LT1 Motor Mount Brackets
1 Post
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
Hi I'm fairly new here and I just bought a 1994 LT1 and it doesn't seem to have motor mount brackets on the engine. Is something like this what I need? http://www.jegs.com/i/JEGS-Performan...oductId=752545
I already have the motor mounts that attach to the K-member.
Car: 1987 Trans Am
Engine: LQ9/L92
Re: LT1 Motor Mount Brackets
you don't want to go with those - they are replacements for the rubber side of the mounts. i'd check around your local salvage yards or ebay, you can use the standard sbc engine side mounts
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Use the stock mounts off your old motor, they bolt right up to the LT1. And I'd recommend replacing the mount bushing. I just ordered a pair of prothane mounts of a ebay for 50$ a pair
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Bummer. Buy them back!
I second the prothane mounts. Good stuff.
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
ambainb
04-25-2016 09:21 PM
NBrehm
08-05-2015 07:57 PM
