5.3 to ls2 86 camaro
#203
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Re: 5.3 to ls2 86 camaro
main drive belt
Gates #K060763
a/c belt
Gates #K040378
the rims only come in a backspacing for the 4th gen f bodys so you'd need spacers for them to fit correctly, OR a 4th gen rearend
#204
Car: 1991 Camaro RS
Axle/Gears: Stock
#208
Car: 1986 camaro
Engine: ls2
Finally bit the bullet and ordered a set of tfs 215's from a member on tech.. Hoping to break the 500 rwhp mark on motor!
#209
#211
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
nasty...rather than going back to auto...just build another car with an auto. then, every morning, you can decide; bangin' gears, or full on drag car..........
haha, maybe put an f13 cam in the auto car
#212
Car: 1986 camaro
Engine: ls2
Only people that order a f13 are people that dont want to make real power lol. If I did go back auto it would be a 4200-4400 converter in a 4l80e
#214
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
looks great! those 4th gen panels and console look awesome in there.
#215
Car: 91 Z28 Convertible, 2000 trans am
Engine: ls6, ls1
Transmission: 4l60e
What'd you have to do to get the panels to fit? I've been trying to find some info on those, but no one goes into detail.
#216
Car: 91 Z28
Engine: 6.0L LQ9
lookin' good, you can just do what i did in my 67 c10....put a 5 gallon bucket in place until you find the seats you're looking for. pretty sure its legal, haha.
#217
Car: 1986 camaro
Engine: ls2
pretty sure uppon the first mash on it session id fall off my bucket and wreck......... but id still have black leather rear seats
#218
I rocked a half cinder block in my car to move it aroun till I put the seats in lol
#220
Engine: Cammed 6.0L LSX
That interior is gonna be real nice once you get those seats recovered.
#221
#222
Car: 1986 camaro
Engine: ls2
i would honestly not recommend anyone that doesnt have the time/temper/skills to do the whole interior swap... BUT the center console is a direct bolt in, the dash isnt that bad once you actually get started, the wiring is kinda a pita and the door panels..... i cant even say what i would like to say about the door panels. you have to remove alot from the actual door to get them to fit, BUT as said it can be done with enough time and patience.
#224
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
#226
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
4 cupholders in my car, makes it so nice going to a car show with a gatorade in one and 2 bottles of water in the back ones, or sitting in the staging lanes while cooking in the 90 degree heat and drinking one. I'd never go back to a thirdgen console
#228
I have a feeling I'll go to a 4thgen console atleast in my trans am. When he Camaro gets he swap I'll leave it 100% as is on the inside and out.
#230
Car: 1986 camaro
Engine: ls2
i plan on using the 4th gen ones where they meet the dash and the stock 3rd gen one and cut them off about half way and fiberglass them together... its an idea in the works, as of right now there stock 3rd gen ones
#231
Car: '85 Camaro
The interior looks WAY better then the red lol. Yeah I'm gonna have to get a 4th gen center console soon, I keep hitting the side of mine when I put in reverse
#232
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
and I actually thought of that idea myself however im not sure how close they are to lining up in the middle and what not.. ya know? I think I might give the fourth gen ones a shot but again I haven't checked if they line up where the ttop meets. All a work in progress though!
#233
Car: 1986 camaro
Engine: ls2
As I thought they were..
#234
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
I also have an option of buying a used 4th Gen setup and from looking at it, thinking this could easily be converted to a 3rd gen setup with a couple of custom floor brackets installed.
http://www.spohn.net/shop/1998-2002-...ersY-Pipe.html
Also, I was wondering if you ran into any clearance issues with your Hawks headers and the QT bell?
#235
Car: 1986 camaro
Engine: ls2
Hey nasty, wondering what size exhaust you are running with this? I am thinking of picking one of these trak paks up while the deals are on. Merry Xmas to me kind of thing. LOL
#236
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
im running a 3 1/2 inch peice over the crossmember. if i had to do it again i would NOT hesitate to buy the trak pak as for the bellhousing.. there is no clearance issue with the qt bellhousing when installing it with the headers already on BUT the bellhousing interfered with me trying to remove my heads because the housing is so much larger than a stock one. ended up removing all of my studs on the passanger side.
#237
Car: 1986 camaro
Engine: ls2
if you were to put the smallest part of the "X" in the hump in the cross tube then yes it would fir.. might require alittle massaging on the floor pan..
#238
Car: 1986 camaro
Engine: ls2
Got my ls3 head gakets in, put down some fat mat under my carpet and ordered some 6liter eater front seats... Still waiting for my trickflows, but the wait is worth it.
#240
Car: 91 Z28
Engine: 6.0L LQ9
so what's the deal, need an update. i'm waiting on parts to fix a leaky powersteering pump, and its snowing outside....
get the heads on yet?......seats in?
#241
Car: 1986 camaro
Engine: ls2
Hopefully tooley gets my heads today or tomorrow and the guy I traded seats with wanted to use my boxes to ship my seats in so I went ahead and sent him the 6le seats and hopefully he gets the ta seats ready to ship out today. Havent really dont anything to the car, painted the valve covers couple days ago....since its STILL 72 DEGREES in lower alabama.
#242
Car: 91 Z28
Engine: 6.0L LQ9
#244
Car: this and Dodge Dakota Quad
Engine: 383 tbi
Transmission: 700 R4
Axle/Gears: 3-73
Re: H/C/I 5.3 86 camaro
I am looking at the same. what motor mounts did you buy? any supprise issues. found a great wiring video at http://www.youtube.com/watch?v=tITS_...eature=related
#245
Car: 1986 camaro
Engine: ls2
#246
Car: 1986 camaro
Engine: ls2
well still waiting on my 225's to come in... so i stole this L33 from a kid for 150 bucks with a oil pressure issue. he said the screen is stopped up but i believe the sensor is bad, because the sensor has not been replaced and when the kid told me it would loose oil pressure he would keep driving it and it would run fine and randomly it would get oil pressure back. motor has between 23-24k miles on it
#249
Car: 91 Z28
Engine: 6.0L LQ9
atta boy! i'm considering a 5.3 for my el camino...either that or find me a regular cab short box 1/2t to play with.
