Gates p/n: 21505 hose issues
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I seem to recall someone else having the same issue. This hose when trimmed still is a bigger diameter than the radiator and water pump. I took a section of correct diameter hose, put it on then installed the Gates hose. It was a tight fit but with the hose clamp it *might* hold.
That band aid should be ok for the initial start up, but what's the deal with this hose?
Engine: Cammed 6.0L LSX
Re: Gates p/n: 21505 hose issues
I'm using it even though it's huge. I have it fastened down pretty good with a hose clamp, haven't found any leaks yet.
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Same problem here, I trimmed it and it was still huge so I clamped the shoot out of it.
What I may try IF mine ever slips off is put something around the outlet on the pump to make it closer to the diameter of the hose, like wrap a ton of electricaltape around it or something. But like I said, it doesn't leak a drop so I'm not worried about it at this point.
Engine: LS1 / LS3
Car: 91 Trans Am
Engine: LSA
Transmission: T56 AWD
Axle/Gears: 8.8 4.10
Not sure if I just got a freak hose or what, but I didnt have to clamp the crap out of it at all. Wasnt even loose on the waterneck
Maybe one of you guys with the lucky hoses can buy one at your own local parts store, trim it, and ship it to me. I'll pay you for it of course.
I actually have bought two of these things, the first one I returned when I got it to the garage and noticed how big it was, and I bought the 4.3L Vortec hose instead, then I decided what the heck I'll give it a try, and bought a second 21505 hose and it's exactly the same as the first one, both came from my local Napa store.
Car: 91 Trans Am
Engine: LSA
Got mine from advance auto, asked for a 90 F250 7.5L diesel lower. Maybe Gates is a different company than the one we got
Engine: LS1 / LS3
I'm getting close to filling the car up with fluids and cranking it over for the first time. The suspense is killing me!
Car: 1987 GTA
Transmission: 4L60e
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
I'm going to ask a quick question as your all about hoses right now...everyone agrees on the 95 3.4L upper hose correct?
My upper hose is whatever one was suggeted in the same thread as the 21505 lower hose. I actually think it's for an early 4th gen V6 car. I just flipped it around backwards and trimmed it a litle.
Engine: LS1 / LS3
I did see this: 21505 Molded Coolant Hose; 1 3/4" x 2" x 22 11/16" What is the dia of the radiator/wp fitting?
Maybe you guys that are having it fit correctly are getting a horrible Chinese knock off that has fitment issues which work in our favor
Car: 91 Trans Am
Engine: LSA
Lower has 1.75" on both the rad and WP
I think ours was the cheap version of 1.75" hose that was formed and then flared right at the WP to 2". Cut the flare off and it's back to being 1.75" the whole way
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I just clamped mine down good and have been beating it to 7100 RPM like nobodys business.
Hotrodboba400
12-10-2019 07:07 PM
