Blakes LSx swap - pic/vid heavy
Old 01-19-2012 | 11:26 AM
  #501
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Presets only. Interesting. Bummer you went through the extra work when it wasn't necessary.
Ditto on the hard lines. A lot less floppy stuff to have to deal with when you're putting the tank back in.
Old 01-21-2012 | 11:27 PM
  #502
blakecharles's Avatar
Re: Blakes LSx swap - pic/vid heavy
Old 01-21-2012 | 11:31 PM
  #503
Old 01-22-2012 | 01:31 AM
  #504
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Originally Posted by blakecharles
I also put the heads back together. The above was a test fit with spohn swap mounts. Ls1 will be pulled for final cleaning and paint then dropped back in the bay tomorrow.
Please feel free to tell me how to remove the dipstick
LOL...my brother basically had to destroy his dipstick to get it out. They have an O-ring that seals them in there but should just pull out. "SHOULD" pull out. I would keep wiggling it and pulling at it and you may be able to free it up. And progress is looking good!
Old 01-22-2012 | 10:41 AM
  #505
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Sorry if you've gone over this before, but what are the details on the headlights? Real projectors/HIDs? I'm wanting to do retro HIDs on my car soon.
Sorry for the hijack, I just never noticed them before.
Old 01-22-2012 | 05:43 PM
  #506
Old 01-24-2012 | 04:16 AM
  #507
Jwood1991's Avatar
Car: 87 iroc z
Engine: 305 tpi
Axle/Gears: ??drum??
Love the car been looking at your thread for a while now and jus bought a white 91 rs. Just when I thought it was ok the way it was you inspired me to rip it apart again (I was afraid to paint myself but hey if you can do it I can atleast try)
Old 01-26-2012 | 10:56 AM
  #508
Old 01-26-2012 | 12:25 PM
  #509
Car: 1986 Trans am
Engine: 5.3 LM7
Hey thanx,
I'm happy to see so many ppl enjoying this thread. I know it's taking a long time, but I had to learn alot. Still pending parts, will update soon!
Long time eh? LOL, I think my build is the definition of a long time. 4 Years in the making now hahaha. I guess you can't put a timeframe on good work though....but I'm sure you know that as well since you've been putting some TLC into yours! Love the headlights on your car as well. Gives it such a mean and modern look. Ever since I saw spikeZ's car with those headlights and the white paint, I thought it was an awesome combo!
Old 01-30-2012 | 01:28 PM
  #510
Old 01-30-2012 | 01:32 PM
  #511
Old 01-30-2012 | 01:36 PM
  #512
Old 01-30-2012 | 01:44 PM
  #513
Old 01-30-2012 | 02:25 PM
  #514
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
The rubber filler hose does need to be shortened. By how much...its hard to say, and I wouldnt go by a set number. Its somewhere in the ballpark of an inch to an inch-and-a-half. But, what I would do/did, is remove the rubber filler with the tank in place. Then mount your filler spout. Then measure what length you need the hose to be. Err on the side of long...you can always take more rubber off. If you go too short, you'll be buying a new one.
J.
Old 01-30-2012 | 05:12 PM
  #515
Car: 1986 Trans am
Engine: 5.3 LM7
I did what ghettocruiser said as well. You can mount the filler neck with the tank in place and it's not too bad. Thats how I did it. Just trim about an inch of rubber to start off, and work on it from there. Pretty sure I ended up trimming about an inch and 3/4 when I had it where I liked it.
Old 02-03-2012 | 05:08 PM
  #516
Old 02-03-2012 | 06:27 PM
  #517
Car: 1986 Trans am
Engine: 5.3 LM7
Oh! I see you painted yours! I'm going to steal that idea... any particular type of paint? I was going to just use the high temp rattlecan stuff
I just used gloss black rustoleum spray paint. It's pretty heavy duty stuff so it should hold up on a filler neck!
Old 02-08-2012 | 03:03 PM
  #518
Old 02-08-2012 | 09:21 PM
  #519
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
finished lapping the valves... just need to get the rockers back on, then strip and repaint the valve covers...
That looks nice all Black, I am sure it will "pop" in that white engine bay. What color you going for the valve covers? Those big block edelbrock ls1 valve cover would look nice on that engine.
http://www.jegs.com/i/Edelbrock/350/41183/10002/-1
Old 02-09-2012 | 07:56 AM
  #520
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Yeah, those would look pretty sweet on there.
Old 02-09-2012 | 03:26 PM
  #521
Old 02-09-2012 | 03:34 PM
  #522
Old 02-09-2012 | 03:58 PM
  #523
dprest68's Avatar
Engine: cammed LS1
I'm pretty sure those are just coil covers. So you would still use your stock valve covers.
Old 02-09-2012 | 06:40 PM
  #524
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
yea those edelbrocks are just coil covers, they are not valve covers.
Old 02-10-2012 | 02:12 PM
  #525
krzyz's Avatar
Car: 1982 z28
Engine: 383
Transmission: 4l60e
Axle/Gears: 3.73 posi
wow i just went threw ur how build and i gotta say great work, watching this build is what i needed to push me to get back and start working on my car again. i just gotta say thanks and keep up that good work ill be following it to the end.
