I should not be left unsupervised
#451
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Re: I should not be left unsupervised
Looks good! I'll be painting my engine bay as well as a 4l80e swap and some more goodies.. Keep us posted on that swap! Were all jealous!
#452
Engine: Cammed 6.0L LSX
I checked those places you are having issues with on your k member and I am not experiencing those issues. This is at full droop:
![Name: 7638cae9.jpg
Size: 79.2 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/393520d1501426643-i-should-not-left-7638cae9.jpg)
#453
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Turn the wheels some, itll hit
Upper contact occurs when going over large bumps with the wheels turned
#454
Car: 92 Firebird
Had some free time today and got alot done
Trans attached to the 6.0. Heavy little devil there
![Name: DSC02363.jpg
Size: 128.1 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/393091d1501425877-i-should-not-left-dsc02363.jpg)
Built my own stands and solid mounts. Ive read mixed reviews about solids in a street car. If they're excessive, Ill just swap them for polys. The mounts I built are the same dims as a stock clamshell
![Name: DSC02366.jpg
Size: 153.5 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/393092d1501425877-i-should-not-left-dsc02366.jpg)
Well that was fast
![Name: DSC02395.jpg
Size: 75.2 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/393093d1501425877-i-should-not-left-dsc02395.jpg)
Main bracket
![Name: DSC02399.jpg
Size: 80.5 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/393094d1501425877-i-should-not-left-dsc02399.jpg)
Big daddy
![Name: DSC02428.jpg
Size: 83.8 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/393095d1501425877-i-should-not-left-dsc02428.jpg)
![Name: DSC02434.jpg
Size: 137.7 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/393096d1501425877-i-should-not-left-dsc02434.jpg)
Some of my pre-fab tubing
![Name: DSC02440.jpg
Size: 77.0 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/393097d1501425877-i-should-not-left-dsc02440.jpg)
![Name: DSC02444.jpg
Size: 126.0 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/393098d1501425877-i-should-not-left-dsc02444.jpg)
This is getting too easy
Well that was fast
Main bracket
Big daddy
#455
somethings missing... wait where's the second blower!
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
#456
Freaking sick. If you decide to make a few rounds of those brackets I may try to get a set from you later. Seems like this would be a cheaper way of forced induction than a turbo
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
#457
Car: 92 Firebird
Brackets are semi-simple. The dual pattern crank pulley design is quite something, making copies will get expensive FAST. It takes a 4" diameter x 10" long solid piece of 4130 to make just the hub. I got lucky and scored one off craigslist for $20, try pricing that sucker
#460
Car: 92 Firebird
Are you running an intercooler?
how on earth did you score a 4" diameter, 10" long piece of solid 4130 off of craigslist? i need your craigslist!
![huh](https://www.thirdgen.org/forums/images/smilies/huh.gif)
#463
1 Post
Car: 1992 B4C 1LE
Also anxiously waiting to hear about which of the cheap headers that you came up with fit (or did I miss that?).
#464
Car: 91 Camaro RS
Axle/Gears: stock...
#465
Car: 92 Firebird
I assume the 80E is in there. How much hammering did you have to do to get it to fit?
Back to it. The main alum plate is actually higher than in my drawings. I messed up and ran the bolts through the upper bolts instead of the lowers. Stock hood is out. I notched the middle some and a RAII hood fits perfectly. Threw some old coolant/washer jugs in there to check fitment. Looks like I built it around them. Ill order some new ones from the dealer. I think Im going to go with a stock 3rd gen cruise unit again. I fabbed one up for someone else and it was very simple. I know those work, had too many problems with my digital unit frying
![Name: DSC02447.jpg
Size: 73.7 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/393080d1501425845-i-should-not-left-dsc02447.jpg)
![Name: DSC02448.jpg
Size: 101.0 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/393081d1501425845-i-should-not-left-dsc02448.jpg)
Hood fully closed and latched. Nostril edge has about 1/2" clearance. Still have tons of room up front for an air box
![](http://i150.photobucket.com/albums/s98/Pocket_004/LS1%20M122%20project/DSC02451.jpg)
#466
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
I just wonder if that radiator will be sufficient?
You need a red 10 rib belt. It'll make it faster.
