I should not be left unsupervised
#301
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Re: I should not be left unsupervised
Pocket, why not build a simple blower intake manifold for it? it seems like you have the skill to do a nice intercooled setup.
#302
#303
1 Post
Car: 1992 B4C 1LE
Cheap ebay intercoolers stand in the way. Maybe he could apply a cheap ebay FMIC to make a liquid to air.
#304
I think his setup looks alot cooler if thats worth anything.
#305
I braved the cold for a little while. Whatever happened to global warming? 28* with a 20mph wind... BRRRR. I wouldnt bitch too much except this is NC, not Wisconsin
Anyways
Rough fitment with the finished plate. Outlet hat isnt going to be as easy this time
First two bolts may need to be welded to the plate before building the hat if I keep the modular design
Not sure where Im going to move the oil fill to. Dipstick flat out isnt going to work. Ill have to get a lokar piece. Those heater core lines are really pissing me off. Im looking into building hardlines from conduit to run the framerail
The inlet opening actually has the same perimeter as 4" tubing. Good news so I can simply squish a 4" tube and weld it onto the flange. No reducing or similar to create turbulence (noise) before the rotors
Biggest hurdle, the blower outlet flange overlaps quite a bit of the main bracket
Removed and a scrap piece of angle laid over
Thinking instead to weld the main bracket to the blower plate and cut a hole in it for the charge pipe, then form the hat accordingly. It would kill the modular design, favoring one large assembly the blower bolts to then bolts the whole thing to the head. Im not sure how easy the bracket to head bolts will be to access once the tensioner is put on
The downside of one large bracket assembly is the belt alignment becomes critical at the beginning of the fab and warping becomes a major issue. With the modular tray/plate design, slight errors can be addressed by redrilling a few holes and shifting the blower to suit
First of the 3 crank hub pieces came back. Looks sweet. Said it'd be about 3 weeks before the others are done
Anyways
#310
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
There is none, so I am assuming Mr. Sun cracked it.
#311
Engine: Cammed 6.0L LSX
Man that is loud, I love it!
#318
New heater core, painted the new heater lines black and installed with fresh hose. Flushed the coolant system, added a pillar pod to hold my boost/fuel press gauges. Pulled the dash hunting the vacuum leak to why the heater door wasnt moving. Took some measures of the current plates and modeled them in CAD. Used those models along with a few accessory drawings to build final assembly drawing
Tensioner is my biggest hurdle. It has to be located in space on the upper side to clear the WP pulley. Problem is it rotates counter-clockwise. Id switch it for a clockwise rotating tensioner except HD units made for a blower dont pop up FS very frequently and new they are about $150 each. Ill make it work anyhow
Its bolted to a 1" tube thats welded to the main cyl head plate. Support rods to the blower tray and waterpump. Hopefully it wont move much. I do miss having Solidworks to test it out though
10 rib belt, 216* of belt wrap on the SC pulley and 205* of wrap on the crank. It better not slip... ever
Crank pulley is 7.8" dia, SC 2.6". Drive ratio is 3.0, so the blower should be spinning about 19,500RPMs when I hit redline. Screamin'
Once I get another engine to play with Ill start mocking up the headers. Modifying a set of NASCAR SB2.2 headers, 1 3/4 stepped to 1 7/8 primaries, stainless. I hate to hack them up, but I cant seem to sell them
#320
WRT to belt wrap, have you ever seen what KB does with their blowers, like the mustang kit has a heavy plate that mounts on the front of the block (relocates the alternator so it's spun around) with 2 adjustable eccentric pulleys on either side of the belt pinching it together just below the blower pulley
#321
Actually, here is one that I did a while ago that you can kind of see what they did:
Stillen does the same thing with their 350Z/G35 setup (also eaton based, M90....), but they also use a small jack-shaft that installs in the front wall of the block.
#322
Like this?
Ill see about designing a support plate to hold the extra pieces. Using a common plate should make it easier to keep all the different pulleys true to each other
Found the one you're talking about with the relo alt
#324
I went picture hunting and didnt scroll up. My bad
Was playing with the pulley locations trying to make a design that cleared everything. Between the charge pipe, accy drive tensioner pulley, waterneck, and waterpump pulley, it was pretty tight
Two fails out of about 20
I moved the plate to the front which allowed the tensioner to be reversed. This helped two ways, the HD tensioner body doesnt interfere with anything and the pair of pulleys can overlap planes without physically touching
Mounts to two blower snout bolts (replaced with studs and sleeves) and a accy drive tensioner bolt stud. Not sure how Id get a wrench on the HD tensioner to install/remove the belt though
I dont see how to add one more idler near the SC pulley to maximize wrap without adding a second down low to prevent belt to belt contact. The lower I go, the less there is to bolt something to. Might just keep things simple with the 3 point belt. I checked the length VS Goodyear's belt catalog and Im still well within common belt sizes
#328
got any updates for us?
#329
He's probably adding a second supercharger as we speak.
#332
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
I sure wish I could swap my vortech for a twin screw, too bad it aint worth **** anymore compared to the prices of a twin screw.
I think a 177 would annoy me just knowing how inefficient it is.
#333
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Meh, centrifugal is the way to go on a street car, hell, most race cars nowadays seem to go to the centrifugal as well.
#335
The balancer hub came back from the machine shop. Pretty
For those that didnt see how its assembled
This should still take a stock LS1 crank bolt and be able to be pinned just like a normal balancer. Ive read horror stories of people spinning pulleys with a 6 rib. I *know* the 10 rib will spin if not attended to
Trying to line up a LQ4 next... it never ends
#338
Got another motor to tinker with
Cheap engine stands are difficult to get perfectly level but I got it. Must have switched the camera to blurry mode though
How much room Ive got to work with for the outlet. Filler neck's gotta go!
Rear brace fabbed, tack welds and an old pushrod brace. It true to the world
Not bad for a few hours of work in the freezing cold
#342
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
That si why i am turbo charging a 08 5.3, if i destroy it by throwing too much, i just go spend a little bit on a new short or long block.
#345
So how much can you anticipate to gain with this blower over the other one, without touching anything else?
#346
The problem is Im changing everything. Only similar part is the fact its a mostly stock 5.3
4L60E to 4L80E
LS1 cam to LS6 cam
Manifolds and Y-pipe to LT headers and duals
36 to 60lb injectors
Single walbro 255 intank to dual
Returnless to boost referenced return style fuel system
2.73 open 10 bolt to 3.73 posi 8.8
Atleast thats the plan. And just for numbers sake, Id love to hit the magic 500 but like the last endeavor, we shall see
4L60E to 4L80E
LS1 cam to LS6 cam
#347
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
I'd say that numbers well within your grasp. With one hell of a TQ curve.
#348
Torque is the fun part
Worked on the outlet collector today and nearly finished but hit a snag. My plate warped really badly. Ill have to cut the front loose and attempt to bend it back. Never seen 1/4" plate warp that badly and Ive put some heat to them. First time for everything though, May be fixable, may have to start over, Ill find out tomorrow
I thought out how the assembly would go before I started fabbing this time and it went smoother. I used geometric shapes as a beginning with simple cardboard filler sections. Took about 4 hours to get this far as opposed to the 2 days for the previous. Im also getting better at welding wierd angles and tight locations so I should have alot less leaks to track down
#350
