nastyist sounding cam in a lt1?
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
i have heard the ms4 and trex for ls motors and i love them!!! but anything for a lt car?
Car: 02wrx/88 rs
Re: nastyist sounding cam in a lt1?
ttt
i found a gm847 and a cc306
any others?
any others?
Car: 02wrx/88 rs
well i wish you could get that sound without making it unusable for most. Im slowly learning what i really want in a cam. But i thought it would be fun to know what cams out there are just killer sounding
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The nasty sounding cams are hell to live with in a daily driver. COMP's Thumpr cams are good for a nasty sound but still decent torque and driveability, but even the smallest belongs in a 383 stroker, and even then will be difficult to tune your EFI for. It'll give incredible upper-midrange. It'd be a good match for LT4-style heads and Edelbrock's LT4 Air Gap intake. Start with 4.10:1 rear gears.
Car: 02wrx/88 rs
well to put you in the loop, im trying to build a lt1 383 road race motor. Ill be using 208 cc ported lt1 heads and ported intake: i dont know what cam yet. I want a nice flat curve for power out of turns. But im asking about cam sound
just to see my options, do they make a hydro roller thumper cam?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
They do, but not listed as LT1 (probably because of the dowel pin). http://www.summitracing.com/search/M...ord=thumpr+cam
Car: 02wrx/88 rs
Engine: LS1/LQ4
There were several listed, including retrofit. The non-retrofit ones had 2200-5900 RPM powerbands claimed.
Car: 1992 camaro
Axle/Gears: 3:73
http://www.advancedinduction.com/
http://elliottsportworks.com/
Both can spec you a cam that will match what you needs.
Sound clips-- Thumpr
http://www.jegs.com/p/Comp-Cams-Thum...ms/763876/1000.
Thumpr & ***** Thumpr sound clips.
( edit )
Didn't take too well.
Click cams & valve train
Click Comp Cams Thumpr Cams
2 sound clips will come up
Click which you want to hear
( edit )
Last edited by t-top havoc; 05-20-2010 at 07:19 PM. Reason: Comp Cams Thumpr sound clips
Car: 02wrx/88 rs
but thethumper are notion my motor?
comp will grind a thumpr Lt1 cam for you if you want them to, just tell them thats what you want. costs the same as ant other LT1 cam would through them.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Elliott is making a pretty good name for himself in the LTx world. If you ask him for a nasty cam, I'd bet he could also help you get a well-matched tune. COMP can't offer anything like that.
they just seemed stuck on the thumpr cams, elliott would probably be a much better go to guy for this, he could match a cam to the motor better than just grabbing and off the shelf.
Car: 02wrx/88 rs
i have been looking at them hard to decide between ai and lloyd. i was looking at the le3 heads. think they(with a good cam) would pull 450+rwhp?
http://www.elliottsportworks.com/lt1.html
Car: 02wrx/88 rs
and i may wanna put my head deciding in a different thread.
