4th gen gas tank swap
1 Post
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
ok so my head is spinning from reading all the search results and now i want to make sure i dont mess this up. i can buy a 93-02 4th gen tank, tank out the sending unit and resistor board and replace the board with this part #25319676, and install the tank and everything will be great. dont need to hook up the carcol canister or evap system (just take them off) am i missing anyhting? like i said my head is spinning.
Car: 89 RS
Engine: LQ4
Transmission: TH400
Axle/Gears: Too lazy to check!!
Re: 4th gen gas tank swap
If that is too much work then you can try what I did. It seems to work fine so far and didn't cost much at all.
https://www.thirdgen.org/forums/ltx-...ding-unit.html
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
AkDrifted
08-17-2015 07:45 PM