![thumbs up](https://www.thirdgen.org/forums/images/smilies/thumbsup.gif)
#467
Car: 92 Firebird
Heres a few more detailed pics of the '80. It fits nicely, but exhaust will be tricky
In there, pan is a bit lower than the '60 or Fbody oil pan, but not excessive. Might have to trim the front wings off to fit headers. No big deal
![Name: DSC02452.jpg
Size: 84.4 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/393066d1501425820-i-should-not-left-dsc02452.jpg)
Plenty of room for the trans lines
![Name: DSC02453.jpg
Size: 94.9 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/393067d1501425820-i-should-not-left-dsc02453.jpg)
Theres already a divot in the trans tunnel for something. Needs a few light whacks up top to get some room for engine torque in case I switch from solid mounts to polys. '80 gear select shaft is not compatible with the 3rd gen cable. I ended up using half form the '80, half from a 3rd gen
![Name: DSC02457.jpg
Size: 89.9 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/393068d1501425820-i-should-not-left-dsc02457.jpg)
No known bracket will hold a 3rd gen cable correctly so this is what I cooked up. It was a 3rd gen piece at one point in time. My original cable was night enough to break right at the tip of the guide sleeve, so I get to buy a new one before going much farther. It keeps the cable tight to the pan for max exhaust clearance
![Name: DSC02459.jpg
Size: 113.0 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/393069d1501425820-i-should-not-left-dsc02459.jpg)
Last one for now. Even though the trans is enormous, the tail housing and output shaft are roughly in the same location as the 700R4/4L60/4L60E. Adapting the stock torque arm mount wont be difficult. The actual crossmember I plan to tie to the SFC's. Using the stock bolt holes would make the shape a giant U which wont be very strong, but will be directly in the way of the exhaust
![Name: DSC02458.jpg
Size: 106.0 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/393070d1501425820-i-should-not-left-dsc02458.jpg)
I dont see why not. Several guys pushing hotter setups on stock LS1 radiators which are smaller than those in 3rd gens
For the belt, I would have preferred black, but apparently all HD fleetline belts are John Deere green
#468
#475
Car: 92 Firebird
They do not
Rear A-arm mount interference, everything else cleared fine
#476
Car: 1985 Z28
Axle/Gears: fourth gen 3.42
I keep coming back every now and then just to check in on this project since my thread died :P
looks awesome Jon cant wait to hear it.
~Steven
~Steven
#477
1 Post
Car: 1992 B4C 1LE
Pocket your thread is awesome, I wanted to say that seeing that 4L80e has helped my friend immensely.
He is knee deep in a 70 bronco 5.0L project now, but his next project is likely going to be a thirdgen with a Duramax.
#479
update?
#482
Car: 92 Firebird
Not much to report. Just rolled the car back into the garage, been working on other projects. Did a few minor things though
Got another AC delete box, cleaned it up and put it in
![Name: DSC02607.jpg
Size: 158.4 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/388791d1501417339-i-should-not-left-dsc02607.jpg)
Got a free set of LS1 fans and stuffed them in there. Pass side didnt fit so I cut it out, the assembly still fought tooth and nail going in. Still need to order a few more T-bolt clamps to button up the intake tract. I went with a steel 90* vs a large silicone elbow. The old elbow liked to balloon quite a bit when I got into the boost
![](http://i150.photobucket.com/albums/s98/Pocket_004/DSC02608.jpg)
Scored a Cadillac pusher fan from the yard and mounted it up front where the other fan got cut out. Had to update the wiring to switch from single to dual fans
![](http://i150.photobucket.com/albums/s98/Pocket_004/DSC02609.jpg)
Quick pic of the balancer assembly with belts. Im still giddy with how that turned out. Looks funny but the drive belt is in the stock Fbody LS1 location. You can see just how close the 10 rib is to the drive to minimize crank snout stress
![Name: DSC02610.jpg
Size: 127.0 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/388792d1501417339-i-should-not-left-dsc02610.jpg)
Hope to be rolling before fall autofair
#484
Car: 92 Firebird
Hopefully north of 500 to the wheels. If not, Ill have to put a real cam in there. Maybe move the TB to the SC inlet and use all the ducting as plenum volume. Truck guy did that with a whipple kit and it REALLY made a difference
#485
Car: 92 Firebird
Dont think Ill have any trouble stopping. CTS-V vs LS1 Fbody vs stock 3rd gen
![Name: DSC02612.jpg
Size: 147.0 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/388680d1501417152-i-should-not-left-dsc02612.jpg)
Conflicting reports of how much rotor I can cram under a 17" C5 wheel. Find out once and for all if its a 14" (C6 Z06) or 13.4" (C6 Z51) in a few days
Got some tubing and will attempt a set of SFCs this weekend. Will be building the crossmember off the SFCs, so its time to set the driveline angle. So far the engine/trans have been supported solely by the solid mounts
#486
Car: Camaro
Engine: 6.2L
Them CTSV calipers are awesome. Better than the ZO6 brakes imo.
