3in to 4in Y-pipe with Hawks LS Swap Headers
Old 11-30-2010 | 05:50 PM
Thridgen60's Avatar
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Axle/Gears: 9 inch, 3.50
Just wanted to share my 3in into 4in y-pipe that i made for my 6.0L swap. When i bought my hawks LS swap headers i got them with the 2.5in collectors and made a 2.5in into 3in y pipe. Well i got bored and decided to cut the collector off where it necked down to the 2.5in and tig welded on a 3in collector. Then i ran two 3in pipes into a single 4in with a 4 inch cutout. After the cutout i necked it back down to 3in. to go over the axle.
First the old y-pipe:
I made my own cross member out of some 1/4 plate and angle iron.
Passenger side of the cross member (I cut off the piece that sticks up once i was done).
Driver side of the cross member.
Old 11-30-2010 | 05:56 PM
Thridgen60's Avatar
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Re: 3in into 4in Y-pipe with Hawks LS Swap Headers
The new y-pipe has a lot more ground clearance than my old one, mostly because i didn't tuck the old one up very well when i made it.
Now the new Y-pipe:
There is just a small difference in size
I took my time building the y-pipe and smoothed it off inside for the best flow.
I added a nice little mount right in front of the cutout. It makes it really easy to remove the y-pipe because it holds it up while i take the clamps off.
Y-pipe installed
4 inch cutout located under the rear passenger seat hump.
Ill have to post up a video of how it sounds once i get my fuel injection swap finished.
Old 11-30-2010 | 07:35 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Nice! I need to redo mine but im using 3 1/2 where us using 4'
Old 11-30-2010 | 08:30 PM
Thridgen60's Avatar
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Yeah 3.5 should be plenty big, its was definitely worth redoing mine. The final product was way nicer than the first one i built.
The exhaust part of this thread is what convinced me to go 4 in.
http://www.ls1tech.com/forums/genera...heads-cam.html
IMO mine will even flow better than the one in this thread because the y-pipe doesnt neck down like his does and it has fewer bends.
Old 11-30-2010 | 10:53 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
Do you have any pictures of the car on the ground, I about to buy those same headers. I have a 700r4 that i am using as well in my swap and it's built for the 9's so should be good with the 700r4.
Old 12-01-2010 | 12:36 AM
Thridgen60's Avatar
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
I dont have any pictures of it on the ground but i will take some this weekend when im home from school. With this y-pipe i have only drug it once, thats because i was driving on a country road and i tried to straddle a loose clump of asphalt.
Overall i am pretty impressed with the headers besides having to dent the floor in to clear the o2 sensors. Just make sure you build your own y-pipe because there are plenty of horror stories on here about the hawks y-pipe.
Old 12-01-2010 | 01:21 AM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Re: 3in to 4in Y-pipe with Hawks LS Swap Headers
Ya I already have a guy that builds really nice exhaust systems, I was either going to notch the frame or notch the crossmember. Not to worried about notching it though. my frame is already a little tweaked anyways.
Old 12-01-2010 | 11:17 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I didnt have to dent or notch anything with my SW Headers. All Fit perfect. Since SW was 5 miles down the street I dropped off my car and had them make me up a Y pipe so I know it would fit right ! lol Also had them use a resonator after the Y to avoid drone since I dont have cats.
Old 12-01-2010 | 11:27 AM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
i was referring to the y pipe for clearances, not the headers
Old 12-01-2010 | 12:38 PM
Thridgen60's Avatar
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Well thats convenient.
My car has never had any droning unless the cutout is open
What are you running for a muffler? I have a flowmaster 3in catback system.
Old 12-01-2010 | 12:42 PM
Thridgen60's Avatar
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Yeah the only thing i did before i made the first y-pipe was make that double hump trans cross member. If you dont make a cross member you pipes will probably hang really low.
Old 12-06-2010 | 03:52 PM
Thridgen60's Avatar
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Here are some pics of the clearance of both the headers and the y-pipe. My car has 3/4 of a coil cut off the front springs and stock rear springs.
Shows the clearance at the header.
Shows the clearance of the y-pipe. The lowest point is by the can.
Old 12-06-2010 | 07:37 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I'm running a stock edelbrock exhaust that I installed back in 99. It was my first ever mod from bone stock. Its kinda rusty now but I want to see how far it takes me!
Old 12-06-2010 | 07:46 PM
Thridgen60's Avatar
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Haha yeah nothing wrong with that.
Old 12-06-2010 | 08:39 PM
Z28FAST1's Avatar
You should flip those clamps so the bolts are not the lowest point. My Vbands always scrap first at the collector.
Old 12-06-2010 | 08:50 PM
Thridgen60's Avatar
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Yeah i have been meaning to do that. The drivers side clamp cant turn much more up because the shifter linkage is right above that one.
Old 12-07-2010 | 10:39 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Nice work
TreDeClaw
Theoretical and Street Racing
06-22-2021 08:21 PM
Terrell351
06-13-2021 01:13 PM
sweet_87_iroc
09-25-2015 10:01 PM
hectre13
09-08-2015 03:38 PM
Out-Cast
08-22-2015 07:49 PM
Quick Reply: 3in to 4in Y-pipe with Hawks LS Swap Headers
