LT1 Fuel pressure regulator differences
Old 10-29-2010 | 10:38 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I ordered a replacement FPR for my LT1, because the one I had got damaged. The one that I got in the mail today has the bracket on the opposite side than the one that came on the motor. Will this regulator still work with my LT1? I can probably make a bracket to hold it on the fuel rail, but I need to know if it will work.
Here is a pic of them both next to each other:
The one that is damaged that came with my motor is on the right.
Old 10-30-2010 | 09:09 AM
Pocket's Avatar
Car: 91 Trans Am
Engine: LSA
Transmission: T56 AWD
Axle/Gears: 8.8 4.10
Re: LT1 Fuel pressure regulator differences
Corvettes and Fbody/Bbodys are on opposite sides. Im guessing you got a C4 unit
Go to a JY and pull one off a Bbody LT1/L99
Old 10-30-2010 | 10:58 AM
Ugh, it was sold as a 93-97 Camaro/Firebird LT1 regulator...
Other than the mounting point, are there any differences?
Old 10-30-2010 | 12:47 PM
Pocket's Avatar
Car: 91 Trans Am
Engine: LSA
Not that I know of
Use a clamp and install the new one on your rails sans bolt to confirm the regulator is your problem
Old 10-30-2010 | 01:09 PM
The regulator that I had originally is broken and un-usable. All I am asking is, will the c4 unit regulate the pressure the same way that the original one will? If so, I am sure I can make a bracket or something to bolt it down.
Thanks!
Old 10-30-2010 | 07:06 PM
Pocket's Avatar
Car: 91 Trans Am
Engine: LSA
Thats what I was getting at
Old 10-30-2010 | 11:36 PM
Allright, cool. I'll see what I can come up with!
Old 10-31-2010 | 02:26 PM
Okay, heres what I came up with, just to show what I did to remedy this:
I used some aluminum I got from home depot a while back, after making a cardboard template, and bent it into an L shape, then drilled a hole where the closest fuel rail bolt was. I also cut the bracket that held on the old regulator and used the part that holds the fuel lines apart to keep them steady, like the old bracket did. I don't see why this wont hold up just fine, theres no way the regulator can back off from the rail.
Old 11-01-2010 | 10:49 AM
Firebat's Avatar
In case it ends up not working out or being a problem in the future - oreillys, advance auto, or Autozone usually have.lt1 f-body regulators in stock for about 30 bucks
Old 11-01-2010 | 11:17 AM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
this is from speeddensity.org
"The 93 fuel pressure regulator was located on the bottom rear of the passenger side rail. For the 94+ cars this was moved to the rear of the driver side rail."
hope that helps.
Old 11-01-2010 | 11:51 AM
Those are the first places I checked, and they cost $70. A bit overpriced for such a little part. Maybe its different where you are?
Old 11-01-2010 | 12:38 PM
Firebat's Avatar
Holy crap that is pricey. Its been about 5 years since I bought one. Prices must have went up or they discontinued the cheap brand.
Old 11-03-2010 | 01:57 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
dude everything is overpriced... an FPR for an 87 Celebrity was 90 dollars over at AZ... I was like WTF ...
Old 11-04-2010 | 11:49 AM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
i have a stock one,its yours for $20 shipped i bought a new adjustable accell one last summer as an upgrade.PM me if you want it!
Old 11-04-2010 | 12:13 PM
If I can't get this one to work, I will definitely hit you up for that one.
Old 11-04-2010 | 01:49 PM
thewizard's Avatar
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
I know this sounds odd, but the FPR on 03-05 J-Bodies is the same as the F-Body part. I know this because I bolted an Aeromotive F-Body AFPR directly onto my 03 Cavalier fuel rail.
Old 11-04-2010 | 02:38 PM
thewizard's Avatar
In my hand is the stock FPR; on the rail is P#13107. Listed for 94-97 F-Bodies and 94-96 B-Bodies.
MustangBeater20
10-29-2022 09:20 PM
9192camaro
16
02-03-2019 12:21 AM
wayshegoes
08-17-2015 12:00 PM
89-S-dime
08-12-2015 11:57 AM
Kaweh
08-09-2015 02:54 PM
Quick Reply: LT1 Fuel pressure regulator differences
