Blakes LSx swap - pic/vid heavy
#204
Car: 99 Tahoe, 98 Buick, 84 Camaro
Engine: 350, 2800, none at the moment
Re: Blakes LSx swap - pic/vid heavy
Hello, I am putting together a list of the LS and LT swaps here on TGO this looks like something that should be on the list. If you are willing to add your thread you can paste it here in a reply: https://www.thirdgen.org/forums/ltx-...ltx-swaps.html and will get it added to the list.
#212
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Actually, those will be less work. Having done both, I can attest to that.
I used the non-setback type and notched the K-member. The Hawks swap tranny crossmember lined up fine.
Be aware that if you use the plates, you can't use the 4th gen AC compressor.
#214
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Dont forget about that top bolt on the pedal set... The one that screws up from the bottom (vertically). Those dont usually line up, and you'll probably have to adjust the hole in the pedal bracketry.
Everythying else looks good... You did the right thing by drilling the holes out. If you used a 4th gen booster you wouldnt have had to do that. Or if you had used 3rd gen pedals.
I honestly dont see the point in using the 4th gen gas pedal though. By the time you bend things and get the brackets to bolt up, you could have just sliced it off and used the modular 3rd gen pedal. But if you can get it work for ya great!
J.
J.
#215
Engine: Cammed 6.0L LSX
I never got the top hole in the 4th gen pedals to line up enough to put a bolt through it. I ended up using 3rd gen pedals and putting a different pin on it to fit the master cylinder rod. It works great, plus the 3rd gen pedals are beefier believe it or not.
#218
Car: 86 Trans AM
There ya go...that'll work.
In order to get my top hole to line up, I had to egg the hole out to the side. Kinda hard to explain, but you just gotta see how it lines up and adjust the hole. You DEF want to make sure you get that bolt in though.
J.
J.
#230
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
man watching this makes me wish i took more time to clean things up on mine. I cleaned it up some but i just did my swap as quick as i could and looking decent. Im going to eventually pull the motor and clean it up more.
#232
Car: 86 Trans AM
On the other hand...the car gets driven in all weather (obviously) and that under coating has probably kept the car as rust free as it is. So Im kind of torn on that. No one really sees under the car but me anyway haha.
Good work getting her cleaned up Blake!
J.
#235
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Great post. If you remove the plastic cover from the steering shaft there will be a bolt under it by power steering box, 11mm. I would guess you have already unbolted the top steering shaft bolt since its visible. After unbolting the two take a prybar and pry from gear box. Steering shaft should come out, and then steering wheel.
#236
Thats exactly what I said haha. When I did my second swap, the car was so clean to start with, that I was slightly ahead of the game compared to the first car. But I still didnt strip a lot of the gunk off the under carriage like Blake and some of the other guys have. I always say that if I take it back apart, which is gonna happen, I would clean/paint more.
J.
J.
#238
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
I'm sittin here by myself and literally said "WHAAATTT!" when I saw the before/after on the underside. Thats a lot of work, good job man.
#239
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
U can eat off that underside lol I was cleaning mine up when I did my clutch but it was too much woek . are u ganna lay some type of coating ?
#242
Car: 88' Iroc-Z
Engine: LQ9
That's the inspiration i needed to clean the underside of my car. Tomorrow is the beginning of that for myself. I'll be patching a small hole in my floorboard, then coating with rust bullet, followed by some type of liner like you will be doing. I wasnt happy with the cleaning and painting i did. i just pulled my lq9 and t56 to clean, weld patch and subframe connectors, and coat with a rust blocker and undercoating. You've put a lot of work in to your car, keep it up! It's turning out amazing
#250
Car: Camaro
Engine: 6.2L
I think that bed liner is a great idea. A local off road friend here did his entire CJ5 jeep tub with Line-x and hes pounds the living hell out of it off road through dense bush etc and it doesnt leave a mark. Plus it soooooo tight and relatively noise free. It kind of works like duramat in terms of deadening the sounds that transmit so a double bonus there.
My 87 is in need of paint again soon so I may follow this lead. Good job on the swap overall man dont give up until shes on the road
