Wiring question
Car: 00 ss 89 iroc lt1
Engine: ls1, lt1
Transmission: M6, auto
Wiring question
I am almost done wiring my LT1 and only have 1 wire that needs to be connected to a switched power source. Where is the best location to connect this? Can I tap into the Purple wire going to the starter or is there a better wire under the dash to tap into?
THankjs
THankjs
Engine: ls1, lt1
Re: Wiring question
I think I already removed that wire but Ill check
Would the Yellow wire under the column work?
