fuse panel question
fuse panel question
I see on lt1swap that you run a 4 fuse setup with 3 ign hot and 1 constant hot for the orange wires on the computer.
Now in my truck harness I have coils, injectors, maf, heated 02s, and pcm ign hot.
Which circuits should I combine for each of the 3 fused circuits, and are the 15amp fuses more than enough for this?
Car: 1987 Trans Am
Engine: LQ9/L92
Re: fuse panel question
this is one of the last things i've got left for wiring, love the layout. saving this diagram for spring
Builders need to vertify the relay pin assignment as they differ per each relay Mfg. There are very few high current relays that have pins 85 and 86 placed vertically on the right side. Gm relays have them diagonal as well as Bosche.
Basic stand alone fuseblock layout for LTx/LSx engines used by carbed 3rd gens and other non EFI cars. Original EFI cars like my 92 have ample fuses/relays in place from the factory so they get reused
T56 still has a reverse lockout solenoid which has a fused wire. Yoou can group it with another one like fans or HO2s, but why bother. Not like you're hurting for fuseblock slots
Car: 1984 Firebird
Axle/Gears: 3.42's
Is there a nice, neat way to mount relay sockets? I'm looking at something like this ( http://bluesea.com/category/5/21/productline/126 ) for the fuses, but I've not found anything near as nice looking as the relays. My car orginally had a carb, so I don't have the exsisting fuses...
http://www.lt1swap.com/fuseblock_obd2port.html
I use those. They nest nicely for a tight assembly. You need two fuseblocks and 2-5 relays for a 3rd gen conversion
Car: 1987 Trans Am
Engine: LQ9/L92
same here, exact same parts for mine. now i just need to finish wiring it all up and get it in the engine bay
Car: 1984 Firebird
Axle/Gears: 3.42's
Can one of you post pics of how you have it mounted? Right now I have a rats nest, I'd like it to look clean when its done. Where did you mount it?
Ghettobird52
07-05-2024 11:18 PM
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
