How do I identify what year my LT1 is?
1 Post
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
I've looked up several numbers on the block and parts on the engine
(10125327, 12552138, 10214196, GM SGI E105)
and I've come up with this
The engine seems to be a 94-95 (and the timing cover # seems to agree), but some places seem to say that the intake (12552138) is from a 96+ engine. How can I narrow it down? And how can I tell if the distributor is vented or non-vented? The engine was rebuilt so it guess it could be using parts from different years.
Oh and is the ALDL port in the wiring harness or on the PCM? Because I can't seem to find it either place...
Re: How do I identify what year my LT1 is?
92-93 are easy to spot. The intake lacks a fuel line crossover up front and the TB has a TV cable stud
94-95 are the most common. Check the front cover near the bottom, it should be smooth
96-97 have a crank sensor on the bottom pass side of the front cover
If you want to get really picky, 92-94 have the old 2 connector coil just like older TPIs. 95-97 use a single connector coil also found in vortec trucks
Vented optis have a vacuum port on the bottom drivers side, non vented dont. Non vented use a short stubby connector, vented use a ridiculously long connector. Be careful unplugging it, 9/10 break the tab off
Then comes the common info:
Alum heads F/Y-body
Iron heads B-body
Drivers side accessories Y-body
Pass side accys F/B-body
If you got a basket case engine or the PO did, narrowing down what it originally came from will be difficult. The good news is nearly everything is interchangeable
Alum heads F/Y-body
Iron heads B-body
1 Post
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The '94 f-body had the spline mounted opti as well, the pinned for that year was on the Impy SS, the '95 f-body will have the pinned opti with the larger hole for it.
Linson
08-21-2015 02:12 PM
