19155167 - GMPP Accessory Drive System Without A/C
Car: 1991 Camaro 1LE Z28
Engine: 6.0L
Axle/Gears: Ford 9" 4.33
Thinking of using this accessory drive for a 6.0L swap into a 91 Camaro:http://paceperformance.com/index.asp...&ProdID=248708. Anyone use this? Any reason to think it wouldn't work?
Car: 91 Trans Am
Engine: LSA
Transmission: T56 AWD
Axle/Gears: 8.8 4.10
Re: 19155167 - GMPP Accessory Drive System Without A/C
Thats the corvette style accessories
The PS pump will be hitting the steering box. Alt may hit the fender well, not sure
Fbody accessories are the best option
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Should have a prototype to show you later this evening, it is to delete the PS pump but i think Nemess also has one he is working on to keep the stock PS pump. It will delete the AC and re use the stock alternator.
COTM Editor
That is the exact accessory kit i used on my LS376/480 swap i did on my '85 iroc. In fact i also bought it from Pace.
It worked great and had no issues at all. The accessories between f and y bodies are spaced out from the block differently so you want to make sure you have the right harmonic damper. The LS376/480 crate engine comes with the corvette damper installed so this kit was a natural.
https://www.thirdgen.org/forums/ltx-...ne-swap-2.html
see post #80 in the thread above for a pic of it installed in my iroc
Car: 91 Trans Am
Engine: LSA
I stand corrected
That bit of info is going into my swap notebook
Engine: 6.0L
Thanks! I thought your accessory drive looked like the 19155167 from Pace. In fact, your thread is why I asked if it would work.
Guess my accessory dilemma is solved.
How is the clearance between the power steering pulley and steering box? Thats what concerns me on this front drive. I was almost going to sell mine and try to locate a LS1 kit.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Here is the first prototype we made and i love it, it is available with power steering, but i doubt the stock alternator will work with the EFI system of the GEN III/IV, so if you went carb here is an option.
1 Post
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Only thing about that is, you can install an LS series using the f-body bracket without A/C on it, it's totally seperate on the motor.
Engine: 6.0L
Do you have one of these accessory drives? Haven't tried to fit it, yet?
Sounds like it fits. I've looked at other swap threads and it looks like other guys are using it, too. See https://www.thirdgen.org/forums/ltx-...-ls3-swap.html
db057
08-11-2015 10:11 PM
