cam swaps yet, make a list of what its going to take to put the build together, total it up and make a decision. I would advise against having a small budget and a short time frame.
LM7 swaps can be done for that. There's a guide on LS1Tech where a guy put a LM7 with a LS1 intake, fuel rail, and injectors in his Thirdgen for less than 2k.
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
I've had to slap some sense into myself on several occasions for getting ahead of myself. A build that has a budget price should never include the word CAM unless its already running, because they are not that hard to change anyway. Plus most cam swaps require new valve springs, and for good measure an oil pump and lifters. Maybe hardened pushrods.
Here is the <$1500 swap guide from LS1 Tech, it's the bare minimum to get a 5.3 into a car.
http://www.ls1tech.com/forums/conver...de-1500-a.html
Car: '89 GTA
Engine: 5.7L LS1
And note that that number is assuming you are making a crossmember and motormounts from scratch. And I think you mean the $1800 minimum listed in that post because we have to use a car intake. You can try to be oblivious but it will bite you in the butt later.
We speak of these prices because we know.
Honestly, I think you should just wait until you have can double your projected budget and can do the lsx swap comfortably, or do a 350 swap to get you by for a few months.
A good shape t-56 can cost from anywhere $1500-$2000, new clutch kit ($400 minimum?) new walbro is $100, then you need braided hose and AN fittings to the rail ($$$). It adds up real fast dude and I think you're heading towards a dead-end if you try this swap. Look at the "costs" threads on here, I have never seen one that was done for less than $4k that hasn't started out with a donor car.
Car: '89 GTA
Engine: 5.7L LS1
Once I'm completely finished (very soon) I will be into my swap for a bit under $3k. However I started off with a smokin' deal on a complete drop out Fbody LS1 with harness accessories, the works. And another amazing deal on an fbody 4L60E. So I don't count.
(and thats down to the nuts, bolts, and fluids)
I don't think it's going to be a dead-end, I think with correct planning and execution it will workout fine.
Car: 91camaro
Engine: 5.3
Im just about finished with my swap now, and here's a rough estimate of everthing i spent. Its not including turbo stuff. I did all the wiring myself with big help of the threads. And im also using the truck accessories and intake so no cost there. Just modding my hood.
Engine 5.3/Harness/pcm-335
Trans 4L60E-400
99 SS Rear end-100
rear brake calibers and rotors-150
fuel pump-100
fuel pump lines-30
motor mount plates from summit-70
trans mount-100
hood-30
powersteering pump and lines-90
Alternator-45
starter-45
Fbody oil pan and oil pick-up- 275
Tune-500
So my , a swap for 2500 or under 3000 is very possible.
Trans 4L60E-400
99 SS Rear end-100
fuel pump-100
fuel pump lines-30
trans mount-100
hood-30
Alternator-45
starter-45
Tune-500
Automatics are cheaper. If you had done an t-56 swap like the OP had originally planned, you'd be above the 4k mark as well..
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
On the note without a T-56, I can just put a stock 5.3 in the car with a 4L60E behind it to save on the cost of the T-56. I would do just the minimum to get it in and running where I could DD it. Then, I could concentrate on the extras like cam, heads, and T-56. Most of my ideas are just what I want. I am willing to do enough to get it in and running and drive it, while I save for the extra parts I want.
Engine: cammed LS1
I'll definitely come by if I'm not too busy.