Old 02-22-2012 | 02:39 PM
  #526
Old 02-22-2012 | 05:18 PM
  #527
Car: 1986 Trans am
Engine: 5.3 LM7
http://www.hawksthirdgenparts.com/98...steel-2-2.aspx
They have fancier ones and ebay has a big selection as well. My brother bought a real nice one with a trans am bird engraved in it but I can't for the life of me find it. They had other styles as well like "Z28" or a chevy emblem.
Old 02-22-2012 | 05:19 PM
  #528
five7kid's Avatar
Engine: LS1/LQ4
noob question: how do I delete the EGR
Put a plug in the hole in the intake manifold, and delete it from the PCM.
Old 02-22-2012 | 06:26 PM
  #529
Old 02-22-2012 | 07:03 PM
  #530
five7kid's Avatar
Engine: LS1/LQ4
You don't need an LS6 TB to run an LS6 intake.
Old 02-23-2012 | 11:07 PM
  #531
Car: 1986 Trans am
Engine: 5.3 LM7
Hey. Not sure if you got it figured out or not yet, but I recently bought the GM fuel level sending unit kit for the 97 grand prix. I know it comes with 2 sending units and I obviously only need one. You said it was out of your budget for the kit, but I'll sell you the second one for $70 shipped if you want it. I have a for sale thread up as well. PM me if you want it.
https://www.thirdgen.org/forums/lsx-...ml#post5192076
Old 02-24-2012 | 11:04 AM
  #532
Old 02-24-2012 | 12:58 PM
  #533
Car: 1986 Trans am
Engine: 5.3 LM7
I already installed the 0-30 ohm unit and programed the gauge. Have not tested it yet though... btw... I have the 97 grand prix unit as well, don't know how it came out to be 0-30 ohm.
I may the fuel pump back out though (still going back n fourth in my head about the turbo)... then I need diff injectors and dual pump + a few things I cannot think of right now.
Haha, ok. Yea I wasn't sure if you ever got it figured out or not so I figured I'd offer. And I'm not sure how you got a 0-30 version either! I know that the 0-90 one only came on the 97 non supercharged 3.8 motor, so it's possible you got one out of a grand prix with a different engine.
Old 02-26-2012 | 04:54 AM
  #534
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
all i can say is WOW!!! i just went threw all 11 pages of this thread and im amazed, i havent seen this thread since i went before BCT and that was went you had just started working on it... it looks amazing keep up the good work cant wait to see it finished and that 69 looks amazing also!! why didnt you just paint it?
Old 02-29-2012 | 02:12 PM
  #535
pault850's Avatar
Car: 1992 rs
Engine: 3.1 v6
Axle/Gears: stock
loving the thread, and the helpful amount of pics. i may just be simple minded, but I hate write ups with little to no pics of all, or in most cases none.
Old 03-01-2012 | 11:27 AM
  #536
Speedfreak391's Avatar
Car: 87 iroc Arctic White w/gold ss stri
Engine: Turbo'd 5.3 in process
Transmission: T-56 w/SPEC stage 3+ clutch
Axle/Gears: 9" Moser w/3.25's
Do you have any pics of how those motor mounts fit on the motor? I have something similar but they are the doug's headers mount plates and they are kickin my butt!
Old 03-01-2012 | 11:40 AM
  #537
Old 03-01-2012 | 06:48 PM
  #538
Car: 1986 Trans am
Engine: 5.3 LM7
This thread is pending shipment of a LOT of parts... too much for me to list right now.
Dude... Please tell me you aren't giving up on it?? You have so much time invested and the car is looking great. I really hope that isn't what you meant by that!!
Old 03-01-2012 | 07:50 PM
  #539
Old 03-01-2012 | 07:55 PM
  #540
Old 03-02-2012 | 12:15 AM
  #541
Car: 1986 Trans am
Engine: 5.3 LM7
LOL, you had me scared for a minute there! Seems like it's going to be an even more bad *** build now. And those headers look nice. Even the cheaper knockoff headers ussually hold up pretty well. Hopefully they fit in the bay nicely, since I think the SSW ones are designed for a 4th gen. Let me know how they fit. I may be interested as well if they do!
Old 03-03-2012 | 09:10 PM
  #542
Old 03-03-2012 | 09:32 PM
  #543
1fas92's Avatar
Car: 1992 Z28
Engine: Forged LS3
Transmission: T56 stage 2 clutch
Axle/Gears: 35 spline with 3.55 gears
Do you have a link to those headers ?
Old 03-04-2012 | 08:13 AM
  #544
dprest68's Avatar
Engine: cammed LS1
You've gotta love when the UMI fairy stops by! It brought me pretty much all the same parts as it brought you!
Old 03-05-2012 | 11:51 AM
  #545
Old 05-07-2012 | 12:21 PM
  #546
Old 09-11-2012 | 12:02 PM
  #547
BirdsOnly's Avatar
Car: Motorcycle
I have enjoyed this thread, nice work!
Old 09-23-2012 | 05:31 PM
  #548
thecraze's Avatar
Nice thread, blakecharles. I saw your videos on youtube and found the thread here. Are there any updates?
Old 09-23-2012 | 06:11 PM
  #549
weberflorida's Avatar
Car: 1991 Camaro Z28
Holy crap you are doing an awesome job
Old 09-23-2012 | 09:48 PM
  #550
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
I've been following your build for a long time
It has been a few months, please give us some updates.
Quick Reply: Blakes LSx swap - pic/vid heavy