As for SFC's? Done many kinds and the square tube stitch welded into the rocker seam style are by far the best. SSM are the ones I first used like this iirc then Kenny Brown? I think that was his name but the x-brace upgrade to the SSM were mint. I have a hybrid of both now and no flexy nada
#487
#488
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Wow pocket, last thing I remembered was seeing your car in the classifieds, and now it's got a 6.0 with a GT500 blower strapped to it! Change your mind? LOL.....good to see you kept it. Awesome project too! I just spent the past 3 hours reading through your build and it is almost 5:30 AM here. Before I passed out and smashed my head on my keyboard I figured I'd tell you that the project looks great, and I along with many others can't wait to see what this baby makes for power. I went the turbo route, but superchargers are awesome as well with thier instant torque and throttle response. In a perfect world, I'd have a blower car, and turbo car! Maybe when I win the lotto lol. I'll be keeping my eyes on this! Good luck.
#489
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Pocket has quite a project on his hands. And I thought my project was hard. he he he
#490
Hey Jon, on a serious note, how much would you charge to make me a similar setup of brackets and a new crank pulley so I can do this on my car? I have been thinking of selling my exhaust system and going turbo, but you always seem to find cheaper ways of making good power. I'd go with a blower if it'd save me some money.
You can PM me if you want
thanks!
#493
1 Post
Car: 1992 B4C 1LE
Man, I hope the 13.4" work. If they don't, I wouldn't think you will have any trouble getting rid of those brakes. Would they fit with 18's?
#494
Car: 92 Firebird
Yes
Not dumping the brakes, exchanging the 14" rotors for 13.4" rotors
Believe it or not, ebay has the Z51 rotors at 1/2 price of the Z06 rotors
Centric 121.62086
Centric 121.62086
![nod](https://www.thirdgen.org/forums/images/smilies/nod.gif)
#499
Car: 92 Firebird
Success in the yard today
96 Ranger had an 8.8 with a 3.55 posi. Picked it up for $75. Here it is compared to the 10 bolt from a 98+ Fbody
![Name: DSC02621.jpg
Size: 145.6 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/388282d1501416392-i-should-not-left-dsc02621.jpg)
Fbody axles stuck in it to see how much difference there is. Drivers side is about 3" short, pass side about 7". Crown vic and rangers used a 28 spline 8.8 and commonly had posi's. Explorers and F150's used 31 spline axles. No big deal except I dont have any 31 spline axles in Fbody length handy
![Name: DSC02622.jpg
Size: 149.5 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/388283d1501416392-i-should-not-left-dsc02622.jpg)
Jig built. Only variable not set by the jig is rotation of the hogs head, which an angle finder will easily nail down because it's set to 0*. The little tube near the yoke is a peep sight so I can gauge how much the driveshaft CL moves. No one has ever reported issues with DS alignment, Im just curious
![Name: DSC02623.jpg
Size: 158.2 KB](https://www.thirdgen.org/forums/attachments/ltx-lsx/388284d1501416392-i-should-not-left-dsc02623.jpg)
Tomorrow Ill cut the tubes and weld everything up. Fresh axle seals and fluid should button up the build. Stronger axle for <$200
Side question, can anyone think of a good reason NOT to put the DS safety loops directly on the torque arm? Seems like a better idea than small crossmembers mounted to the chassis. The TA moves with the DS, the chassis mounted loops have to be ovaled to account for the travel. I checked the NHRA rulebook and the only regulation is dimensions of the loop itself, not how its mounted
